Old 06-06-2012, 07:19 PM   #1
muzzy
muzzy's Avatar
Default Gauges in RS 20000
HI Guys getting Ready to fire my RS for the first time
Where should the temp gauge run?, and same for the Oil pressure gauge
RS2000 5 speed
Twin 44idf webers + other goodies
muzzy is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2012, 10:29 PM   #2
RSgerry
Well hello Mr Fancypants
RSgerry's Avatar
Default Re: Gauges in RS 20000
Hi Muzzy, I wouldnt put a lot of faith in the gauges at all. Both of these dont work in my car and I have installed VDO gauges instead in the ashtray slot. Also, my fuel gauge goes up and down by 1/4 tank depending if I am accelerating or braking. Sometimes it just stops. Temp in mine is about 80 degrees IIRC and oil is about 55psi.
1965 Ford Anglia
1980 Ford Escort RS2000
2006 Mazda SP23
2012 Ford Focus ST
RSgerry is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2012, 06:29 AM   #3
whooligan
whooligan's Avatar
Temperature Gauge tends to run high and oil line usually always leaks (into the dash) this is all too common with RS2000 dashes. Probably why they tend to sell high on eBay. Took 3 dashes to get mine right when I bought my car and ripped out all the aftermarket crap.
I guess it's par for course with RS2000 owner ship....don't expect the gauges to work!!!! Just know your car, check it regularly and trust your instincts when it doesn't seem to be running right.
whooligan is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2012, 05:50 PM   #4
muzzy
muzzy's Avatar
I started the engine for about 5 mins before I stripped it down, early last year, what I was wanting to know where should the gauge run IE 1/2 way for temp and 3/4 for oil??
I have recalabrated the fuel sender unit so that should be correct, the tacho has been aslo recalabrated ( long way out from the factory)
RS2000 5 speed
Old 03-07-2012, 07:34 PM   #5
muzzy
muzzy's Avatar
Engine runs sweet( very deep sound with twin IDF's)
I have set the fans to turn on at the upper white line ( this is 90 degrees) therefore running temp is about 1/2 way beteen 2 white lines
RS2000 5 speed
Old 12-07-2012, 10:33 AM   #6
shepv8
V8's for ever
Hey mate, where did you get your tacho and fuel gauge recalibrated at. Im interested in doing the same
shepv8 is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2012, 05:55 PM   #7
muzzy
muzzy's Avatar
The tacho I sent away to an instrument repairer in Sydney, the fuel tank unit I did it myself using a multimeter , ruler, and pliers to re bend the arm
RS2000 5 speed
