Old 11-05-2011, 08:14 PM   #1
mytgxl
mytgxl's Avatar
Default boss 260 info
What are HLA`s & are the easy to replace & what would be the cost of them each! how many are there? & would that stop my ticking noise on cold startup?
Never drive faster than your guardian angle can fly but fast enough so the devil don't catch you!
mytgxl is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2011, 08:26 PM   #2
Sam
Default Re: boss 260 info
Hydraulic Lash Adjusters (lifters). Could be the timing chain tensioners, the replacement of the old plastic ones will stop startup noise. The o-ring fails on the early ones causing them to bleed down and release tension on the timing chain. $250-$300 in parts, $500+ in labour.
Sam is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2011, 08:31 PM   #3
mytgxl
mytgxl's Avatar
Oh crap I`ve had them replaced, & It still makes the noise on startup till the motor gets warm any idea`s?
Old 11-05-2011, 08:34 PM   #4
Sam
Is it just the 2-5 second rattle on a cold start in the morning? There are a few cases of guys replacing the HLA's at around $45 each from Ford. I would definitely get it seen to by one of our Forum Sponsor experts who have dealt with these beasts before.
Old 11-05-2011, 08:37 PM   #5
mytgxl
mytgxl's Avatar
No it`s not the 2- 5sec rattle had that fixed it`s more of a ticking noise until it warrms up!
Old 11-05-2011, 08:53 PM   #6
JOSH
JOSH's Avatar
are you talking about the timing chain tensioners? they make a bad rattle on start up
03 BA Pursuit
(03) 93053000
Ray Prescott Auto
(02) 49902488
JOSH is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2011, 10:06 PM   #7
mytgxl
mytgxl's Avatar
No it doesn`t rattle on startup if the motor is idling you don`t here a thing!
it`s not until you put it in gear & put a load on it till you hear the ticking noise then it goes away when the motor warms up!
Iv`e tried 0w-30 & 10w-30 but it did`nt make a difference! the oil gets changed every 800km because I do stuff all kms between services, should I try 0w-40 castrol next? or will this make no difference
Old 12-05-2011, 01:07 AM   #8
dump
Could be a good idea to let it warm up for a few minutes before you drive it and give the oil a chance to circulate before you put a load on it...oil pressure?
dump is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2011, 01:10 AM   #9
dump
Maybe, just maybe... you should warm it up, find a secluded area... and do a massive skid to blow out the cobwebs, lol...
Old 12-05-2011, 11:11 AM   #10
mytgxl
mytgxl's Avatar
How many HLA`s are there in the motor & are they easy to replace?
