Old 20-09-2005, 09:10 PM   #1
smudgerino
Default EA Rocker Cover
I've managed to crack the rocker cover on my EA Wagon (3.9 CFI). Ford don't make the part any more, so it looks like I need to get one from a wrecker.
Do you know of any later models with the same shape rocker cover, or am I restricted to only getting a replacement from an EA?
I'd like to get a newer one if I can, maybe a different colour to the broken silver one I have got now....I've seen red and blue covers, what do they come off?
smudgerino is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2005, 09:14 PM   #2
neb
hibernating
neb's Avatar
You can fit ea to ed without any problems. ef and el you can also fit but it has a different gasket and may leak a bit around the half moon shapes
neb is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2005, 10:29 PM   #3
spope
spope's Avatar
Red covers came on XR6 models, blue covers have most likely been painted by people. Like me. I have an EF rocker cover on my EA, painted blue.
EF-EL rocker covers fit no problem, just put a bit of silicon in the half moons before you bolt it on.
spope is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2005, 10:53 PM   #4
smudgerino
What model followed the EA? You mentioned 3 models, the EL, ED and EF, which is the youngest car? I don't know in which order the cars were released after the EA.
Do you know if I will be able to pick up a new rocker cover for any of the above models, or will it be a scrap yard job?
Thanks
Old 20-09-2005, 11:09 PM   #5
spope
spope's Avatar
EA, EB, ED, EF, EL
You'll probably still be able to get an ED or EF cover new - but it'll be expensive. They are usually about $20 from self serve wreckers.
Old 21-09-2005, 03:16 PM   #6
JUZXR8
Hmmmmm
JUZXR8's Avatar
what is the sort of paint you would use to colour a rocker cover?
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2005, 03:18 PM   #7
BlackLS
Posts: n/a
Hi-temp engine and brake caliper paint. BTW how did you manage to crack the rocker cover
Old 21-09-2005, 03:23 PM   #8
EA2BA
PM me if you want
EA2BA's Avatar
My guess over tightening the nuts that hold the rocker cover down, you either crack the rocker cover or crack/break a pedastal mount point.
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2005, 04:37 PM   #9
XR Martin
XR Martin's Avatar
Factory EBII and ED rocker covers were blue.
2004 BA wagon RTV project.
Old 21-09-2005, 10:58 PM   #10
smudgerino
Thanks for the replies....
Yeah I stupidly overtighted the nuts on the rocker cover...as I did the thing made a loud cracking sound, more like a pop actually...I've now got an oil leak coming from the cover. I'm going to have to check now to see if I've damaged a pedastal mount point like you said. If I have managed to damage one, how can that be fixed? Where do they fix to? Are they on the cylinder head?
Old 21-09-2005, 11:42 PM   #11
The MaDDeSTMaN
No longer driving a Ford.
The MaDDeSTMaN's Avatar
Where are you mate? We've got a rocker cover here that LuvinmyEB might be willing to sell cheap if you want it...
Originally Posted by russellw
For those who get their jollies attacking other people let me remind you that we will not tolerate this here. If you want to do that then I am sure your presence would be welcomed elsewhere.
The MaDDeSTMaN is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2005, 12:00 AM   #12
smudgerino
Northern Beaches Sydney...I will go to the wreckers this weekend to see what I can pick up.
So does anyone know where the pedistal mounts are fixed? Cylinder head? engine block? Cam Assembley?
Old 23-09-2005, 06:13 AM   #13
Rmyers
Does Steve have a car?
Rmyers's Avatar
Pedestal mounts are part of the rocker assembly and bolt to the top of the cylinder head. You will need to unbolt the entire rocker assembly to change a pedestal (i think it's about 24 bolts or so)...
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2005, 09:14 AM   #14
EA2BA
PM me if you want
EA2BA's Avatar
I thought 28 for the rocker gear
Old 23-09-2005, 06:53 PM   #15
JUZXR8
Hmmmmm
JUZXR8's Avatar
if you take the rocker cover off, do you need a new gasket or silicone for when you want to put it back on?
Old 23-09-2005, 07:01 PM   #16
spope
spope's Avatar
28 bolts - each one needing to be tightened at least twice.
Juz Gremlin - depends on what condition your old gasket is in. If your old one is hard or brittle, ditch it and get a new one. ED if you are fitting EA-ED rocker cover, EF if you are fitting EF or EL rocker cover. EF gasket is a funky silicon-y type of gasket, that sits inside a rim of the rocker cover. With ef, you will also need some silicon in each half moon - else you will get leaks.
Old 23-09-2005, 07:04 PM   #17
JUZXR8
Hmmmmm
JUZXR8's Avatar
noice, thanks mate
where can i pick one up from.....just at a Ford dealer, or a repco etc?
Old 23-09-2005, 07:19 PM   #18
Jason[98.EL]
Jason[98.EL]'s Avatar
you can pick gaskets up for the rocker cover from any reputable spare parts place
no longer have a ford but a ford man at heart
R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN
[SIGPIC][/SIGPIC]
Jason[98.EL] is offline   Reply With Quote Multi-Quote with this Post
