#3181 | ||
Very regular
A update on the old Rover. It’s not quite as iconic as DFB’s Victa 18, but I still like my Rover 200 ESX. It’s a lot lighter to push around than today’s heavier push behinds with their safety bars and other ‘keeping you safe from yourself’ devices attached to various parts of the machine. And being a really basic 36 year old mower (had it since new) it’s also a lot easier to fix and repair to.
![]() But it did let me down for the first time in ages the other day. I was half way through the mowing and emptying the catcher when it sort’ve just petered out and stopped from idle. Pulled it through a few times, and absolutely nothing. Didn’t even look like firing. Pulled the plug out and no spark. Fortunately I bought a spares machine for $20 a few years ago and with no spark figured it was the ignition coil. Swapped the coil across and also fitted the fan shroud/tinware from the spares machine. The shroud on my machine had ripped its bolt hole and wouldn’t bolt on square, so it rubbed on some of the rotating hardware. Even rubbed it back a bit and gave it a coat of paint! All done in 30 minutes. Simples! And it also looks a little bit cleaner with the fresh paint. Anyway it’s running as new again and I’m looking forward to another 10 years of trouble free mowing!
G6E Turbo Ego Cashmere .....The velvet sledgehammer ![]() |
#3182 | |||
![]() Join Date: May 2008
By the way, flip the air cleaner the other way around, the pointed part should fit the contours of the blower housing and be facing toward the starter rather than pointing outwards. Sorry, my OCD brain can't not see those little details.
The Fleet - 2016 PX MK II Ranger Cool White 2008 FG XR6 Sensation Blue 2014 FG X XR8 Emperor Red 2024 Mustang GT Race Red The Departed - 2002 T3 TS50 Blueprint 2017 Mustang GT Race Red |
#3183 | ||
HSV - I just ate one!
Jesus H Christ Honda power equipment are hard to deal with.
Local dealer advises that the direct replacement has been discontinued and there are other motors of the same base model but different specifications..... but cant tell me the differences between them. Even the non franchised suppliers seem to be of much help. Honda Australia themselves? if they got any more useless, they'd be telling me to buy a cheap knockoff from china. How hard can it be to have a chart listing engine models breaking things down by shaft size & length, and then which options? Surely its not difficult to imagine that theres someone out there thats used a vertical shaft Honda engine for something other than a lawnmower? All I need is a *genuine* Honda vertical shaft motor with a 25mm straight shaft that measures 80mm from engine mounting face to end of shaft. Grrrrr.... about ready to tell my guy to go buy an electric mower like he's thinking about.
#3184 | |||
https://sunshinecoastmowers.com.au/c...-gcv170-engine
#3185 | |||
#3186 | |||
Very regular
The briggs with the starter sitting on top of the fan housing wouldn’t of had that clearance issue and I think that’s where that style filter came from back in the day.
#3187 | |||
![]() With the foam element air filters, there were two different housings, actually three. For those older side-pull air engines, the metal housing is squarer with less chamfering around the edge. ![]() The newer engines from the early 90's have the pointier shape housing with chamfering around the edge. These were made in metal up to about the mid 2000's, then plastic. Looking at your engine, I'd say you have this style housing, which fits but not snuggly. ![]()
#3188 | ||
What about this one -
Shaft - 25mm diameter / 80mm long https://www.hendersonmowers.com.au/p...specifications
#3189 | ||
Very regular
Roger on all of that re the filters. Yup, mines the plastic one. I didn’t know that there was a metal filter housing for the 3.5 HP engines. I’ll have to keep an eye out for one of those, as that housing looks a little more ‘finished’ on the engine than what I’ve got.
#3190 | |||
(I know, it's sad I know this shit)
4 users like this post: |
#3191 | ||
And you thought your battery powered lawn mower was something new.................
#3192 | ||
Ordered a couple of specific Stihl tools, which are designed to allow adjustment to the carburetor tuning screws, bypassing the limiter caps.
https://www.outbushman.com.au/produc...-5910-890-2314 https://www.outbushman.com.au/produc...-5910-890-4500 ![]() Also included was a bottle of Stihl press fluid, which is designed to make installing gromets, fuel lines and filters easier. I learnt about this via the video below (from the 43-min mark), the idea of using this over oil is that press fluid evaporates away and prevents the fitting from popping off. https://www.youtube.com/watch?v=7z6khZwwZ2s&t=182s https://www.outbushman.com.au/produc...ne-fitment-etc ![]() I also decided to give this foam air filter oil a try. Normally, I'd just use 30 weight oil, but its a messy job. This would be useful for old 3.5 - 4.0hp side-valve Briggs engines, as well as the newer entry level OHV Briggs with the primer bulb (300E, 450E and 500E) which have oil-soaked foam filters. https://www.outbushman.com.au/produc...-all-machinery ![]() ![]()
#3193 | ||
Wondering what I should do here.
