Old 16-02-2007, 11:39 AM   #1
gregg_13
2016 PX2 Ranger XLT
gregg_13's Avatar
Default RIMS FROM HEAVEN...Real Engineering
Radurra is Italian for Clear
The creator and patent holder of "the clear wheel" Doug McGoon and Forgiato have combined to turn this idea into a real drivable wheel.
In 2006 we proudly produced and introduced "The Clear Wheel" called Radurra for cars and motorcycles.
Again we return to our roots of jewelry manufacturing. A technique known as bezel setting which only master diamond setters can know, is where the diamonds are just slightly larger than the bezel they are set into, and held in place by pressure. Understanding this, we put the same care and consideration towards the Radurra as we would towards a fine watch.
By eliminating the alloy center of a three piece forged wheel and setting into its place a hard coated polycarbonate center with a glass-like finish we achieve an amazing and stunning look, with a finished product that looks too good to be a wheel. Much the same way the diamond is set into a bezel setting, the polycarbonate center is set into the forged aluminum hoops with precision machining and a jeweler's touch... the end result is a wheel that is strong, safe and beautiful.
Now show off your high performance brakes and suspension on your high-end car or motorcycle. The same way you would add diamonds to your platinum watch, add the Radurra to your "platinum" car or custom chopper. With a vast range of color and finish options, your Radurra is sure to be as individual as yourself or your clientele.
The Radurra is currently available in twenty and twenty-two inch, and are custom built on order for your car or motorcycle.
The same way all Forgiato Wheels are custom built by master craftsmen.
(More sizes available soon)
Technical Data
The center is 1.5 or 2" polycarbonate, chemical hard coated both sides.
Weight 20" - 27 lbs, and 22" - 38 lbs (complete wheel weight)
All other parts of the wheel are forged 6061t aluminum
(Inner and outer hoops and Hub center)
SAE tested, certified and passed Impact, cornering and radial tests.
Now in production, average delivery time is 6-8 weeks.
Suggested retail is $5000.00 per wheel
gregg_13 is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 12:00 PM   #2
pb02
inconceivable!
pb02's Avatar
hmm, here I was thinking Heaven was a nice place....... and at $5000.00 per wheel, I could think of kazillion and one other things to spend that money on.
Also, would you have to take them off to wash the brake dust from inside all the time?
pb02 is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 01:08 PM   #3
XRchic
Hello
XRchic's Avatar
I dont know if they are good or bad really, but I reckon if the price of those dropped a lot, and they were marketed correctly, they could take off in a big way...
Would the brakes overheat?
2008 FPV TERRITORY F6-X
Silhouette, window tint, roof racks, 3rd row seats, ROH Mantis 19s, black custom plates 'FPVF6X' and no stripes.
: Cobra :
XRchic is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 01:21 PM   #4
blackers10
blackers10's Avatar
brake dust would be a killer issue..
and i dont think brakes would over heat any more than a stock fairlanes brakes do.. as alot of standard cars from a few years back have solid faced wheels .. any look at any of the drag style rims on toranas etc..they are solid..
but i dont see any benefit to these over a set of thinly spoked wheels??
Old 16-02-2007, 01:23 PM   #5
BlueRaven
Dual O2 sensors
BlueRaven's Avatar
Thats gonna look hot on my XB.... rusty looking rear drum brakes visible all the time! Yeehaw!!
Black 1990 300zx Twin Turbo 5 Speed Manual :
Blue 2004 Mini Cooper S 6 Speed Manual - Yes, thank you Amanda. I realise now that you updated my signature to include your car. :
BlueRaven is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 01:32 PM   #6
coupdy do
How ****ed will you be when the Perspex crazes in the sunlight?
coupdy do is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 01:40 PM   #7
kooky
WRX terrorist
kooky's Avatar
ooooh a new use for car neons........
I have seen these on a US 350Z
: MY-03 STi :
kooky is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 05:18 PM   #8
XR8putts
XR8putts's Avatar
As mentioned in TopGear magazine a few months back, brake dust means that this idea is still born.
XR8putts is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 05:25 PM   #9
Kryton
Kryton's Avatar
wouldnt mind seeing the plastics after 100000km of brake heat on them.
Old 16-02-2007, 05:32 PM   #10
rag top
rag top's Avatar
I'd like to see them used in the V8 supercar series!
Old 16-02-2007, 05:38 PM   #11
ThoR_
Holdens Fall Apart!
ThoR_'s Avatar
i agree i dont think there crash hot
AU2 XR8, Venom Red, 200kw, K&N Panel Filter, 2.5" Lukey Exhaust
ThoR_ is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 09:42 PM   #12
XW_GS
Paulie
XW_GS's Avatar
NNNOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!! !!!!!!!!!!!!
"i was wondering why the frisbee was getting bigger.....then it hit me!" ....
