Old 25-09-2020, 10:32 PM   #721
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
Default Re: Mowing ..
Originally Posted by MITCHAY View Post
Well I put down some weed and feed a couple of weeks ago. I also used the manual aerator too.
I have heaps of green shoots coming through strong now but I did not remove the thatch
So do I cut it low with the mower and rake the **** out of the thatch or not? Is it worth doing with couch grass?
If you're going to do it nows the time. You've gone about it the right way, feed it and get it growing first before doing anything drastic, it'll recover much quicker.
A long term solution to thatch is to keep going with the aeration to get the soil bacteria working and let them compost it and turn it into fertilizer as a bi-product.
Mk1 GT Cortina Project.
FG XR50 Daily.
Old 28-09-2020, 06:05 PM   #722
I tried out the mulching function of the Bushranger for the first time today.
The finish was very good with no clumps left behind. I like that you can mulch with the catcher attached so the customer is none the wiser.
And I LOVE this Honda GXV160 engine. Along with it being smoother and quieter than Kohler it replaces, hitting some thick grass today, the Honda just grunted through it. I reckon Honda under quotes the power of these engines as it seems to have more power than the higher rated engines I have used in the past.
DFB FGXR6 is online now   Reply With Quote Multi-Quote with this Post
Old 28-09-2020, 10:06 PM   #723
Originally Posted by danzvtil View Post
I’ve put 4-5 hours of use on the HSA56, what a great piece of kit. It cuts twice as fast as my last hedge trimmer and twice as fine. Absolutely loves diosmas which my last one would chew up rather than cut.
Back at my clients house for the first time in 3 months, the entire family were glad to have me back as all the topiary had gone to hell. The lady of the house isn’t happy when the garden looks like crap, and if she isn’t happy, no one is
How has the Stihl battery gear been going for you?
Old 28-09-2020, 11:00 PM   #724
danzvtil
danzvtil's Avatar
No complaints, still powering thru it all, I’ve never run short of battery power with ak10 and ak30 batteries.
I’ve noticed the gearbox is a bit noisy on the handheld unit, I’m about to get some grease to see if it will hush, that’s what the internet tells me to do.
I am still yet to buy the pole extension, as this one won’t give the height of my old ozito telescopic.
As for the GXV, the bloke who sold it to me said it suffers from the Bunnings effect, they have some units that are 200cc, customers don’t get that the output gets the job done not the engine size.
And with how quiet it runs, every time I start it, I mistakenly reach for the throttle to increase revs even though it’s at max.
____________________
2024 TOYOTA HIACE
2019 LDV G10-GONE THANKFULLY
2009 Mitsubishi Express-GONE
2011 Honda Jazz
danzvtil is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2020, 11:05 PM   #725
I have found my HSA 56 to get a bit noisy after an extended run, let me know how you go with the grease.
Did you end up putting a full set of high lift blades on the Honda?
Old 28-09-2020, 11:12 PM   #726
danzvtil
danzvtil's Avatar
Not as yet, I may consider it when replacement time comes.
2024 TOYOTA HIACE
2011 Honda Jazz
Old 01-10-2020, 09:38 PM   #727
danzvtil
danzvtil's Avatar
Opened the gear box on the HSA56 today, there wasn’t much grease in it. Pulled it apart, it had some grit on the bearings, so cleaned it out and reapplied stihl multi lube (been looking for it all week, but they’re waiting on new stock).
All smooth and quiet now.
2024 TOYOTA HIACE
2011 Honda Jazz
Old 01-10-2020, 09:59 PM   #728
Interesting, will definitely be doing the same. Thanks for the feedback.
Old 05-10-2020, 06:40 PM   #729
Made a small modification to the Bushranger today, the result not as I expected though.
This mower doesn't have a raised pull starter on the handle, something that is a handy feature.
I picked up a used Masport attachment from my local mower shop.
Pulling the cord out to install, I instantly knew why this isn't a standard feature.
