#2551 | |||
Call me dirt... Joe Dirt
I'm working with the Solar company to determine the optimal system and configuration to cover as much of our own consumption as possible, but not really putting too much back into the grid. Have worked out the majority of consumption is in the afternoon, so trying to maximize the west facing panels.
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100 Mods so far: Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines Mods to come: 4.11 Diff Gears|Chromoly Tailshaft I use & recommend: Castrol|Motorcraft|Mainlube|Penrite Check Out My Build Thread |
#2552 | |||
at the low of winter (winter solstice) 21-06 till 4.30 max. Look at the average per year is another indicator. And to change ,if needed, your household energy useage as the power IS available (Washing machines etc to be run when the panels are producing. |
#2553 | ||
RPO 77
people need to remember also that different brands and models of inverters have different minimum switch on and off voltages - sometimes it is better and more efficient to go with a smaller inverter and have it switch on earlier and switch off later generating for a greater portion of the day but clip the peak generation where a larger inverter may have switched on later and off sooner but had greater peak generation but for nowhere near as many kWhr's
you don't have this prob with sma's/enasolar et al there min switch on volt approx 130v whereas brands such as solarmax/samil are twice that - meaning the panels have to work twice as hard before the system even turns on and starts to channel its energy... delta probably represent best value for money having similar specs to sma/enasolar but are half the cost and interestingly have twice the factory std warranty @ 10 yrs panel efficiency is what you need to look at thoroughly also - the difference between a 14.5% efficient panel and a 16% efficient panel is 10% - and are mostly the same cost - that can equate to a 10% more efficient system for nothing - fwiw suntech are good but there is better value for money out there at about 20-25% less cost a good solar energy provider will be able to tell you within a few % what you can achieve from minimal info - geographical data, longitude/latitude, insolation, inclination, orientation, mount type, cable run length, inverter data, module data you are very much on the right track
Q: If you have tried to sell it three times now and it is still not sold, do you think it might be over-priced? A: It is over priced - just like all the other falcon coupes for sale!! ![]() ![]() Last edited by CJR09; 14-02-2014 at 11:47 PM. |
#2554 | ||
So I have been thinking... why stop at just solar power during the day? Why can't I store the power generated during the day and use it at night time?
So my question is; would anyone know how much battery capacity I'd need to store enough power to sustain my house during the night? I've worked out my consumption is about 0.5-1.0kW/hr between the hours of 10pm-10am. I've got some spare space behind my garage... how many batteries would I need and is it even feasible at this point in time?
#2555 | ||
Yea I'd also be interested in looking at that scenario, i think you'll find that the batteries will be pretty exe though i have heard of folks using second hand forklift type batteries that can be picked up fairly cheap (ish).. obviously the necessary batteries are not your standard car battery type..
Cheers Ed |
#2556 | |||
RPO 77
o/grid looking at approx $7-8/watt installed
Q: If you have tried to sell it three times now and it is still not sold, do you think it might be over-priced? A: It is over priced - just like all the other falcon coupes for sale!! ![]() ![]() |
#2557 | ||
Ok, I am doing the rounds again after moving home. Still in outer Sydney, Endeavour Energy area.
I am looking a little bigger 4-5kw, still in NSW, so NET FIT. Net Metering works on an instantaneous net of electricity use/production. One bunch said that I need a Three-Phase Inverter (I have 3 Phase) - I find this odd. My previous install was also in a three Phase home, and my figures seem to show that that single phase inverter fed in to the NET meter, Netting Solar Production against the total of the three Phases. From my chat with someone who did not want to share info at Endeavour Energy, they use two Meters for Three Phase Solar; 1 is a "Stand Alone" the other is a "Combo". The only reason driving choice is apparently the room left on the board. So my Qs for those in the know: 1) Do either/both of the two meters used by Endeavour Energy net the Solar against the total of the three Phases, or rather just one Phase. 2) Are either/both of these meters "Smart Meters" (enabling Time of day billing). 3) What are the brand/model of the meters currently in use ? 4) Is there a requirement (or benefit to the homeowner) to have the solar distributed across all three Phases ? |
#2558 | ||
Maybe have a chat to Solar Choice, they are a solar system broker and I found them very helpful when doing my research
http://www.solarchoice.net.au/ 1800 78 72 73
#2559 | ||
OK
Got a call back from a techie. 3030 same as my last one, and all the meters do net solar against all three phases. If a System is 5kw or above (panels OR inverter) it must be split - this is a service provider requirement, and does not benefit the homeowner (not sure if this is a <5kw difference between phases, or a <5kw max per phase) |
#2560 | ||
Prior to my cancer diagnosis I worked for a small company in Denmark Western Australia as a Designer/ Installer; one of the last projects I was working on was designing and project coordinating of the second biggest rooftop installation in Western Australia. So if anyone has any technical questions they want an unbiased opinion on send me a message.
2 users like this post: |
#2561 | ||
welcome to the forum . hope you beat the big c
clevo mafia (sadly sold) 351c xe manual (now with short shifting 5sp goodness) xc gs coupe project...hmm more clevo for me new daily 2005 ba sr |
#2562 | ||
got my new bill (he he he I love calling it that) now $565 in credit 4kw system gotta say im loving life and now ive got a slow combustion heater it wont go down much in winter and as i'm in the country the firewood is free !!!
