Old 19-10-2005, 09:10 PM   #1
ea_boss_05
Default plz help? amps
hey every body
can some one help me, i am looking in two getting 2 12 inch pioneer subs but im not sure what amps to use,both subs on a 4 channel or 2 mono block for each sub. it confusses the hell out of me, lol
thanks alot guys
ea_boss_05 is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2005, 11:00 PM   #2
efgiar
rofl copter
efgiar's Avatar
i would go for 2 x 2 channel amps, and bridge them, better then a mono block IMO and 1 amp wouldnt power the 2 subs proply unless you spend a crap load of money on 1 amp, go and get 2 response amps, they are like bridged 500watts rms and the old man has one in his car, goes awesome
GQ patrol.
thats all
Old 20-10-2005, 02:11 PM   #3
MickyB
Get in the ring!!!
MickyB's Avatar
You can use a monoblock amp and wire the subs in parallel so that they are both acting as one speaker. Normally you cannot do this on an amp because they will overheat, but specilised monoblock amps can do this easily.
FG MKII XR6T - Tuned by Pit Lane
MickyB is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2005, 02:26 PM   #4
BlackLS
Posts: n/a
You would need at least 1500 watts. Go to Strathfield car radios, tell them that your mate Habib sent you to them and they could do you a good deal on a BOSS amp...
And yes I am not serious...
Old 20-10-2005, 02:37 PM   #5
nang3
nang3's Avatar
yeh just get yourself a nice monoblock Class D amp...
Crossfire BMF1000D or similar would do the trick !!
i had a crossfire pushing a 1ohm load for about a year, cranked pretty much everyday and no probs, very reliable !
nang3 is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2005, 02:37 PM   #6
niko
likes falcon's
niko's Avatar
im running the older black 2 channel response amp, great sound. and cheap
www.carhubsales.com.au
niko is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2005, 03:02 PM   #7
BoZZa17
Lovin the Manual.
BoZZa17's Avatar
how about someone asking what power the speakers can take?
are the speakers dual voice coil?
and if so what is the impedience of each coil??
give me some infoa nd i can tell ya a decent amp to get.
ta
BoZZa17 is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2005, 08:18 PM   #8
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
I had in my car a coustic 600se pumping 2 x Alpine 12" R series 4+4 ohm subs, that pumped hard but apparently it was configured at only 150 watts per sub
Now thats in the cupboard and I updated to an Alpine MRD-501 amp pumping 2 x Alpine 12" S Series 2+2 ohm subs, the bass is clearer and more responsive and apparently its now at 275 watts per sub NOW thats much better
I have purchased recently another MRD-501 amp so I can run 1 amp per sub but have to go back to 4+4 ohm as you cant configure a single 2+2 ohm sub to run of one Alpine MRD501
In saying this make sure you match the subs to the amp, dont just go out there and buy the cheapest bargain as you may not be able to configure it to run at the maximum power.
Eg 1 x 4+4ohm Sub = 1 x class d which will run at max power
and 2 x 2+2ohm Subs = 1 x class d which will run at max power
FYI Class D are 1 channel amps
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2006, 10:35 AM   #9
foxtrot
Blood, sweat & tears
foxtrot's Avatar
FYI Class D is not a 1 channel amp (Yes this is an old post but i was looking for info on re-wiring front door speakers and found this thread)
"Class D amplifiers ("D" does not stand for "digital") boast higher efficiency, produce less heat, and draw less current than traditional Class AB designs, but they tend to have more distortion. Since low-frequency distortion is almost impossible to detect, compact Class D amps rule the bass kingdom."
and there is the correct info!
foxtrot is offline   Reply With Quote Multi-Quote with this Post
