Hi All,
I picked up a pair of second hand front seats that I want to swap into my AU3 Pursuit 250. The new drivers seat is electric but my ute wasn't optioned for electric seats. Is there any factory wiring point in the loom I can plug into to get power for the seat or will I need to run a new feed into the fuse box? Cheers Michael
AU3 Pursuit 250 5.6L + Auto
Good question , I'll be interested to hear the answer to that one myself.
5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
This has been covered in another thread somewhere. The seat power is supplied from the fuse box (under dash) by the Grey w Yellow trace wire from connector C181 behind the fuse box. This wire goes to connecter C50 behind the driver's side kick panel where, in the high series cars, this has a tail that goes off to the driver's seat. Wire remains Grey / Yellow all of the way. Not sure if the Ute would have the grey/yellow from fuse box to connector in driver's kick panel. Diagram is on page 24-4-73 of the wiring diagrams here:
http://fordforums.com.au/wsm/wire/au...html#page00024 Good luck. Cheers Stu P.S. If you use the grey / yellow as a source, this has input from the BEM, which I believe will stop you using another memory spot whilst the car is moving???? I havn't tried the full extent of movement on mine whist the car is going, but I do know it would not let me select my memory spot after I started moving.
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
Thanks Stu,
I'll check behind the kick panel on the weekend. The seat I have is just a manual electric one with no Memory function. It just needs a 12V source. Cheers Michael
