Old 10-11-2005, 06:04 PM   #1
EFFalcon
Last warning
EFFalcon's Avatar
Default Finally some control!
It may not look like much, but these little beauties will finally allow me to adjust the ignition timing on my EF.
From here on in i don't think i'll be running on ULP much (ignition advance will be too much i'm guessing) but LPG will love it!
[img]hxxp://www.deleted link/pics/mycar/engine/MJLJ.jpg[/img]
for a grand total of about $300 i'll have programmed ignition timing while still using the stocko EF coil pack and sensors
funniest part, both my licence (from vicroads) and this ignition controller (from the US) were meant to be sent at the same time... for some reason the US package arrived first :|
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 10-11-2005, 06:07 PM   #2
Walkinshaw
Two > One
Walkinshaw's Avatar
Where are you getting a base tune from? Can this also be linked into the knock sensor for auto advance/retard?
Old 10-11-2005, 06:11 PM   #3
EFFalcon
Last warning
EFFalcon's Avatar
should be getting a base tune from a modified EB, his running PULP so i should have a bit of leeway there.
unfortunately it doesn't have any inputs for auto retard etc, but for the price i'm happy
Old 10-11-2005, 06:55 PM   #4
xxxc
tuff
xxxc's Avatar
gotta love having the dizzy in the els haha
.......................FG XR6 UTE...........................
......................xc fairmont gxl.........................
...................GQ coil cab UTE ..........................
xxxc is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2005, 06:57 PM   #5
xxxc
tuff
xxxc's Avatar
gotta love having the dizzy in the els haha ,mmm distributer
Old 10-11-2005, 07:47 PM   #6
Walkinshaw
Two > One
Walkinshaw's Avatar
Moving the dizzy only offers static advance.
Old 10-11-2005, 07:51 PM   #7
hornet
hornet's Avatar
What is it?
5 Speed EL Futura
140rwkw last dyno
hornet is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2005, 08:31 PM   #8
EFFalcon
Last warning
EFFalcon's Avatar
programmable ignition controller.
ie. aftermarket ECU for ignition timing only
(don't need fuel control because its on LPG)
Old 10-11-2005, 08:40 PM   #9
John_LS1
good stuff john, you finally got it! another step closer to that turbo!
Old 11-11-2005, 03:00 AM   #10
Rmyers
Does Steve have a car?
Rmyers's Avatar
Sweet as! Now get it installed so we can see if it's gunna work ;)
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2005, 02:16 PM   #11
need psi
slow & low EA Ghia
need psi's Avatar
hey john do u think you could get another one? im interested in one for my car, ive got an ignition amp as well, do you knnow if they are compatible? or itwont make any difference.
Ea Fairmont Ghia 1988
need psi is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2005, 02:45 PM   #12
EFFalcon
Last warning
EFFalcon's Avatar
honestly no idea how compatible it would be.
i imagine it'd work some how but no sure exactly.
this is where i get mine and the related info:
hxxp://picasso.org/mjlj/
Today i got the car semi running, realised i had to leave the leads on the normal order (coz they're paired by firing order) so it was running with the timing hard set to 10 degrees BTDC (kinda a limp home mode thing)
it wasnt overly happy running like that so i'm assuming there is still either a coil pack wiring related problem or it doesn't like 10 degrees BTDC.
anyone had their car running with the timing set to 10* BTDC? how did it run?
Old 13-11-2005, 04:35 PM   #13
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
anyone know what standard timing is on an EA mpfi?
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 05:43 PM   #14
Walkinshaw
Two > One
Walkinshaw's Avatar
static timing is 10deg BTDC
Old 13-11-2005, 06:06 PM   #15
EFFalcon
Last warning
EFFalcon's Avatar
got it running better today, still some minor issues.
firstly it seems the ECU *really* likes having a tacho signal.
as far as the cars concerned the cars not running, warning lights on the dash stay on, thermo fans don't switch on, no tacho (expected)
the cars got a bit of a miss though, with the timing light i can see a miss & hear it too.
care refused to idle but that could be ISC related.
I've gotta determine if the crank angle sensor signal can be split between 2 ECU's and hopefully the stock ECU is happier with that outcome :P
Old 13-11-2005, 06:09 PM   #16
niko
likes falcon's
niko's Avatar
cool, sounds like abit of fun
www.carhubsales.com.au
niko is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 08:46 PM   #17
EFFalcon
Last warning
EFFalcon's Avatar
another update, seems the crank angle sensor signal can be split without problem, i tapped back into it and fed it back to the ECU, the cars a lot happier with it running properly.
tacho signal and everything is based from the crank angle sensor which is good to know
So yes, now that the cars happy i have the car fooled into thinkings its doing everything it should, there is still a miss on what seems to be cyl's 1 & 4. i'll try a few things to try and get that fixed tomorrow.
the ISC is also cracking it, when connected it opens to its wide open position and the car's idling at about 1300rpm, when disconnected the car is on the virge of stalling and then does, not sure what to do about that yet :P
Old 13-11-2005, 09:42 PM   #18
NZ
NZ's Avatar
You might need to do a code check on the stock ecu to see if anything has come up. The idle is fine tuned with the ignition timing by the stock ecu. The other thing is that the isc valve is in the full open position when the engne is revving while driving. Perhaps the signal from the crank angle sensor isn't strong enough for it now causing some probs. You'll get it sorted. Otherwise slot a dizzy into it as well! You don't need the sequencer if you aren't running petrol any more
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 10:12 PM   #19
EFFalcon
Last warning
EFFalcon's Avatar
i've figured out the idle issue may be related to the MAP sensor vacuum pipe being missing :P
i borrowed it for the 'new' map sensor and thus the factory one would be getting a WOT signal.
and since karl just said the ISC is fully open when driving, the ECU would think the cars @ WOT and thus ISC wide open and screwing the idle!
time to source another vac source.
Old 13-11-2005, 10:43 PM   #20
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
/me watch's with interest.
Dont blow it up again John.
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
2008 MA XR5 Mondeo
2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2005, 09:31 PM   #21
galapogos01
eec tweaker
galapogos01's Avatar
very interested in the outcome of this one john, keep the tread going
good work mate!
Jase
galapogos01 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2005, 09:48 PM   #22
EFFalcon
Last warning
EFFalcon's Avatar
it was 100% this morning, unplugged the MAP sensor and started the car, flawless, idled as it was meant to, drove properly, seemed normal.
i drove it about 20km, and had switched the car off in that time etc.
i was stoked
but... i started fiddling and trying to make it look nice, and taping up wires mounting stuff properly and now its idling high again, car still drives ok but the idles not the best. will have to check for some vac leaks tomorrow as the map sensor is still not plugged in.
anyway, heres the pic before i started tidying.
[img]hxxp://www.deleted link/pics/mycar/engine/edisincar.jpg[/img]
Old 14-11-2005, 10:00 PM   #23
Gubas
- BOOYEH -
Gubas's Avatar
NEVER FIDDLE! LOL
Glad to hear your project is on track. Hope the rest of the upgrade is smooth sailing! If only.
Gubas
1993 EBII Fairmont Turbo T04e 7 psi
Gubas is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
