Old 30-04-2008, 08:01 AM   #1
Sterling
Default starter motor wiring up correct?
my starter motor is the bosch pre engaged.... ive ordered it and it shoudl arrive soon, now
the big contact on the solenoid obviously goes to the big red wire.
there are 2 other wires, one is to engage the solenoid, the other does nothing i can see.
i was told to run one of those to the negative side of the coil, and what about the solenoid engagment wire, can that just be connected to the big red lead?
(using a jumper cable and a battery, i tested them, touch wire on the right to POSITIVE and main contact to POSITIVE while a ground is connected, the starter motor engages and spins up, when i connect to the other wire (as far as i can remember) did nothing...)
and help or opinions??
Sterling is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2008, 06:12 PM   #2
greenmk2
75 MK2 2 Door
greenmk2's Avatar
Smile
get a test light. there should be a wire down around the starter area when you hit the ignition key to start position it should light up.
- FG MK1 G6ET - weekender
- Escort MK2 - Weekender
http://i76.photobucket.com/albums/j5...zaicos/Z-1.jpg
greenmk2 is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2008, 07:01 PM   #3
Sterling
i origonally had the 1600 engine with the inertia starter, so theres only one wire, the red one, what about the other 2 wires on the solenoid of the 2 litre starter?
Old 01-05-2008, 09:45 AM   #4
greenmk2
75 MK2 2 Door
greenmk2's Avatar
Thumbs up
Just test the starter with the jumper leads like you did before and the small terminal that makes the starter engage and turn over hook that up to that red wire. dont worry to much about the other wires for now..
Those other two terminals one is for boosting the coil with 12v on start up and the other is for auto trans solanoid...
You wont have to hook up that wire to coil if you have electronic ignition though. I just got magna dizzy and swaped the guts over cost me $15. Both escort dizzys and magna dizzys are both made by bosch so their identical inside..
Old 01-05-2008, 04:51 PM   #5
Sterling
yeh cool man ill see how i go
Old 12-05-2008, 09:25 PM   #6
Sterling
when u sed "other 2 terminals" do they both do the same thing? cuz how do i know what to connect the boost coil wire to?
(on the solenoid, AND + or - of the coil?)
Old 14-05-2008, 06:44 PM   #7
Sterling
come on, somebody has to know this
Old 14-05-2008, 07:18 PM   #8
mopog
on ya solenoid you will have linked big red wire (battery positive) to smaller terminal. this should only leave one terminal not used, as greenmk2 said it is a 12v output when cranking the car this will go to the positive of your coil(hooking to coil negative will burn out your points). as said earlier if your running electronic ign you wont require this wire. the piont for this output is to provide 12v to the coil only when cranking this gives more spark hence easier starting, commonly called the easy start terminal.
mopog is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2008, 06:13 PM   #9
Sterling
sorry, my car is in my barn so i only get to see it for about an hour after work...
ok thanks i was mistaken i thought there was one more contact
