#3481 | |||
not in WA we use to do this and stuffs ranging from xray equip/cat scans to pianos to ... sensetive stuff and ended up selling to cope , the then owner became the WA manager and his son a mate of mine is now running this depot i believe think the companies name back then was chalange transport
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
#3482 | ||
Being the solar thread…
For a dedicated, compliant residential enclosure to house a solar charge controller and changeover switch, do I need the “NSW standard” 600x600x250 box? In cavity brickwork is HD conduit required for lead-ins? Or is the brick cavity itself considered sufficient for internal wiring? |
#3483 | |||
BANNED
We use a standard generator changeover switch, pole 1 up, center off, pole two down. Brick cavity should be fine if it is weather sealed...IMHO I used an electrician even though it's a no brainer to install, suggest you do the same.
Please press the "Like" button if you enjoy my posts. (It's the red triangle with exclamation mark on the left) |
#3484 | ||
I will use a sparky for the actual wiring (I’ve been warning him, the longer he avoids me the bigger the job gets
#3485 | |||
BANNED
what are you using?
#3486 | ||
I haven’t spec’d anything yet.
It’s a slightly arbitrary number but the long game is to take power completely off-grid in a 75 year old suburban house, including a sizeable air-con (or as people say in Tasmania, heat pump). I want to be done in the roof before summer; all services plus insulation. |
#3487 | |||
BANNED
I have done a few off grid setups, would you like a shopping list?