These Honda engines have quite a short pull cord meaning, when installed in the handle's allocated hole, it leaves only a limited amount of cranking ability. Enough to start the engine, but not enough for my liking. Looking at Honda mowers, this feature is fitted lower on the handle mitigating the problem I have encountered. I don't really want to be drilling holes in my brand new mower so I will see how it works on the job. At the end of the day, it didn't cost me anything so no big loss if I choose to punt it.
Old 05-10-2020, 06:52 PM   #730
I have had this for a while, and it's use is somewhat limited, but this little tool is helpful when finessing a hedge.
https://www.stihl.com.au/STIHL-Produ...en-Shears.aspx
I find this useful trimming along the bottom of a Buxus hedge, getting into corners or cutting where a larger tool would be cumbersome. The battery run time is more than sufficient for this type of work. I have also used it to shape topiary's and standard Lilly Pillies. The blade speed is pretty slow and it's use is limited to fine material but it's a handy addition to my arsenal.
Old 05-10-2020, 07:03 PM   #731
New addition today.
https://ecoorganicgarden.com.au/prod...4aAloKEALw_wcB
I have used this before but not in my own business. Made from plant oils, Slasher is a Registered Organic weed killer. Slasher is one of the few products that will kill Fleabane, a weed that takes off at this time of the year. It will also control moss and algae. I have seen this product take a weed out within hours.
Two drawbacks though. Slasher acts by burning the foliage, leaving the root system behind. On annual weeds this isn't a problem, other weeds are best treated with Glyphosate. And the smell of the products tends to linger for a couple of days in my experience.
Old 05-10-2020, 07:38 PM   #732
Tassie f100
Wouldn’t be too hard to add 1/2 mtr extra to the existing rope???
Tassie f100 is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2020, 08:17 PM   #733
Possibly, although replacing the entire rope would be better. I don't like the idea of an un-startable mower mid job because my patch job on the rope failed.
Old 12-10-2020, 08:34 AM   #734
...the smell of the products tends to linger for a couple of days in my experience
That’s one which smells like vomit?
Got jagged by a few agave spines when shifting dozens of pots for a messy lawn Friday, the wounds festered nicely over the weekend. Wondering if that ramped up the hayfever that began again yesterday, as I barely sneezed Saturday.
Old 12-10-2020, 06:30 PM   #735
I spent a pretty solid day mowing with the Bushranger today.
I'm starting to get a gauge on fuel economy now, the 163cc Honda GXV is certainly using less fuel the 173cc Kohler.
On one of my jobs, I would normally refuel the Kohler about half way through to make sure I don't run the thing dry. Today I just kept going, at the end the Honda had plenty to spare. Combined with more power and quieter operation, I am now a Honda (engine) convert.
Old 24-10-2020, 09:54 AM   #736
FTE217
T3/Sprint8
FTE217's Avatar
Well it’s back to full on mowing down the quick growth times.
As usual I fed my grass early spring, I reall like shelleys no17, it work well and gives the grass a good boost and strength to suffocate weeds.
Yesterday decided to get it done before the rain appeared for the weekend.
First few cut view And the mighty briggsy.
Love 4strokers yes I won’t clean it DFB
Love seeing the first few cuts
And whallah - good work briggsy
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
6 users like this post:
Old 24-10-2020, 09:56 AM   #737
FTE217
T3/Sprint8
FTE217's Avatar
Oh forgot due to a previous thread mention
The mighty comfortable crocs
Only work shoe I’ve used for years
Daily Macan GTS
Old 24-10-2020, 06:54 PM   #738
Ahh come on, that bottle of Collinite would work wonders on the mower too.
Old 25-10-2020, 06:31 PM   #739
FTE217
T3/Sprint8
FTE217's Avatar
Stop influencing me lol.....