When I rebuilt my beloved Sprint 375 last year, I noticed the breather tube was loose where it screws into the block. On closer inspection, and I have no idea how this happened, but the threads were gone. ![]() This tube threads into the block behind the valve chamber and cover, directing crankcase pressure to the carburetor. Anyway, I decided to order a new one. ![]() ![]() ![]() As I had expected, the threads in the block were gone as well, so the new part didn't tighten down. Because of how the hole goes all the way through, I'm considering a helicoil to repair this installed from the valve cover side as access on the other side would be limited due to the coil/flywheel ect. With the valve cover removed, it wouldn't be depositing metal fragments into the block. I've also had someone suggest just using JB Weld or RTV to patch it back together. Would love some feedback on this.
#3194 | ||
If you’re comfortable with drill and tap a keysert/keensert type repair would be plenty strong enough.
#3195 | ||
The tube doesn't need to be torqued down super tight, just needs to seal off the valve cover and prevent letting dust into the engine. It also can't be blocked off, which looks as if the Keyserts do?
#3196 | ||
Keyserts arent blanked off at one end, so they'll suit your purpose
#3197 | ||
Excellent!
#3198 | ||
So, what is the difference between Keysert and Helicoil? Is it just the branding?
#3199 | ||
Keysert type thread repairs physically lock into the base metal by four integrated pins you tap flush. Helicoils rely only on gross friction.
#3200 | ||
One point in favour of Helicoil type inserts, is you can get kits cheaply. That thread looks rather like a 3/8” UNF by pitch.
With Keyserts, you have to buy the drill and tap separately. (I’m fortunate, eBay tap and die seller “toolingstation” is not too far from my regular travels.) |
#3201 | ||
First job of the day and after two strips of lawn, the Rover locked up the rears, then wouldn't drive the right rear.............single wheel peel. I know I should have stopped to prevent potential further damage, or at least just pushed the mower, but this thing is just too heavy to push on thick and spongy Kikuyu. With only the one-wheel driving, I needed to both push and steer it straight. Luckily, I only had one lawn to do, so I limped it through and would look at it when I got home.
I've done this enough times now to be confident tackling a task like this. Remove the hub cap, remove the stupid wheel retainer washer, then slide the wheel off the axle. The culprit? A slipped circlip, which caused the washer to pop off the drive shaft and the pawl going with it. One properly munted washer, the pawl looked fine, as did the circlip.................... ![]() And THIS is why I now have a healthy spare parts supply. In this case, all I did was replace the washer and circlip. Reassembled and tested, problem sorted. ![]() On those wheel retaining washers Rover used, I hate them! They are a pain to remove, requiring you to mess about with a hammer and flat screwdriver lever them off the axle. This almost always breaks the stupid things, which means replacement. Then, you need that hammer again to beat the new one back on the axle with an old socket. https://powermowers.com.au/products/...f097853c&_ss=r ![]() Rover used those clips across the range, from the basic 18-inch steel deck base model, right up to the top of the range alloy deck 22-inch ProCut 560. While Masport also use them on the entry level machines, they switch to a threaded axle and nyloc nut for the high end and Contractor series. Victa use E-clips and on the steel chassis variants, and a combination of E-clips and wire M-clip on the alloy deck models. All preferable to those stupid tension washers.
3 users like this post: |
#3202 | ||
I nearly fainted when I watched this! Considering how close that child is to the thing, I REALLY hope it didn't have blades on it.
#3203 | ||
Unfortunately that's something you see regularly with some people from other nations. Not just the actual mower thing, but many dangerous situations.
#3204 | |||
Several years ago, I worked with an accountant from India who you'd swear could run a businesses numbers in his head, a very, very smart man with numbers. Untill he came in one monday morning with a hand all bandaged up, and naturally I asked him what happened, and he said that he'd been mowing the previous afternoon and a stick had gone up and gotten caught under the mower. "Please tell me you shut the engine off before trying to remove the stick" ....................no
#3205 | ||
You can't fix stupid
![]() Join Date: Mar 2013
Firing up a 'toe cutter' with thongs is also a big no no in my book
-- - Whenever I fill out an application, in the part that says "In an emergency, notify:" I put "Doctor". --- Current ride: 2007 TRD Aurion 3500s 129,000 Kays and climbing. all the while reliably
#3206 | ||
Agreed!
#3207 | |||
#3208 | |||
So on that note, guess the nationality....................I left the grammatical errors in place for emphasis......................
![]() That's a Victa 18-inch alloy chassis with a one of those "awesome" Lawn Bettle engines on it. Considering the absurdity of the product description, perhaps I should ask him to include the "metal piece Rivert" for free?
#3209 | ||
hi
Honda as with other large equipment resellers ,power equipment is not there primary dealer focus . Honda = motorbikes in Australia Briggs = small to mid size petrol motors ,,, no focus on diesel no info no tech assistance etc etc STIHL = sold decent pressure cleaner years ago but when they last sold were all 10amp models no 15 or 20 amp models . Many high performance versions available overseas . Stihl = chainsaws and brush cutters in ozzy |