My Website
www.freewebs.com/xwgs
:disco:
302 XWGS FAIRMONT C10 9" :
302 XW FAIRMONT 4 SP 9" :
Fact: an XW had a shaker before any XY did...... :Up_to_som
Should a 302 Cleveland really be called a 302 Geelong?? No 302's with a Cleveland block where built in Cleveland
XW_GS is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 10:00 PM   #13
RIPGMH
RIPGMH's Avatar
Obviously at 5k a wheel there's alot more engineering in these wheels then your average plastic weather shields, so cracking and sun bleaching probably aren't that big an issue. As far as brake dust goes, these wheels given their cost and hence exclusivity would negate the problems associated with brake dust and daily driving. Basically if you can afford these rims you can also afford a detail fairly regularly.
This makes my post count 351, I'm tempted to never post again.
RIPGMH is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 10:03 PM   #14
philstoj
philstoj's Avatar
Only problem with these wheels is you will see them on some ricer lancer, full of neons and 9' discs, and tiny calipers...
I think they would be better used to sit the phone and keys in the lounge...
philstoj is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 10:27 PM   #15
SP.UTE1
Burning Up 98 Octane
SP.UTE1's Avatar
There definatley a hot looking wheel but would be a pain in the **** to keep clean if it was a daily driver.
BBB
Better to die on your feet then live on your knees
SP.UTE1 is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2007, 01:31 AM   #16
GK
Walking with God
GK's Avatar
Me too, on every holden. I'd love to see the rims melt off the car! LOL!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 17-02-2007, 01:51 AM   #17
Kryton
Kryton's Avatar
i think this is another 'time will tell' invention.
it really all depends on how much testing has been put into these rimes.
Old 17-02-2007, 10:30 AM   #18
MattyJ
Oh dear.. every rapper is going to be straight into these.
I think we can stress less about the Lancers and what not using them - bit out of their price league and they're not exactly a stocked item at SuperCheap.
At least they're different... would be cool for show cars.
Old 17-02-2007, 10:58 PM   #19
irsa76
Snoopping
irsa76's Avatar
I would be very suprised if they were used for anything but show use.
irsa76 is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2007, 11:04 PM   #20
MITCHAY
I won't be giving up my STi rims anytime soon. $5000 per rim? Get ******!
MITCHAY is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 12:57 AM   #21
Jayden
Graphic Artist
Jayden's Avatar
its a first issue technology. no doubt it will lead to something one day I would actually want. not yet though.
For crimes against aesthetics in automotive culture, I sentence you to a life of commodore.
Jayden is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 11:16 AM   #22
Tony xa
Streetrides panel & paint
Tony xa's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Tonys qualified advice on paint and panel is always very good
I like them for their propose but for the price and the downfalls they have I can only see them being used for show and at show not realy on the street .
I like to see things new for cars weather they work out or not .
Tony xa is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 11:29 AM   #23
Scott
They look awesome. Would have been cooler if they had designed them like the chopper wheels though ie completely hubless.
Scott is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 09:11 PM   #24
Rev28K
re
Location: Victoria - where being slow & incompetent is considered being "safe"
I'd rather have the Dymag carbon fibre rims (metal spokes) -http://www.fastcar.co.uk/Lighter_faster_Carbon_fibre_wheels.YTFUHONoa2rmWw. html
Scuderia Rev: Otto the tow pig - 2007 3.0 litre Coupé, vernünftig schnelle aber kein peilstab, Bathurst 2007 und 2010 zwölf Stunde Gewinner Jaffa the angry ant - mid 70's Honda 市民の, 73 と立方インチ LSD Elle "the body" shell - early 70's Datsun フェアレディ coupe. いい体は彼女の内側、内側と土台を待つ
Rev28K is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 09:26 PM   #25
holmsy
holmsy's Avatar
i think you would find these rims would be only used for car shows etc. sure there is bound to be a few on the road but most would never be used properly.
holmsy is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 09:30 PM   #26
Ryan
My thoughts exactly. I'm happy with my $1500 18" VY SSs.
******* $20,000 for wheels.
Ryan is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 10:58 PM   #27
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
yeah , can just see them on the V8;s , Liquify before your eyes with the sight of a Bright Orange 1000+ Degree brake Rotor... Would Look Cool on the TOLL HRT Cars
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 11:36 PM   #28
drcook
I Bleed Orange!
drcook's Avatar
so what is italian for 'full of brake dust'?
DRCOOK XY BUILD - http://fordforums.com.au/showthread.php?t=56248
drcook is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2007, 03:20 AM   #29
JADED6
V8 Ghia & BF2 XR6 + Wagon
JADED6's Avatar
Definitely a car show only item and would do the trick quite well.
Polycarbonate roofing, designed to withstand the harsh sun still ages pretty poorly.
JADED6 is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
