Old 19-12-2013, 09:23 PM   #1
supershifty
Missing a sock...
supershifty's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Dave has been a long time active member on the forums and in particular has been a busy volunteer whenever there are cruises and toys runs etc held in South East Qld. He actively gives up his time and ensures that the events are provided for, be it commun
Question When to re-torque cyl head/drop oil after initial run in?
Hi all, need your learned advice before Saturday. I and Ansith have recently put a fresh xflow six in his XC.
It's done about 300km as of today. Anisth leaves on a road trip from Brisbane to Melbourne in 3 days time returning in about two weeks.
I normally wait until a fresh engine has done 1000+ km's before I drop the oil/filter and re-torque the cyl head bolts. This has been my practice for 30 years. Ansith won't reach 1000k's before he leaves. We filled the sump with Penrite 15w40 (non synthetic) and the recommended run in supplement as recommended by the cam manufacturer. I've recommended that Ansith run Penrite HPR30 (again, non synthetic) after the initial oil change.
Please don't turn this into a debate about oil brands, but oil grades would be welcomed. Yes, I've stated the brand I prefer and have trusted since I was 16 - just saying!
My real dilemma is: do I re-torque the head with low k's or leave it until he comes back? We used a Permaseal brand of head gasket. What do you guys think?
Appreciate your replies. Thanks and cheers!
Real friends + great times = sheer bliss!
Considering becoming an organ donor? Click here
QLD Events, Cruises and Get Togethers: Click here
Gain success instantly - lower your standards.
It's not government funded - it's taxpayer funded.
supershifty is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2013, 09:34 PM   #2
superyob
Default Re: When to re-torque cyl head/drop oil after initial run in?
I have not re-torqued cylinder head bolts since the late 80s (possibly). There is no need with modern mono torque type head gaskets...
superyob is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2013, 09:38 PM   #3
cs123
cs123's Avatar
What sort of oil pressure do you have now Dave?
I'd do the oil and filter. Run HPR30. Re-torque the head when he returns. I'd also change the coolant too.
Load the boot up with some spare oil and 10 litres of water just in case.
It would be nice if anyone from Melbourne with a bit of experience can catch up with James and look the engine over when he is down there to make sure it's going well.
I love Holdens....
cs123 is online now   Reply With Quote Multi-Quote with this Post
Old 19-12-2013, 09:39 PM   #4
redxm
64 Deluxe 4 door
redxm's Avatar
I would - change the oil now. Put some more zinc supplement in and retorque after he comes home, if you feel the need. If the gasket surfaces were nice and straight and the threads in the block clean, I dont see the need to retorque. Thats my preferance, and practice for 20 years anyway.
I also use Hylomar on the gasket but.
Out of curiousity , Alloy or Iron head?
XM Deluxe
FG XR50
BA Pursuit Ute
redxm is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2013, 09:40 PM   #5
mik
mik's Avatar
In the xc days cylinder head was retightened at 1500 service, but I believe some of these permaseal gasgets don't need to be re torqued? personally I would re do them anyway, headbolt retorque on the x flow is a piece of cake........ don't forget to do the one with battery lead bolted to the front head bolt .
Old 19-12-2013, 09:43 PM   #6
GASWAGON
He should be fine for his 1000klm trip.......Re tension when he gets home.....Just don't use synthetic oil.....Mineral oil only for old engine.
GASWAGON is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2013, 10:06 PM   #7
supershifty
Missing a sock...
50psi oil pressure @ 2000 rpm with the 15w40 and the very liquid 500ml of run in supplement. This is with a standard volume Melling pump, more than adequate for a motor that doesn't have oiling problems. I can't recall offhand what the factory specs are - but I think they were 40psi when the relief valve kicked in.
Spare water is already in the boot. We'll drop the oil/filter and water/radiator sock on Saturday anyway - can't hurt, will change it again when/"if" Ansith gets back.
I really like the idea of not re-torqueing the head bolts before the trip. Snapping head bolts after the trip is a great idea!
Superyob, I can't trust "monotorque" type head gaskets - although with TTY (torque to yield bolts) I've had no problems from the EA Falcon onwards with the single torqueing.
Cheers!
Old 19-12-2013, 10:10 PM   #8
joolz
Normally after 1000 k's
joolz is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2013, 10:14 PM   #9
The Yeti
The Yeti's Avatar
I always retorque cylinder heads,mas I've had mono torque gaskets leak due to I believe them not being retorqued, personaly though I'd wait until he returns
As for the oil hmmm I'd probably change it before the trip and I always use HPR 30 any way
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2013, 10:35 PM   #10
supershifty
Missing a sock...
Iron head redxm, yep, I know alloys are more fussy.
The iron head was machined and the block was zero decked - all fresh and dry faces were used prior to the fitment of the head gasket.
This ride has has given us some grief, but I think it's coming to fruition now.
