02-04-2009, 09:21 AM | #1 | ||
as topic says can this be done ? i no i may sound stupid but i was reading somewhere that the manual gearbox is sealed and the oil cannot be changed is this true? i have tried looking for the plug and were to put the oil but i cannot find it any info will help guys
cheers |
02-04-2009, 04:52 PM | #2 | ||
I'm not 100% sure but i have heard the same thing. As far as i kno the box is sealed and the oil cant be changed.
2006 WQ Fiesta Zetec Sea Grey Interior:- MOMO Blue Leather Gear Knob, Window tint, Scuff Plates, ST Black & Blue Leather seats, Soundstream Amp & 5x7 speakers, Sony Headunit, Pioneer sub & Amp. Under the Hood:- Superchips ECU Flash Tune, Denso Iridium plugs, KV85 Magnecor Leads, BMC CDA Induction. Exterior:- Spoiler, clear side repeaters, Lowered (35mm) King Springs, Whiteline 22mm Rear sway bar, 2" cat back exhaust with a dual conversion, Konig 17" Hotswap with Kumho Rubber, HID's. |
03-04-2009, 10:46 PM | #3 | ||
There is no drain plug. There is a is a filler plug tho. It is behind the motor, sort of down and left of the battery when looking from the front. The plug is held in by a pin that has a clip on it. If you can put the car on a hoist itis easier to find from below.
Mike www.ttcracing.com |
04-04-2009, 08:44 AM | #4 | |||
Surely the oil has to be replaced sometime? |
04-04-2009, 12:53 PM | #5 | ||
u need to suck it out. I have an oil changer that does it but you can buy hand pumps (like a big syringe).
