Old 30-11-2016, 06:40 PM   #1
NZ XR6
Default Can anyone guess what this is for?
Sent from somewhere using Tapatalk
NZ XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2016, 06:44 PM   #2
sailaway
sailaway's Avatar
Default Re: Can anyone guess what this is for?
In relation to what?
Is it found in a Mondy or associated packaging?
Pete
Melbourne
2010 Ford Mondeo Zetec TDCi Diesel
Colour: Frozen White
sailaway is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2016, 06:51 PM   #3
NZ XR6
It's something I made for working on the Mondeo. A bit rough but it does the job.
Old 30-11-2016, 07:22 PM   #4
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
To place over the body seam when you jack it up with your hydraulic Jack.
I have something similar for SWMBOs VW.
Those from colder climates than ours use ice hockey pucks.
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2016, 07:47 PM   #5
NZ XR6
Yes, that's it. I initially used a block of wood under the seam until I managed to bend it when I jacked up the car too quickly.
I might check out the ice hockey pucks.
Old 01-12-2016, 08:28 AM   #6
rondeo
I've been using discs of 3/4 plywood (no groove) in the trolley jack head. The seam just sinks in a bit.
The jack makers are a bit behind on this one. Some of the rubber pads look like they'd slice nicely in two. Not intended for sills I guess.
I've assumed the vehicle weight should be taken on the edge of the seam, so the groove depth would be about 15mm. NZ your blocks don't seem to have been touching there?
Old 01-12-2016, 11:47 AM   #7
DZFord
DZFord's Avatar
http://protechproducts.com/index.php...ory&path=35_37
There are these too
Old 01-12-2016, 03:37 PM   #8
NZ XR6
Yes, I tried rubber pads but the seam cut straight through them. Same thing happened to soft wood (pine) blocks. I haven't tried ply though.
I had assumed that the weight was taken by the seam, but 3 of them have bent as a result of being used as lifting points. The shape of the scissor jack head is interesting - it looks to me as though the weight is taken on the inside of the sill.
So that is how I've designed the wooden block, and it seems fine. But I could easily be wrong!
I hate to mention the Accord for the second time this week, but the jacking points under the sills are far more substantial, and can be lowered directly onto axle stands. Or even dropped, as happened when the trolley jack release valve stuck!
Old 01-12-2016, 03:40 PM   #9
NZ XR6
Originally Posted by DZFord View Post
Nice.
Old 01-12-2016, 04:44 PM   #10
Vortex-98
Vortex-98's Avatar
What are you lifting a truck?
You can jack it up from the suspension bolt front an rear just don't use the tips of the jacks plate,an don't use ply use a solid block of wood about 3 in high x 4in wide.you can bend the double plate of the subframe if its not forward enough closer to the wheel
Vortex-98 is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2016, 07:45 PM   #11
NZ XR6
Yeah, if I could get the trolley jack under the car. But I do put the jackstands under those bolts.
The Haynes manual suggests lifting the car under the centre of the front crossmember. You'd need a very special jack to reach that far!
Old 02-12-2016, 10:09 PM   #12
And these http://www.ebay.com.au/itm/Premium-S...YAAOSwImRYG08F and http://www.ebay.com.au/itm/HELI-GUY-...3D252639420309
Old 02-12-2016, 10:10 PM   #13
And you could make these yourself http://www.ebay.com.au/itm/HELI-GUY-...3D252639420309
Old 02-12-2016, 11:18 PM   #14
cobrin
Challenge Accepted!
cobrin's Avatar
That's what I use and with that special jack you talked about lol, was last years xmass present. I see Auto1 has the same 2T twin cylinder aluminium jack in green (WTD) and $30 cheaper, mine is red.
Old 03-12-2016, 04:26 AM   #15
NZ XR6
Do you have a link thanks?
Old 03-12-2016, 12:42 PM   #16
sailaway
sailaway's Avatar
Ah but which one?
https://www.autoone.com.au/catalogue...gue/16#page/12
Pete
Melbourne
Old 03-12-2016, 01:14 PM   #17
Vortex-98
Vortex-98's Avatar
you could just use a standrd scissor jack to give you some clearance then slide in the trolley jack.. don't forget to crack the wheelnuts first (hate wen that happens)an grease the wheelnut thread when you do them back up...
Old 03-12-2016, 02:11 PM   #18
cobrin
Challenge Accepted!
cobrin's Avatar
top left $249 aluminium 2T, WTDHF20SA. it fitted when my suspension was sad and tired at it's lowest point, 3 to 4 pumps and it's off the ground. It's heavier than the typical single cylinder hydraulic jack but it does everything else easier/quicker and for that I'm grateful. Mine is red and sports a different brand but it's identical.
Word of warning if when you assemble the handle to it and start to pump the cylinder and the arm doesn't lift, remove the rubber fill plug on the main cylinder. I just started to pump it and it wouldn't lift. Figured out removing the plug to check the fluid level helps bleed it and away you go. I cycled it three times to make sure air was bled and it's been good ever since.
Thread Tools
Display Modes
