30-05-2005, 07:09 PM | #1 | |||
When I set the AC fan speed to 3 in my EF the fans surge/stop working periodically (like every 10-15 seconds). I think it will just be a dirty contact or something simple, just wondering if anyone could pin point the cause for me before I pull the dash apart.
cheers Mark
30-05-2005, 07:42 PM | #2 | ||
Hmmm Gold!!!
man thats freeky...... mines just started doing that too.... lucky im not going to need it coming into winter. pretty sure it would just be a dirty contact
bender
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber :, EL XR8 Sway Bars, NGK Iridium Plugs, New Trip Comp, Pacemaker 4480, 2.5 system 4L ED engine with surecam Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
30-05-2005, 08:45 PM | #3 | ||
V8 Powaah
Yeh mine did that but it's fixed now.
Took it to an auto electrician, turned out it was a faulty fan speed resistor. You can either take it out or put a new one in *No need to pull dash apart, it's near the Air con intake in Passenger footwell
FG G6E Turbo- Seduce & Cashmere - Sold XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
30-05-2005, 09:14 PM | #4 | |||
ahh, just the kind of info I was hoping for. Thanks for that - you might have just saved me a lot of time
30-05-2005, 09:15 PM | #5 | ||
02/90 EA II Fairmont
mines done that for ages... doesnt do it on 1,2 or 4... just 3
so i just avoid it lol
211RWKW EA |
30-05-2005, 09:24 PM | #6 | ||
V8 Powaah
Yeah, if you got a Gregories manual it's all in there, pretty easy job.
Anyhow this is whats in the Gregories Manual 1. Remove the Glovebox Compartment 2. Disconnect & remove fan wiring connector from mountin bracket 3. Remove screw and withdraw the bracket plate 4. Disconnect wiring connector and remove the retaing screws from Resistor 5 Remove resistor from housing DONE
30-05-2005, 09:26 PM | #7 | |||
That is what I have been doing - but 2 is not enough and 4 is to much. One of those little things that is really ****ing me off!
Edit: Thanks fairlane
30-05-2005, 09:33 PM | #8 | ||
V8 Powaah
Yeah, # 2 sucks it just aint enough air and #4 is too bloody noisy. lol
30-05-2005, 09:52 PM | #9 | |||
ok, I guess this is what I was after
30-05-2005, 10:34 PM | #10 | ||
Hmmm Gold!!!
haha love all the crap in it...
if hate to see mine, parked outside under a tree 24/7, might pull it out on the weekend...
30-05-2005, 11:08 PM | #11 | |||
and there is plenty more crap in the box!
I cleaned out the leaves and hooked it back up. Now I can see little arcs comming from where the coils crimp onto the terminals each time the fan slows down. I reacon all they need is a clean up and little solder to fix up the connections and shell be good to go.
31-05-2005, 07:29 AM | #12 | ||||
Redhead extraordinaire...
Bindi 88 EA- his car 88 Rolla - MY car Quote:
31-05-2005, 09:10 AM | #13 | ||
The 'Stihl' Man
haha this is weird.
My fan is crazy, Ill leave it on 3 and it will work for about 2 mins, then stop, then start for 15 seconds and stop again. If Im lucky it will start up by itself but usually I have to switch it to 2 or 4. And your right 4 is to much! I thought this was just an EA thing to because my last one did the same thing. And to make it worse the vents barely work at eye level, the screen demister is fine and the ones at my feet just work. I really need to get it fixed :(
31-05-2005, 11:06 AM | #14 | |||
Low and Loud
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
31-05-2005, 07:32 PM | #15 | ||
4 is fine i just turn up the tunes to suit
211RWKW EA |
31-05-2005, 09:56 PM | #16 | ||
GT
what a co incidence my el has just started doing this as well about 2 weeks ago . had no idea what could be causing it . there ya go
