Old 13-08-2012, 10:33 PM   #1
79FordEsky
79FordEsky's Avatar
Default Air Compressor Help
Hey just wanted to see if anybody knows if you can get a 3 phase 15amp air compressor motor changed to a 1 phase 10amp.
The help would be much appreciated.
My Ride: -
My Survivor 1 owner XC Wagon
Check it Out
79FordEsky is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2012, 10:44 PM   #2
cs123
cs123's Avatar
Default Re: Air Compressor Help
I probably wouldn't. The motor is rated to drive the compressor pump and if you go too small you risk damaging the motor.
The only exception is if the motor is over rated for the work being performed.
What is the compressor? CFM etc.
I love Holdens....
cs123 is online now   Reply With Quote Multi-Quote with this Post
Old 13-08-2012, 10:52 PM   #3
pcman
ebay the whole thing and buy a single phase unit is the best option
pcman is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2012, 10:59 PM   #4
79FordEsky
79FordEsky's Avatar
Ok well the compressor is 14 CFM bit under powered I am looking at my options at the moment. What would you suggest for doing painting and tool work.
My Ride: -
Check it Out
Old 13-08-2012, 11:08 PM   #5
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
minimum 17cfm 3hp 240v
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2012, 11:18 PM   #6
79FordEsky
79FordEsky's Avatar
http://www.ebay.com.au/itm/Honda-Pet...#ht_822wt_1265
My Ride: -
Check it Out
Old 13-08-2012, 11:24 PM   #7
my67xr
my67xr's Avatar
thats fairly old?
the pump doesnt look very tall, im guessing it's a 12cfm.
ask the seller, it should say the cfm on the black plate on the pump
keep in mind,if it's old it might need rings/bearings etc in both the motor and pump
67 XR Fairmont
Old 14-08-2012, 10:42 AM   #8
poppa smurf
poppa smurf's Avatar
3 options on your compressor......
get a motor wiring specialist to convert the existing motor to single phase (may lose too much power in the transition) I've had this done a few times on heavy machinery using a couple of Adelaide specialists with varying results
buy a 2 horse electric motor and mount in place of the 3 phase......my main suggestion
go petrol, good cheap Chinese motors are plentiful
G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II...
may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon!
poppa smurf is offline   Reply With Quote Multi-Quote with this Post
