Old 06-05-2019, 12:59 AM   #1
TasFocus07
Default 2007 Focus LT brake reservoir access
Evening people,
Can some one enlighten me as to how one gains access to the top of the brake fluid reservoir please?
Seems a dumb design to have it hidden under the plastic scuttle cover.
Is there a trick to this?
Cheers,
Max Heazlewood
TasFocus07 is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2019, 06:46 AM   #2
marg99
Default Re: 2007 Focus LT brake reservoir access
the plastic shelf above the brake resevior is removable. It has a few press clips along the front and I think you remove wiper arms as well.
Old 06-05-2019, 10:48 AM   #3
TasFocus07
Thanks for your reply.
That sounds like a bit of a PIA!
I want to fit a pressure bleeder to do the whole system as I'm replacing rotors front and rear along with new pads front and rear.
Otherwise i will use my normal one man bleeder fitted with a non return valve.
I'm servicing this car for a friend and there is no record of when the fluid was changed.
