Early Falcon Car Club of Qld Inc The Queensland early model Falcon Club. |
22-02-2024, 11:38 PM | #1 | ||
Hello fellow XB Owners I NEED HELP Installing a electronic Dizzy into my 351 Cleveland WHER is the resistor wire? I know it runs from Coil to ignition but I need to find where to connect a nEW WIRE to run to Positive on Coil Colur location need help please
23-02-2024, 08:35 AM | #2 | ||
The wire resistor to the coil is in the harness. If you unwrap the harness from the coil back towards the firewall you will see it.
It is a thick pink wire if you keep following it back you will get to a red/green (From memory) you need to run a new wire from that point.
Territory black VSI lpg XW GS Fairmont 351C toploader 9inch Mazda Bravo 4 X 4 |
23-02-2024, 12:15 PM | #3 | ||
Hi mate some advice say its a red/purple wire from ignition which Ive found followed it back through firewall above brake booster then to junction near battery it seems to go on past battery and not to coil I note on coil positive side are 2 brown wires one thicker than the other so thinking is the thin brown wire the resistor wire so now about to solve that destination of the 2 brown hoping one connects to the red/purple damn am ove r it bloody ford engineers
23-02-2024, 02:31 PM | #4 | ||
The other wire is probably going to the starter solenoid.
I love Holdens.... |
Thread Tools | |
Display Modes | |
