01-12-2008, 12:39 PM | #1 | ||
Critical Thinker
Well I just got a message from my mechanic mate who said the carrier bearing on my diff is on the way out.
Tends to whine and vibrate a little at 65kph. Common issue on the AU's apparently. So I was thinking, while Im getting the bearing replaced, is it worth me converting to LSD and sticking a 3.45 ratio in it, or something else?
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
01-12-2008, 12:51 PM | #2 | ||
Your probably be better off just replacing the whole diff with an 3.45lsd out of another car, this is what i have done, it cost me $500 for a complete S2 XR8 LSD irs assemble, yours would be a lot cheaper being non IRS. But basically to buy diff gears 2nd hand $200, to get a good LSD diff centre your looking at $300.
Are the E series live axle diff's the same size as AU, if so that would mean you would get a diff a lot cheaper.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
01-12-2008, 12:55 PM | #3 | |||
Critical Thinker
01-12-2008, 12:58 PM | #4 | ||
The 3.45 lsd diff has a large carrier bearing in it, and i have never heard any problems with them.
01-12-2008, 01:05 PM | #5 | |||
Critical Thinker
01-12-2008, 05:54 PM | #6 | ||
i would bear in mind that in a second hand lsd at 100000 k`s the it will probably be close to single wheeler due to wear and tear, i tested mine at about a hundred thousand k`s and it had very little lsd effect, the car has never been to drags or had any abuse, if your buying a diff second hand for a lsd on its own unless its recoed i think your wasting your dough imo unless its super low k`s.
01-12-2008, 05:56 PM | #7 | |||
Critical Thinker
Get a 2nd hand unit rebuilt or by new?
02-12-2008, 01:52 AM | #8 | ||
i've purchased plenty of lsd and had plenty of cars with them at 300,000km's and i have never got one stuff, which has been good luck, the whole thing is you have to check the diff your buying, check how much touque it takes to break the lsd and play etc.
02-12-2008, 10:48 AM | #9 | ||
Critical Thinker
thanks mate, will do.
02-12-2008, 10:07 PM | #10 | ||
some good advice from 5.0whiteaughia, allthough i have to admit i`m a bit partial to reco stuff, i have been dissapointed a few times over the years from buying second hand stuff over the year`s, good luck.
02-12-2008, 10:21 PM | #11 | ||
Critical Thinker
Thanks mik. I'm pretty cautious also. It will be interesting to see whats out there. If I have to buy new, I will but prefer not to if I can avoid it.
03-12-2008, 01:53 AM | #12 | ||
Yeah new is always nice, but with the price variance between new/reco diff centre and gears compared to a 2nd hand unit, its a big difference.
03-12-2008, 10:47 AM | #13 | |||
Critical Thinker
03-12-2008, 11:24 AM | #14 | ||
ive been quoted 660 fitted for a standard replacment NEW LSD center from Hart Transmissions up here in Brisbane(at Brendale)
then you just need the gears.apparently aftermarket gears from a diff shop are of a harder metal so as to reduce wear and tear compared to the cast standard units
03-12-2008, 12:16 PM | #15 | ||
Critical Thinker
Thanks blackers. Thats interesting to compare.
I reckon weighing up the price differences is a must. Still if you can get a decent 2nd hand unit for cheaper, its worth looking into.
03-12-2008, 12:37 PM | #16 | ||
Okay well gears $450 new, LSD $600 new.
You should be able to get a good 2nd hand LSD diff for it for $250. I got my whole IRS setup for $450 with 3.45 LSD.
03-12-2008, 12:53 PM | #17 | |||
Critical Thinker
Here is a question, will the 3.45 gears from an IRS setup fit into a live axle diff setup?
04-12-2008, 02:26 AM | #18 | ||
yes they will the gears are the same, but the LSD is different, but you can put an IRS lsd in a live axle, but not visa versa although some people have, in the IRS setup their is a circlip groove thats not in the normal setup.
04-12-2008, 11:07 AM | #19 | |||
Critical Thinker
04-12-2008, 01:13 PM | #20 | |||
formerly PURSUIT-250
It will work using early cones (solid axle ones) in an irs, as they are a 2 piece cone and side gear. The circlip will locate in the grove. Hey blueoval your noise will be most likley be coming from small pinion bearing as there the first to chew out. Cheers Mick. |
04-12-2008, 01:23 PM | #21 | ||
Critical Thinker
Thanks Mick. Will replacing the diff gears and installing an LSD centre sort the noise out or is that a different area of the diff again that I will need to address?
04-12-2008, 02:59 PM | #22 | |||
That will fix the whien. (spelling) But as mentioned by others your better of with a good 2nd hand 3.45 ratio LSD. More fun. : Good Luck. Cheers Mick. |
04-12-2008, 03:07 PM | #23 | |||
Critical Thinker
05-12-2008, 12:46 AM | #24 | ||
Pursuit 250 - Yeah it will work putting the 2 piece cone and spider gear in, but its not exactly correct now is it, not to mention your then forcing a circlip in between both forcing the cone harder against the case, so if we can just force things tighter than why do they bother setting the preload correctly with shims.
05-12-2008, 01:21 AM | #25 | |||
HAhahahahaha, the factory preaload as we no, is good for a blender. hence the circlip slightly forcing the cone harder into the hat, when building them i ad 2-3 BTR LE front pump shims in between the side gear and cone wich gives you a nice and TIGHT LSD, a litle to tight at the start but in 3-4 weeks she is sweet as 18 YO. : Cheers Mick. |
05-12-2008, 02:29 AM | #26 | ||
Critical Thinker
I have got in contact with a member who works at a wrecker and has a complete xr6 live axle diff with 3.45 ratio and LSD setup, axle to axle for $500 cash.
Is this good? I can pick it up next week to be fitted.
05-12-2008, 03:26 AM | #27 | ||
Sounds a tad expensive to me, i would have thought they would be more around $300-$400. But I don't exactly go around pricing them either. Along the same lines if its in excellent low km condition then it would be worth spurting some extra $$$ for.
05-12-2008, 03:30 AM | #28 | ||
PURSUIT - 250 thats funny you say that about factory pre load, cause i have noticed in the AU"s its pretty loose but in earlier diff's it was much tighter.
05-12-2008, 07:58 PM | #29 | |||
It's not exactley CHEAP but it is about the price you would pay retail, as long as the diff has'nt done 400,000 k's, minimal back lash, not noisy and has NO metal partical's in the oil. Cheers Mick. |
08-12-2008, 11:54 AM | #30 | ||
Critical Thinker
thanks fellas. I might take a member from SA to come with me to see what they think. I dont want to be ripped off if this item is a POS.