#2563 | |||
Obsessed with wheels
#2564 | ||
it would be nice to have but I don't want to pay tax on it plus you never know what the future holds for input credits ( mind you one can never have too many hardtop bits )
#2565 | ||
Morning all! I have been following this thread with much interest and would like to thank all those who posted for their experiences and feedback. I have just had a 4.5kW system installed and took great delight in watching the meter spin backwards. 4.5kW is the largest single phase array that PowerWater allow and is divided 8 panels east (actually ESE) and 10 panels west (WNW). This array uses 9 micro-inverters rather than a single inverter. This allows panels to generate individually rather than on a string. Been averaging around 22kW/h per day but that will increase once I've removed a line of trees which totally shadows western panels mid arvo. I'm thinking 27kW/h per day will be the go. Hopefully should knock around $700 per quarter off the bill!
4 users like this post: |
#2566 | ||
Recieved my "Bill", $419 in credit, a little less than i expected, although all these rain days we have recieved over the last quarter probably dropped this by a little, I think last year it was $500 in credit for the same period.
#2567 | |||
I haven't paid a bill since install and just withdrew $1,000 leaving $250 or thereabouts (after my last account).
--------------------------------------------------------------- G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II... may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon! |
#2568 | ||
Definetly, a credit is way better either than a $333 bill
#2569 | ||
Sorry to ask, but for comparisons sake I would love it if people stated if they were NET fit (like new NSW connections), or Gross (total Generated) FIT.
My previous 2KW NSW install (NET FIT 6.6c) saved me about $200 per quarter, and my calculations (based on sampling every 5 minutes) imply that even at a 5kw system I would not get into a credit situation. |
#2570 | ||
gross generated for me........paid for every kilowatt I produce.
BIL'S wife has terminal cancer, the drugs she takes make it hard for her body to regulate her temperature so their ducted reverse cycle air-con runs 24/7.......bills used to be $1500 per quarter and rising. since we installed a 5 kilowatt system, unfortunately after the larger FIT'S were taken away, the accounts have halved, ...................I think this is still a good outcome for a relatively small expenditure (taken over the life of the system). sometimes a credit is maybe not the way to be thinking, a major reduction in power accounts is a very good outcome I feel. the "credit" in my account is good but the "no charge" on my account is what gives me the buzz! after years of fearing the power account I couldn't really care less about the money side of it.
#2571 | ||
4.5 kW at darwin
Last bill $800. I use power and ac when I feel so that is about right. Normal bill would be about $1500 without the solar. Wet season too so not as much sun. Average 22kwh per day on a sunny day. Panels not in ideal position but best we can get Happy with the set up and will pay for itself in about 4 years. I will get a new 5.5 kW after that with a smart inverter so only 4.5 kW goes into the grid. Won't be for a few years though |
#2572 | ||
Thailand Specials
Whats the price on a 5KW system in Victoria? We average about 25KW/h a day with our power usage with no heating/AC.
#2573 | |||
http://www.solarchoice.net.au/blog/s...h-2014-100314/
#2574 | ||
Energex finally got around to putting our other meter in. I'm just interested how are you meant to read it? There are two different readings that flash back and forward. So I'm figuring the one with the minus sign is what we put into the grid? And the other is what we have used from the grid? That's just a guess I don't know.
#2575 | ||
do you have the Itron meter?........if so you will have "export" or "import" stamped straight under the numbers with a little set of numbers above the stage you are at.
press the blue button and your numbers will change and the "staging number" will light up above the position you are in. a user manual can be downloaded from here, https://www.itron.com/mxca/en/produc...ype%20292.aspx ETSA only use this model so I can't comment on any others.
#2576 | ||
#2577 | ||
Missing a sock...
![]() ![]() Join Date: Mar 2012
I've got the Em1000 too Roo.
Positive reading is what you've taken from the grid, negative reading is what you've given to the grid. My meter bloke must read both the values and enter them into his handheld unit. https://www.energex.com.au/__data/as...25619/8006.pdf I dunno how it works if you've got off peak power tariff like electric hot water/pool pump - maybe a different meter is fitted. I've got gas hot water/stove and no pool. Cheers!
Real friends + great times = sheer bliss! Considering becoming an organ donor? Click here QLD Events, Cruises and Get Togethers: Click here Gain success instantly - lower your standards. It's not government funded - it's taxpayer funded.
#2578 | ||
we don't use those around here so I'm not familiar, my guess is to use the "scroll" button (top right) to view the different outputs or inputs.
you will have a "J" tariff in there as well if you have electric hot water, disregard that one. as SS states positive reading is "infeed" (bad) , negative reading is "export" (good) you may find this interesting........ https://www.energex.com.au/__data/as...25619/8006.pdf or even http://www.youtube.com/watch?v=wPmk57Xq08U
--------------------------------------------------------------- G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II... may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon! Last edited by poppa smurf; 12-04-2014 at 02:11 PM. Reason: added PDF |
#2579 | ||
Thanks fellas. I have solar hot water as well. The scroll button only puts it to the reading it's not displaying at the time. But then just goes back to flicking between the two, so ultimately you'd want export number to be a lot high then the import number.
#2580 | ||
BANNED
I just did some sums and its cheaper to buy 3kw of panels and a standard electric hotwater system instead of a solar convection unit....(about 4000-4500 dollars)
My question is...will an electric hot water unit work using 240volts DC instead of AC? (cause when the water is hot this setup would still make electricity for charging batteries and a convection solar unit does stuff all once water is up to temp) Anyone tried it? |
