Early Falcon Car Club of Qld Inc The Queensland early model Falcon Club. |
14-08-2008, 12:57 AM | #1 | ||
Hey ford fans. I just bought myself a xc falcon sedan and it is currently a column shift auto and i want to convert it to a floorshift manual and was wondering whats the go with it whether its hard or simple or whether it costs alot or its a real cheap process. Anyone out there with the answers i would appreciate it greatly. Cheers
14-08-2008, 07:41 PM | #2 | ||
If you are mechanically handy it is not to hard to do.
Cost will depend on 6 or 8, 6 would be relitively cheap, V8 dearer. You need pedal box (clutch and brake pedal), master and slave cylinders and line Sandwich plate, bellhousing, flywheel, clutch, gearbox single rail-cheap or toploader dearer speedo cable. You will also need to fit a spigot bearing in the rear of the crankshaft The original cross member and gearbox mount will interchange, the tailshaft will also interchange. The original speedo cable will fit but it is to long and is untidy. hope this helps
Territory black VSI lpg XW GS Fairmont 351C toploader 9inch Mazda Bravo 4 X 4 |
