Old 21-06-2005, 10:22 PM   #1
EF302
Default 200kw GT cam
i heard the the gt had a more aggressive cam. Is it worth swapping for stock xr8 cam 170kw. what would be involved, is it strait swap?
EF302 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2005, 10:53 PM   #2
PULLY6
PULLY6's Avatar
just buy an aftermarket one. much better HP gains for less $$
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust
PULLY6 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2005, 11:01 PM   #3
EF302
i think i can get it for under $100, if not i won't bother. what do u suggest for an after market cam.
sorry, dont no much about the 8. last car was an injected 6. gota learn all over again
Old 22-06-2005, 10:25 AM   #4
Supa R00
Rolling on Simmons...
Supa R00's Avatar
Your not going to get much gains from a cam just yet as the heads and intake manifolds will be choking your car to death... only when you upgrade these will a cam be really beneificial
The daily hack...
1994 ED
XR6
5Spd, Simmons FR17"s, SupaLow's, Sprint Bodykit,
Cam, exhaust and all that jazz... Complete AU XR6 conversion and soon to be turbo!
:voldar02:
Originally Posted by Walkinshaw
When has any XR6 after the ED, prior to the XR6T been anywhere near being a performance car, or much more of a car than a stock taxi spec Gli?
Supa R00 is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2005, 02:35 PM   #5
Cairns GT
The GT has 25pound injectors with a 75mill throtel body and larger MAF sensor, on an importes US HO motor with unigue GT 40Heads (apparently not interchangable with standard GT 40Heads), roler rockers, and a unique inner dampner spring in the valve springs. There is also a 13mm Phenolic heat spacer between the upper and lower intake manifolds, which are also unique and bigger than standard xr8's. Aswell as a unique cam and EEC module, programed to run with premium fuel. Also it has a low resistance air cleaner intake to improve air flow. (Valves Intake 46.4 exhaust 38.6) (Valve spring compression kg @ spec length mm Intake 40.0 @ 45.2 / 127 @ 33.0 exhaust 38.6 @ 40.6 / 120 @28.4) (Rocker Arm Ratio 1.70:1) (Camsharft lobe lift Intake 7.168 exhaust 7.168) Sorry for all the figures but I got carried away with the technical training notes booklet I percured.
Old 22-06-2005, 03:17 PM   #6
EDXR8
EDXR8's Avatar
Those technical notes aren't very accurate, the GT's had 24lb injectors, a 65mm throttle body and the GT40 heads were just standard FMS GT40's.
Cam specs are 0.479" lift and 209@50th duration (270 adv) so it's not a big cam at all, just slightly bigger than stock. I would look more towards the Crane 2031 or 2030 cam's, much more power potential and will still run on the factory EEC.
EDXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2005, 03:22 PM   #7
Cairns GT
Sorry about the specks I was just reading them from the Ford new model introductory manual, and I have put my air meter up against a 75m throtle body and it was identical.
Old 22-06-2005, 07:29 PM   #8
EF302
the more info the better, it all helps.
thanks falles. the cams on e-bay. thought it might be a cheaper mod. he's also got some ported and polished lower an upper ho manifold and 19lb injecters
Old 22-06-2005, 07:52 PM   #9
LUXO_8
windsor user
what you have to realise is, unlike the I-6 where you lift the rocker cover off and whip out the cam, the V8's are a lot more work to change the cam.
a cam in a V8 (windsor or clevo) isnt a "cheap mod" like the I6 cam change is
Old 22-06-2005, 07:57 PM   #10
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
E303 Cam
http://www.scoa.org/legacy/info/camsheads.htm
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2005, 07:59 PM   #11
Walkinshaw
Two > One
Walkinshaw's Avatar
Do it once do it properly. I wouldnt go from a HO to a cobra cam. As Grant said look into a 2030 or 2031(if you have 1.72rollers). I helped install a 2030 into a DC LTD and it made a huge diffrence to the way the car feels! However as Wayne noted its not a simple change, so its worth doing it properly!!
Thread Tools
Display Modes
