Old 22-11-2015, 08:11 PM   #1
PIGNUTS
Default 302 W belt pulleys not lining up
Hi everyone,
I'm having issues with my Gilmer setup not lining up with each other. The motor had standard pulleys when I bought it, and now it seems that the alternator pulley leans forward more then the other 2 ? I'm not 100% sure if I am using the correct bits for it, as there is a spacer between the head and the alt bracket ? Hopefully you can see from the photo's what I'm talking about.
PIGNUTS is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2015, 08:39 PM   #2
66 coupe
around the place
66 coupe's Avatar
Default Re: 302 W belt pulleys not lining up
can you get a pic with the belt on.
if the belt sits on all three pulleys, the whole width of the belt then it will be fine
GPS Tracker for your vehicle - PM me for info
66 coupe is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2015, 08:50 PM   #3
PIGNUTS
It does seem to sit on well with all 3 pulleys, but I was concerned when it's running, I might have some issues.
Old 22-11-2015, 09:07 PM   #4
Xauterus
Are you using a straight edge on each pulley. They may appear lined up but if say the alternator is slightly crooked then you will have issues. Out of alignment and the belt will slide down the pulley.
Xauterus is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2015, 09:10 PM   #5
Express
Bathed In A Yellow Glow
Express's Avatar
With and without the belt the alternator appears to be leaning forward a bit.
Express is offline   Reply With Quote Multi-Quote with this Post
