Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Early Falcon Car Club of Qld Inc
Early Falcon Car Club of Qld Inc The Queensland early model Falcon Club.
Old 19-03-2008, 05:53 PM   #1
pioneerxf
Default XY light switch removal
Hi guys, I am having some trouble removing the pull type light switch on the dash of my XY. According to the manual, there should be a clip or button underneath/behind the dash which will allow the switch to be removed. However mine either doesn't exist or is completely encased by the dash itself.
If anyone has any ideas about this your help would be appreciated.
pioneerxf is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2008, 11:30 PM   #2
xwboss
xwboss's Avatar
Yes there is a spring loaded button on the outside of the headlight switch body, you hold this in and pull the knob and shaft out of the switch. its just a bit fiddly finding the button and the shaft should pull out easy, dont use to much force.
Then you need to unscrew the bezel with a large flat blade screw driver where the knob and shaft came out.
xwboss is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2008, 10:23 AM   #3
OLDFORDNUT
OLDFORDNUT's Avatar
first disconnect your battery,as you will most likely push some wires around under dash while removing the switch.
/////////when you put your hand up under dash you will feel the large part of head light switch body with your fingers,feel on top of it (big flat area)and in middle of this there is a small spring loaded button that will wobble around a little under your fingers just push it in and with your other hand pull the headlight switch knob straight back and out.
Hervey Bay QLD
Great trades recently- GILMORE
BOSSYONBIKE
OLDFORDNUT is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2017, 11:12 AM   #4
Billmeerkat
Default Re: XY light switch removal
Hi All could someone tell me how to put the headlight switch back together the centre slides back in but does not stay or activate anything
Billmeerkat is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2017, 01:47 PM   #5
Tassie f100
Sometimes you have to give the switch shaft a hard push to get it to click into place.Might go in easier if you reach up to the switch and push in the little spring loaded button in at the same time
Tassie f100 is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2017, 02:22 PM   #6
Billmeerkat
Thanks for that i will give it a try
