Old 22-08-2005, 06:25 PM   #1
Kaddis
Kaddis Customs
Kaddis's Avatar
Default ED XR6 Diff Center Into EF GLi Diff
just wondering if a ED XR6 Diff center would fit into a EF GLi diff??because i curruntly have a gli diff because my old diff packed up and i can get a LSD center out of an ED XR6.
i thought i remember reading that the GLi and XR diff's were the same except for the centers??
FG XR6 E-Gas Ute in Ego
Kaddis is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 07:37 PM   #2
niko
likes falcon's
niko's Avatar
u will have a 3.45 single spinner if u do that?
www.carhubsales.com.au
niko is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 08:05 PM   #3
Kaddis
Kaddis Customs
Kaddis's Avatar
you sure? i thought if you change the center it will be LSD because its all the center that makes in between single or LSD
so confused!
Old 22-08-2005, 08:08 PM   #4
EFFalcon
Last warning
EFFalcon's Avatar
if u change the complete centre then yes, it'll be LSD.
they're both 28spline, so the axels will be fine.
the tail shaft will bolt upto it.
i'm sure someone else would know more about it.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 22-08-2005, 08:31 PM   #5
sphell
sphell's Avatar
it will bolt straight in. You will also have to change the pinion gear though. Just make sure you use the shims that were in the GLi diff and don't swap them left to right either. However you pull it out, put it all back the same way and ONLY swap the center and the pinion gear. And yes it will be LSD.
sphell is offline   Reply With Quote Multi-Quote with this Post
