Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
Does anyone know the 2011 use of Daytime Running Lights in NSW?
I have found lots of conflicting stuff on the web. Looking to do a 'mod' on my AU UK
Lots of cars come from factory with daytime running lights...
The only issue is Fog lights/ spot lights
You've seen it, you've heard it and your still asking questions?? Don't write off the Goose until you see the box going into the hole.... |
I've heard that current model holdens have been 'booked' for having them on.
UK
Most probably urban myth... or the owners are too stupid to fight it in court.
If the car meets the ADR then there is no issue. The state cant overrule the Fed...
![]() ![]() Join Date: Jun 2006
ADR76 covers the light specifications for DRL's.
ADR13 covers the installation requirements on vehicles. basically 250mm to 1500mm from the ground, and not less than 600mm distance between lamps. Also they are only to be on whenever the ignition is ON, and the vehicle lighting is OFF. Seen a number of HSV's with the DRL's on when the headlights are also on, that is illegal per ADR13. |
Please explain how this applies to the cars that were factory fitted with hand held mobile phones and/or radar detectors.
#7 | |||
Regular Schmuck
#8 | |||
I was thinking about this style
![]() but are these legal in NSW (say mounted to show the raditor) or as DRL's ![]() UK
Blue lights are illegal..... in any form.
#11 | |||
Australian Design Rule 76/00 - Daytime Running Lamps 9. COLOUR OF LIGHT The colour of the light shall be white. It shall be measured by using a source of light at a colour temperature of 2856 degrees K (corresponding to illuminant A of the International Commission on Illumination (CIE). However, for lamps equipped with non-replaceable light sources (filament lamps and other), the colorimetric characteristics should be verified with the light sources present in the lamp, in accordance with paragraph 10.2 of this Regulation. The colour must be within the limits of the trichromatic co-ordinates prescribed in annex 4 to this Regulation.
#12 | |||
ADR76 as you pointed out allows for daytime running lights... If fitted at the factory in accordance with the ADR then it meets the requirement. Volvo have have daytime running lights on its models since what? 1975? And they have been sold here with the lights connected directly to the ignition legally since then.
#13 | |||
Mot Adv-NSW
DRL's, including the regulations later adopted as ECE, then UNECE - were a Scandanavian thing. EU's ECE mandated them for that market not that long ago. The new LX Mondeo doesn't get the LED DRL's, Zetec does, but no front fogs, Titanium has the DRL and front fogs! Thought Ford would have standardized them through the Mondeo range. Not that I really care, happy to live without them. http://www.dadrl.org.uk/ EDIT - Bloody Ipads, had to use computer to fix.
ORDER FORD AUSTRALIA PART NO: AM6U7J19G329AA. This is a European-UN/AS3790B Spec safety-warning triangle used to give advanced warning to approaching traffic of a vehicle breakdown, or crash scene (to prevent secondary). Stow in the boot area. See your Ford dealer for this $35.95 safety item & when you buy a new Ford, please insist on it! See Page 83, part 4.4.1 http://www.transport.wa.gov.au/media...eSafePart4.pdf Last edited by Keepleft; 19-02-2011 at 11:36 PM. |
#14 | ||
Hi all
I have seen these fog lights on ebay.. http://cgi.ebay.com.au/7-COLOR-PILOT...item56416be6a4 Now if the glob is white, and if I get white angel eyes are these legal in NSW? The reflector is blue. UK
#15 | ||
Mot Adv-NSW
Can't see any conformity markings on the lens, wattage insofar a halogen front fog light is proper, but we can't tell the beam pattern to accurately determine it's real function, that of a front fog light, or a driving lamp.
You are reliant on the advertising. The blue lens simply gives a whiter light within the beams range, width/reach. See Narva/Hella et al for dedicated LED or incandescent bulb DRL kits. I'd be more inclined to fit a rear fog, but that's me:-)
ORDER FORD AUSTRALIA PART NO: AM6U7J19G329AA. This is a European-UN/AS3790B Spec safety-warning triangle used to give advanced warning to approaching traffic of a vehicle breakdown, or crash scene (to prevent secondary). Stow in the boot area. See your Ford dealer for this $35.95 safety item & when you buy a new Ford, please insist on it! See Page 83, part 4.4.1 http://www.transport.wa.gov.au/media...eSafePart4.pdf Last edited by Keepleft; 26-03-2011 at 03:48 PM. |
