08-04-2024, 03:25 AM | #1891 | ||
*SILVER SERVICE PILOT*
Hey GT, can you tell me if the passenger side rear bumper slide bracket is still available for a 2006 BF Fairlane, also a roof antenna mast (not the base) please?
Cheers, Linz.
BUILD THREAD
https://www.fordforums.com.au/showth...71#post6891271 2006 Lightning Strike BF Fairlane Ghia...HIS 2024 Titan Grey Hyundai Tucson Highlander...HERS |
08-04-2024, 12:40 PM | #1892 | ||
Gday gt, wondering if can help out? My uncle has an sz diesel territory. Not sure what year but definitely sz and not szii.
He's just had it towed back ftom interstate with a "broken" diff. Not sure what the actual issue is, but the dealer says a new one from Ford is worth $6k. Given my uncle has just traded the car in on a new everest, he's not keen to spend that money on a car that he's not going to be the owner of for much longer. So, are Ford diffs still available? Does $6k sound reasonable? Any suggestions of alternatives to a new one, ie reconditioned and idea on cost? Appreciate any assistance you can offer.
Labels are for jars, not for people. Life is a journey, not a destination. ~~~~~~~~~~~~~~ Daily: 2013 FGII EcoLPi in Winter White Play: 2015 FG X XR8 in Emperor Show' N Shine thread Gone, but not forgotten: 2015 SZII petrol Titanium Territory in Emperor |
08-04-2024, 10:11 PM | #1893 | |||
Sorry for delay in reply have been busy with a few things. There are a few dealers with this part in stock. If you tell me where your located, I can advise the closest to you. |
08-04-2024, 10:14 PM | #1894 | ||
08-04-2024, 10:20 PM | #1895 | ||
Thanks GT.
BUILD THREAD
08-04-2024, 10:27 PM | #1896 | |||
First of all, need a lot more informtion to give you a more accurate response. I assume you are talking rear diff. Is it RWD or AWD? Yes they are around $6000 for the whole assembly, how ever need more specifics to get accurate price. You will also need to work out what they mean by "broken" such a braod term. If you can find out exactly whats wrong, you may be able to have it rebuilt with just new components. If you can find all that out, we can try and get the best option for you. GT |
08-04-2024, 11:20 PM | #1897 | |||
And, yes, you assumed correctly. Rear diff and rwd. At least the $6k sounds about right. Thanks for the info.
09-04-2024, 10:45 AM | #1898 | ||
As suspected, uncle is comfortable to allow the dealer to work through the options.
Thanks for the info, GT.
09-04-2024, 12:23 PM | #1899 | |||
Please compare that to the quote he gets, it may save him a few hundred dollars.. But up to him I guess. Where is he located and what dealer? |
09-04-2024, 12:56 PM | #1900 | |||
11-04-2024, 12:47 PM | #1901 | |||
Hi GT thanks for that. I ended up finding some last Friday at a local dealer. Sent from my iPhone using Tapatalk
-15 Ford Falcon FGX XR8 Auto -14 FPV Pursuit Ute #47 Auto -12 FPV Pursuit Rspec #44 Manual -11 FPV GS Ute #225 Manual -10 FG XR8 Ute Manual Sold -06 BF XR8 Ute -75 XB Falcon Coupe 351 GT replica -73 Ford Mustang convertible 351 -20 Ford Mustang GT Convertible |
12-04-2024, 03:29 PM | #1902 | ||
Forgot to ask GT, are the Fairlane rear bumper slide brackets different to the Falcon type?
BUILD THREAD
12-04-2024, 07:38 PM | #1903 | ||
13-04-2024, 01:18 AM | #1904 | ||
BUILD THREAD
15-04-2024, 05:46 PM | #1905 | ||
hi GT, i hope you can shed some serious light on this. or someone that fitted these at the assembly line.
i thought the fg fg2 and fgx all have the same shape front upper A arms, maybe some different part numbers because of changes in the manufacturing? here are two examples with massive price differences, im told one is for my car and one is not, the more expencive one is on V8s and 4L LPG cars and utes regards kris https://www.ebay.com/itm/22352392720...69RsMEu5GKBvKS https://www.ebay.com.au/itm/22300990...ESVLioI7pdCpoO
Current 2009 FG GTP Sold 2003 boss 260 xr8 daily driver 1991 eb1 xr8 once a year driver, factory cassette player |
15-04-2024, 10:36 PM | #1906 | |||
From what I understand the difference is in relation to the bracketry that mount to the shock tower. They are different pending on model in relation to castor/camber positions. GT |
16-04-2024, 05:14 AM | #1907 | |||
People Just need to know to tighten the rubber bush bolts whith arm at ride height angle (with the factory style bushes) Cheers
25-04-2024, 09:59 PM | #1908 | ||
Part request: FG V8 Intake Elbow - Rubber coupler that goes between the airbox and the throttle body. (plus clamps please)
Cheers! |
25-04-2024, 10:09 PM | #1909 | ||
25-04-2024, 10:31 PM | #1910 | ||
Can you tell from this photo?
https://encrypted-tbn0.gstatic.com/i...URwK4vP8Y&s=10 Sorry for being so vague... |
25-04-2024, 10:42 PM | #1911 | |||
FG 5.4 Air Cleaner & Parts.png |
25-04-2024, 10:46 PM | #1912 | ||
9B697 and the 2 clamps please.
26-04-2024, 08:04 PM | #1913 | ||
01-05-2024, 10:44 PM | #1914 | ||
Regular...with metamusal
01-05-2024, 11:15 PM | #1915 | |||
AXLE ASSY - REAR, WITH M86 SERIES AXLE, TAG ID:8R29/G* (4.0 DOHC PETROL EFI TURBO 24V VCT, AUTOMATIC TRANSMISSION, 2.73, REAR AXLE LESS LIMITED SLIP DIFF, 4 WHEEL ANTI-LOCK BRAKING SYSTEM) or FG Ute From 8/12/2010: AXLE ASSY - REAR, 1 TONNE, WITH M86 SERIES AXLE, TAG ID:8R29/G* (UTE, AUTOMATIC TRANSMISSION, 2.73, WITH EXTRA HEAVY DUTY SUSPENSION, REAR AXLE LESS LIMITED SLIP DIFF) |
03-05-2024, 08:32 PM | #1917 | ||
Looking for the below FG items:
The black outside door mouldings complete set for front and rear doors. RH/LH interior seatbelt B pillar trims in black. |
03-05-2024, 09:52 PM | #1918 | |||
When you say Seat belt b pillar trims I assume you refer to the top half, not the bottom half. For the top half FG1 and FG2 only came in light cashmere, FGX is the only one that also came in Light Limestone & Shadow Grey which is not quite black, but closest too. From what I think you can only get LH one only (need to confirm if any left), RHS is obsolete for sure for Shadow Grey Light Limestone is all obsolete too. . |
03-05-2024, 10:21 PM | #1919 | |||
Yes the outside door moulding for FG MK1. Seems I can find these online apart from the RL door mould? I have everything to blackout my FG MK1 but just require the top seatbelt B pillar trims to complete my set. Everything I have is from a FGX which would be shadow grey. |
03-05-2024, 10:30 PM | #1920 | |||
I would need to check but for FGX I think only the LH B pillar upper trim in Shadow Grey is available. |
