Old 15-08-2010, 12:27 PM   #1
zbeasty
zbeasty's Avatar
Default Check Engine Light but no Fault Codes
Anyone experienced this. Last service was done less than 15,000km ago and I've checked all the fluid levels. Just gone through 103,000km so I thought maybe timing belt but that is supposed to last till 150,000km. It's not flashing so not an urgent issue apparently.
zbeasty is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2010, 12:39 PM   #2
ratter
ratter's Avatar
What are you using to check fault codes?
Pit Lane Performance
Old 15-08-2010, 01:13 PM   #3
Gaz
Got Ghia?
Gaz's Avatar
**edit**
Didn't realise we were in the Small car fourm Thinking a timing belt on a boss wasn't quite right. Apologies I stumbled through the wrong door!
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2010, 08:34 PM   #4
zbeasty
zbeasty's Avatar
Push odo reset before starting and continue to hold till it enters test. Scroll through until it gets to DTC. It says none.
Old 15-08-2010, 09:03 PM   #5
ratter
ratter's Avatar
Not knowing what it checks for, I would assume it only checks for emission related codes, I would suggest you get your mechanic to check for codes with a workshop scan tool, not just a generic OBD2 scan tool.
Normally if a light comes on a code would be logged, the code may only stay present for x amount of starts before clearing itself
Thread Tools
Display Modes
