#31 | |||
335 S/C GT: The new KING of Australian made performance cars.. ![]() |
#32 | |||
i guess DSC will not be able to be retrofitted if it is released with Mkii. I would be willing to pay to have this fitted on my f6. |
#33 | |||
I still have both eyes
hp (DIN) DIN horsepower is the power measured according to the German standard DIN 70020. It is measured at the flywheel, and is in practical terms equivalent to the SAE net figure. Because the test conditions are so similar, it is safe to divide DIN horsepower by 1.0139 to arrive at SAE net. This value is so close to equal that for all but the most technical purposes DIN and SAE net are interchangeable. hp (ECE) ECE R24 is another standard for measuring net horsepower. It is quite similar to the DIN 70020 standard, but the requirement for connecting an engine's fan during testing varies. ECE is seen as slightly more liberal than DIN, and ECE figures tend to be slightly higher than DIN. Therefore: 297KW (SAE) = 301KW (DIN) NOT 305KW !!!!!!!!!!!!!!!! 297KW (ECE) greater than 297KW DIN (see bolded bit in last paragraph). The upshot is that DIN appears to be a better standard and now allows direct comparision between Ford and Holden. That said Holden now use ECE figures so why are HSV using DIN? |
#34 | |||
HSV themselves directly quoted VZ @ 297kw or 305KW DIN, so which of those 2 figures is accurate?
#35 | |||
Location: I live in my own little world, but it's alright, the people know me here
MOTOR magazine managed to get a 4.99 0-100km from the GTO.
Man who walks through plane door sideways is going to Bangkok. |
#36 | |||
7,753
When the subject is a manufacturer’s product the only reference of note is what they claim to be fact. If you can get HSV to print a retraction then you have a story to tell, until then we will continue to quote manufacturer specs as they have been quoted to us. That being said the only language we are interested in is real world times, and I suspect HSV will deliver because they appear to spend greater effort trying to achieve these benchmarks. On your other point I am with you. Something about this doesn’t sound right given what has been printed in the media and used by Holden. I am still sceptical about what they are using.
BREAKING NEWS: The Pity Train has just derailed at the intersection of "Suck It Up & Move On" after it crashed into "We All Have Problems" before coming to a complete stop at "Get the Hell Over It." Reporting LIVE from Quitchur Bitchin' Last edited by HSE2; 23-08-2006 at 04:25 PM. |
#37 | ||
Purveyor of filth
Pfflt! HSV.
What about all the stock 'phoons coming out of Broadmeadows being able to peel of sub-13sec times with the ZF auto? |
#38 | |||
#39 | |||
Purveyor of filth
#40 | |||
Secret Sleuth
#41 | ||
1/4 mile times and 0-100 times can be frustratingly inacurate at times, HSV have been big at making claims that no one else seems to be able to reproduce in the real world, id say their times come from sticky tracks with perfect air temp etc etc.. FPV are vague and concervative on theirs.
The only real meaningful numbers come from back to back tests where the cars are compared on the same track, same weather conditions, same drivers etc, these figures are more meaningful than manufacturers "best possible effort on a sticky track in perfect weather conditions" times....
#42 | ||
Holdens Fall Apart!
it`s a commodore who cares
AU2 XR8, Venom Red, 200kw, K&N Panel Filter, 2.5" Lukey Exhaust
#43 | ||
Foo Fighter
I can see FPV sticking with the 290 and not changing anything in terms of power.
#44 | ||
Guys, the sub 5 second 0-100 may or may not be proven in real world tests.
However, given Motor (using their own gear, at lang lang) peeled of a 5.36 in damp conditions in a SS. Its not a big stretch to see HSV take off 0.36 seconds given: 1/ a dry well surfaced (sticky drag strip) track 2/ lower diff ratios than SS 3/ more power and more torque than SS 4/ DSC which, while not launch control, is tuned to allow aggressive take offs by letting some wheel spin occur but balancing traction and power application. 5/ a strong desire to lay claim to being a member of "the elite 4 second club". 6/ decent suspension allowing better power down. We will know soon enough, everybody will be trying to prove the times. Don't be surprised to see them not just equaled but bettered. Otherwise HSV will take a lot of s**t in the media. |
#45 | |||
#46 | ||
I am currently doubting the MRC system. I mean sure Ferrari managed to work it for the 599 and Audi have got it in there TT, but they aren't exactly high performance sedans. They might brag about it being in a corvette, but thats only in the base ls2 model, why not in the z06 if it was that great and as i've stated for awhile the STS-V went to monotube shockers after they found the Magna-ride system could not be developed to a satisfactory level for there high performance sedan, although that was released in 2004. Also the upcoming RS6 might not have the magna-ride suspension implemented either, if you read around the right forums. If HSV have mastered the Magna-ride system, congratulations to them, they have done a world-first for a high performance sedan. However i think theres also a chance of an underdone system being released for namesake. It was great how they included the RS4 in there Australia vs Germany advertisement and put "NO" to the MRC system, obviously ignoring that the RS4 has its own DRC system(Dynamic Ride Control), not the same system, but an adaptive suspension none the less.
Does anyone else think this is the biggest load of crap that Holden and HSV have decided to release 0-100kmh times, yet havent coped anything for it. I mean the Typhoon coped flak before it was even released for having an additional 30nm of torque over the GT. Holden using the excuse that they had to release them because the times were so great is an unacceptable excuse. |
#47 | |||
7,753
Wheels have basically said MRC is impressive with the short drive impression of a senator mule
BREAKING NEWS: The Pity Train has just derailed at the intersection of "Suck It Up & Move On" after it crashed into "We All Have Problems" before coming to a complete stop at "Get the Hell Over It." Reporting LIVE from Quitchur Bitchin' |
#48 | ||
7,753
After reading much of the wheels articles on VE V8s it’s clear that Ford have a problem with the Boss engine. The Holden six appears vulnerable but the opinion on the Holden V8 is very clear. With the HSV V8 they claim that even more air has been put between it and the FPV GT more then the 10 kw gain would indicate.
The bottom line seems to indicate VE HSV is something FPV should be very concerned about.
#49 | ||
Heres the drive video of them testing the Senator. They spend some time on MRC.
http://media.drive.com.au/?rid=21221...3&flash=1&ie=1 |
#50 | |||
#51 | |||
Clevo Mafia Inc.
![]() Join Date: Dec 2004
Who said anything about higher output for the Force 6/8 ? |
#52 | ||
I am very skeptical about the advertised outputs.
#53 | |||
It seems nobody knows for sure what these Force 6/8 cars will be. |
#54 | |||
7,753
Adaptive suspension is probably one of the last remaining obstacles that separate these cars from the rest of the world. This route should have been obvious as soon as HSV started playing with Ohlins. FPV haven't offered the basic adjustable set up so its hard to imagine it being on their radar and given the other areas they have fallen behind in, and the fact they have to build their own engine I doubt there is a budget for it. HSV still have to convince their buyers this direction is worth it. According to the reviewer switching modes does provide a difference in ride handling and steering quality. That’s half the battle won. If you can demonstrate it to be different the better part can be argued another day. The MRC has been at the expense of some other technical advances that I was led to believe would be in E series. Although they now appear to be suggesting that the grange will have further advances, so I guess time will tell.
#55 | |||
But there is an embago. |
#56 | |||
Clevo Mafia Inc.
#57 | |||
#58 | |||
7,753
#59 | ||
7,753
I just read on the LS1 forum where Tuna dynoed a Ve SS to have 230 rwkws. Didn't see if that was a manual or an auto but I think we all know what that translates to.
#60 | |||
Thread Tools | |
Display Modes | |
