25-03-2005, 02:41 PM | #1 | ||
Rollin
Hey all
This will give you digital readings for your speed in mph, the amount of fuel left in miles to go, your revs in digital form, your engine temperature plus more. NOTE!!!!!This process will not harm your car in any way you just loose your current odometer reading. Functions Gage Test Dial Test Bulb Test N/A N/A Clock Type (shows “date 44” if UK) Un Speed MPH Speed KPH Revs Fuel Engine Type Temp of Engine Battery Voltage N/A LCD Display (17-30 N/A) now i had a quick play but its quite over rated and you have to do it every time you start the car. what you do is have the car turned off push in the odometer trip button for 10 secs then keep it held down and start teh car and dont let go till you see the word test come up then you can let go and press the button to cycle through the different things |
25-03-2005, 03:00 PM | #2 | ||
Clio 182 CUP!
how did you figure that? ill be trying it out to see how it works. Sounds good
------------- Steven 'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04) |
25-03-2005, 03:05 PM | #3 | ||
Rollin
people in the uk try and sell it on e bay but was posted in UKFeznetwork
its what ford use when they service the car it tests bulbs guages etc |
25-03-2005, 03:13 PM | #4 | ||
Clio 182 CUP!
Awesome... im gonna try it forsure
25-03-2005, 04:47 PM | #5 | ||
What model is this on I have a fiesta LX 5 door
25-03-2005, 05:24 PM | #6 | ||
Rollin
mk6 any model
25-03-2005, 06:35 PM | #7 | ||
Tricolore Tard
Yeah its the same process as it is for the focus models
Pointless as it doesnt stay like that when you turn the car off and you lose the odo reading which i use a heap Pity its not like the E series ones which at least keep the current odo reading Chris
18-04-2005, 10:33 PM | #8 | ||
do you lose the odo or tripmeter readings. I thought odo readings weren't allowed to be altered by law?
19-04-2005, 05:57 PM | #9 | ||
GT4.
Obviously the tripmeter reading....
Deja vu big time for me, as I used to constantly use it in the EF so i knew how much (or mostly how less) fuel i had to play with before it ran out... -Dan |
19-04-2005, 06:10 PM | #10 | ||
Yeah, i used to do that on the EF alot too.
19-04-2005, 07:27 PM | #11 | ||
Fiesta Zetec
So it is ok to drive around like this and it will not have any adverse effects on the car??
There is some handy stuff available there |
