Old 12-08-2009, 08:07 PM   #1
toobs
Team DOB
toobs's Avatar
Default About to replace engine in mk2 escort 1600- tips?
Hi everyone. I have a stock mk2 1600 which started making really bad noises down near the crank. Although I haven't diagnosed the issue properly, I'd hazard a guess that I've managed to spin a bearing or something similar.
I'll be removing the engine shortly and replacing it with a low-km or reco'd unit from either city dismantlers (Adelaide) or somewhere that can offer a better price with something resembling a warranty.
I've done countless work on lasers and other FWD cars but haven't touched an escort before. I have no issues pulling/rebuilding engines but just wondering if there are any things I need to look out for specifically with the escort.
Additionally, what parts/seals I should consider replacing while the engine is out.
Unfortunately its not my car and I have to keep the budget to a minimum. The car is not a cruiser, racer, etc only a dead standard car so it doesn't require any hot bits.
Thanks in advance for the help
Darius
Understeer is when you hit the tree with the front of the car, Oversteer is when you hit the tree with the back of the car
toobs is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2009, 08:52 AM   #2
Puzzlescort
Rally Nut
Puzzlescort's Avatar
the 1600 is fairly small - easy change over
just check the obvious gaskets leaks, on the front of the gearbox, exhaust manifold, check the condition of the clutch fork & bearing while the motor is out, they can tend to bend
you can check the condition of the steering rack bushes etc while you at it (depending on how keen your getting)
apart from that there isnt much in an escort engine bay - lol
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2009, 12:06 PM   #3
toobs
Team DOB
toobs's Avatar
Haha very true! Easiest to remove gearbox with the engine or leave it in?
Old 14-08-2009, 01:37 PM   #4
Puzzlescort
Rally Nut
I always find it easier to remove the engine without the gearbox if you are lifting the motor out, I usually only leave the gearbox on if I am dropping the whole lot down on the crossmemeber
for the 10 or so bolts, unless you want to do something with the gearbox leave it in - no stuffing around with tailshafts, speedo cables, etc
Old 14-08-2009, 05:48 PM   #5
toobs
Team DOB
toobs's Avatar
Thanks mate...are there any online store that stock escort gear for a decent price? I live in the country and getting parts is difficult/expensive, local parts shop thought EBC greenstuff was a type of coolant...
