Has a blue one
Tonight I replaced a blown fuse for the stop lights. When I turned the ignition back on a loud beep came from the dash and since then the car no longer starts. Could I have accidentally triggered the smart shield to thinking I'm trying to steal the car?.......The smartshield hand flashes ninety to the dozen when i try to start her
I have dash lights and radio, but absolutely nothing else. Is it curable?
If we call for the proof and we question the answers, only the doubt will grow. |
check the engine fuses in the engine bay worth a shot
no longer starts, does that mean cranks but won`t start or is just plain dead.
Has a blue one
Cranked twice, now it's dead except for dash lights and radio
5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
Check your key, make sure the transponder has not dropped out of the handle end. Do you have a spare to try?
Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
Next upgraded Mk1 Leopard
Thats what happened to me
UK
probably unrelated and a stupid question, but how is your battery, got plenty of charge?
Has a blue one
I'm starting to think the fuse to the smartshield may have been removed while the ignition was still on.............Any chance that may have created the problem?
Has a blue one
Thanks for all the suggestion all. The car is now back up and running.
It was the dome light causing the issue
