Old 18-04-2016, 12:07 AM   #1
skipfx
Default OBDII cables
I have an obd2 to vga cable. Can i use a vga to usb adapter and use it like a normal obd2 to usb cable?
skipfx is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2016, 06:29 AM   #2
russellw
russellw's Avatar
Default Re: OBDII cables
I rather more suspect it is an OBD2 to Serial cable rather than VGA. If it is then yes although you may have to experiment with a couple of different Serial to USB adapters to find one that works.
A quick count of the pins will tell you - VGA has 15 and Serial has 9 (well it can have more but the other type doesn't look like a VGA).
If it is actually VGA then the answer is no.
Russ
Old 18-04-2016, 07:01 AM   #3
skipfx
Yes it is a 15 pin vga
Old 18-04-2016, 11:27 AM   #4
pcman
wouldn't it be better to spend 10bux on a usb-obd2 cable
obd2 to vga does not make sense, id guess its a non standard cable for a expensive scan tool
pcman is offline   Reply With Quote Multi-Quote with this Post
