19-12-2005, 09:51 PM | #1 | ||
Hey guys, tonight i was looking at how i can install my head unit. I removed the ash tray and took the left hand side screw out. But the frame work around the Tape Deck wont budge. There's something holding it in from the right hand side, and i don't know what.
Any help would be great! Thanks Paul |
19-12-2005, 09:55 PM | #2 | ||
Last warning
its a clip.
you'll need to force it.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
19-12-2005, 09:58 PM | #3 | |||
lol - im sure I answered this exact same question last week.
Just take the screw out, then pull.
19-12-2005, 10:04 PM | #4 | ||
Thanks Guys! I'll give it a shot in the morning, i didn't want to force it without knowing it was the right thing to do.
19-12-2005, 10:09 PM | #5 | |||
19-12-2005, 10:13 PM | #6 | ||
As the others have said, there is a clip that takes some force to release. Also, you will need a security Torx bit to remove the HU once the surround is out of the way.
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
19-12-2005, 10:16 PM | #7 | |||
19-12-2005, 10:32 PM | #8 | ||
[EBGLT]
That tork bit is to get the head unit out! They also get your door handles of too!
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
20-12-2005, 07:23 PM | #9 | ||
I finally work out how to remove the surrounds from around the head unit tonight, and now discover as mentioned above the old tape deck is locked in by some weird screws. Where can i buy, or what can i use to remove these??
Paul |
20-12-2005, 07:36 PM | #10 | ||
you could drill them out or use two very small flat heads to get them out. Super cheap the sell the torx bit sets cheap, might come in handy as you'll find those same screws o the door trims.
20-12-2005, 08:39 PM | #11 | ||
Just use a pair of needlenose pliers - did the trick for me.
20-12-2005, 09:09 PM | #12 | ||
- BOOYEH -
Dick Smith Electronics / Tandy, sell the complete sets as well, with a range of different sizes. They retail $20. Lots of other handy types as well.
http://dseau.resultspage.com/search....0&I1.y=0&I1=Go
1993 EBII Fairmont Turbo T04e 7 psi
20-12-2005, 09:14 PM | #13 | ||
Yeah i havent got the correct tools for the job, ill have to get a set tomorrow whilst im out getting my loom for the headunit.
20-12-2005, 09:26 PM | #14 | ||
- BOOYEH -
The correct tool should have the hollow centre, to accomadate the centre post of the screw. If your not fussed, try breaking the centre post out of the screw, or try the above methods ( multigrips, longnose pliers, small flathead screwdriver, vicegrips)
20-12-2005, 09:53 PM | #15 | ||
Its worth having a set of security Torx bits, Ford used Torx bits throughout the cars. Seatbelts, steering wheel, etc.
20-12-2005, 09:56 PM | #16 | ||
I guess the good thing about these security torx bits is its harder for ppl to steal parts of the car, because they come unprepared. But its a hastle when the owner wants to change things.
20-12-2005, 11:56 PM | #17 | ||
Ive also got some 6" rears to install, how did you connect the speaker wire to the speakers terminals, did you use a soldering iron and solder?
21-12-2005, 12:21 AM | #18 | ||
I used spade connectors connected via some good quality wire. Solder them together and plug the male end into the wiring plug in the boot and the female end into the speakers.
If you plan on creating some serious vibration, tape it up so it is nice and secure as well. Funny story: I was expermienting with adding a small touch of rice to my car and installed some LEDs in my speaker covers. Did a stupid thing and reconnected the speakers while the head unit was pumping. Accidentally touched the positive side of the speaker connection to the negative side of the LED's (which were earthed to the speaker, little did I know) and blew the head unit! Been driving around for almost a week with no sound! So now I have to decide: Do I upgrade my JVC head unit or do I buy an amp? *Gets out wallet* |
21-12-2005, 12:23 AM | #19 | ||
likes falcon's
u can if u want, connectors or just tape is easy way out
www.carhubsales.com.au |
21-12-2005, 08:32 AM | #20 | ||
I bought myself the 41 piece set (includes torx fittings), from Dick smith, which is in the link that Gubas posted up. I have been able to undo anything and everything now
Heritage Green EL Ghia Black AUII XR8 Ute |
