Old 24-03-2006, 10:14 PM   #1
ehbobeh
Default Aftermarket Cruise control on EL
Has anyone fitted an aftermarket cruise contro unit to an EL. Do they work well? Where can you get them cheap? Thanks, Bob
ehbobeh is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2006, 10:15 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
is there a reason why you don't wanna fit a factory setup?
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 24-03-2006, 10:27 PM   #3
InitialD
Low and Loud
InitialD's Avatar
If your not wanting to go factory, You can get a AP COMMAND cruise setup. They are around the $200 mark and work quite well. But for the same price you could go Factory.
Just whatever you do, MAKE SURE ITS ALL IN GOOD NICK IF 2nd hand! You dont want it to stuff up on you and you cannot stop if the driver is unexperienced ;)
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car
1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon :
InitialD is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2006, 09:45 AM   #4
ehbobeh
Thanks guys. Ididnt realise the prices are comparable. Where do you get a factory setup from?
Old 25-03-2006, 11:43 AM   #5
EFFalcon
Last warning
EFFalcon's Avatar
Wreckers would be the first place to try.
Does you car have ABS?
if the car has ABS, installing cruise is VERY easy.
if not, its a little more involved but still not bad.
Old 25-03-2006, 03:16 PM   #6
ehbobeh
Yes it has ABS, What is the difference?
Old 25-03-2006, 03:20 PM   #7
EFFalcon
Last warning
EFFalcon's Avatar
if the car has ABS then you already have all the wiring required to install cruise control.
What you need:
cruise control module (situated under drivers side bonnet hinge.
Cruise Control buttons to fit to the steering wheel
maybe the brake pressure switch on the master cylinder, i can't remember if thats fitted.
thats all that i can think of.
Old 25-03-2006, 08:03 PM   #8
2kool4u
Location: I live in my own little world, but it's alright, the people know me here
EF gli's have ABS standard don't they??
Man who walks through plane door sideways is going to Bangkok.
2kool4u is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2006, 08:29 PM   #9
ehbobeh
EFFalcon,
Thanks very much. Is all the wiring in place or does this need to purchased aswell? Off the topic but is the wiring already in place for a roadtrip meter? Anyone have the spare bits lying around? Thanks for your time!
Cheers, Bob
Old 25-03-2006, 08:32 PM   #10
LUXO_8
windsor user
if the car has ABS (which you said it has) it will have the cruise wiring in place already - it is the same loom...
you will just need to buy the parts EFFalcon and fit them.