Daily Macan GTS
Old 25-10-2020, 08:59 PM   #740
roddy1960
roddy1960's Avatar
We have had nearly 200mm of rain this month...consequently grass is literally growing as you look at it . Today I was cutting my jungle but it bloody rained again ...will have to be tomorrow night after work I guess..Bugger..I had to force myself to re watch the Tigers win in the Grannie again..A tough chore but someone has to do it . !!!!!!!!
roddy1960 is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2020, 09:11 PM   #741
I would rather mow the lawn than watch the football!
Old 01-11-2020, 06:21 PM   #742
Took on a new job today that needed a bit of help getting the edges back in order, a job for the little Atom, which has been running very well after a carby service.
Old 01-11-2020, 06:46 PM   #743
Tassie f100
Go and wash your black and yellow mouth out!!!!
Old 03-11-2020, 05:34 PM   #744
GasoLane
Former BTIKD
GasoLane's Avatar
At the risk of being ridiculed by the purists I'm think of getting a cordless mower.
Why? Well we have a thick (not long) spongy front lawn and a fair sized back lawn, it needs to be mowed weekly, summers coming and mowing in +35c is no fun.
Not to mention that I'm lazy and self propelled sounds like a good idea.
Does anyone use a battery mower and what are they like?
Old 03-11-2020, 07:13 PM   #745
Choose wisely.
One of my work colleagues bought a Stihl RMA 510.
https://www.stihl.com.au/STIHL-Produ...Skin-Only.aspx
Being a mower aimed at the American market, it has a limited amount of cutting height adjustment, mainly on the lower end of the scale.
From a technical point of view, it is better to mower on a higher setting for turf health. Certain grass species, such as couch, look better cut on a lower setting. Even on the lowest setting, he was disappointed. In terms of power, battery life and the quiet operation, he was impressed.
So having said that, choose a mower with the appropriate power level to suit your lawn species (Kikuyu and couch need more power, fescue and rye less power) and make sure you are happy with the cutting heights offered (most mowers will state their cutting range in the spec sheet).
Old 03-11-2020, 07:22 PM   #746
GasoLane
Former BTIKD
GasoLane's Avatar
Choose wisely.
Yeah we've got Kike front and back. So far I'm looking at Ryobi (good reviews in Choice mag) and our neighbour over the road just bought a Makita, so I might take his for a test drive
Old 03-11-2020, 07:29 PM   #747
Something else to keep in mind is the battery system. The tools are often the cheapest element, while the batteries and charger add a large portion to the cost of the overall purchase.
Do you have existing battery powered tools that could be used with the mower. If not, choose something that you could potentially add to in the future. Ryobi is popular because of their extensive range of tools that run from the same battery system.
Old 03-11-2020, 07:32 PM   #748
Tassie f100
Son in law has a Dewalt which I think does a pretty good job,but I’m not sure the battery cutting time is all that good,but then he doesn’t cut as often as he should,so it works fairly hard when he does get around to it.His isn’t self propelled.Mate has an 18v Ryobi which he is happy with to trim his about 70-80 sq mtrs
Old 03-11-2020, 07:38 PM   #749
GasoLane
Former BTIKD
GasoLane's Avatar
That's one drawback. I've got a couple of Ryobi 1+ items but the mower I'm looking at is 36v lithium.
They make a (cheaper) 1+ mower but it's a narrower cut and the battery only lasts for 30min compared to 60min.
I checked out the price for the 36v lithium batteries and chargers, expensive little suckers aren't they?
Old 04-11-2020, 09:59 AM   #750
whitelion65
whitelion65's Avatar
https://www.husqvarna.com/au/product...RoCRoAQAvD_BwE
Expensive, but the prices are coming down rapidly.
Steve
Current rides
2012 Mondeo Titanium wagon (TDCI)
Moondust silver
2016 Focus Trend, 1.5ecoboost, 6sp manual.
Frozen white
Previous
2004 Berlina Wagon (LS1) Vespers Blue
1995 Camry 2.2, white
1971 Ford Fairmont wagon 302w, C4 Polar white
1971 TC Cortina, 2L 4sp, Ermine white
whitelion65 is offline   Reply With Quote Multi-Quote with this Post
