11-04-2006, 11:28 PM | #1 | ||
BF F6, APV SR3900
hey all....
whats the way to go with spark timing on our cars.. what is everyones experiences on timing on aftermarket cams especially? i was running at 21deg BTDC, and advanced further... runs fine no ping... anywayz.. any comments?
Santo White APV SR3900 [WIZZRD] (Click Here) [/COLOR] Daily: 2006 Red BF F6 Typhoon Bluepower enhanced. |
12-04-2006, 07:40 AM | #2 | ||
White Lightning
i think mine may be up around 26 degrees and i've never had problems. stock xr6 cam though and i always run ultimate. i reckon it would ping its guts off on 91RON.
12-04-2006, 08:55 AM | #3 | ||
Two > One
How are you checking the deg of advance? Have you marked your own TDC on the balancer? Its very common for the cars to slip the balancer and give you an incorect reading. This said. When i had EEC incontrol of the engine i had 20deg BTDC dialed in as static timing.
12-04-2006, 09:56 PM | #4 | ||
BF F6, APV SR3900
well was 21deg BTDC when it was put on the dyno.. since then ive advanced it more after i put new cam in...
12-04-2006, 10:09 PM | #5 | ||
BASS ON BOARD!
I have high compression aftermarket cam and my mechanic at one stage had 44deg advance.
We then backed it off to 39deg advance and I run ultimate. Chiptorque were pussys with the timing in the chip so we did it the old fashioned way :Reverend: :thebirds: : :monkes: TWIST!
Nothing interesting to put here. |
12-04-2006, 10:21 PM | #6 | ||
OzECruisers Treasurer
I like pussys
I am at 32deg advance |
12-04-2006, 10:23 PM | #7 | |||
BASS ON BOARD!
We have something in common! : meeeeooooowwww
