Old 27-08-2015, 06:42 PM   #31
347 mont
347 mont's Avatar
Default Re: Rear IRS bushes/rear end maintenance
Definitely on the priority list on mine. Went for a country cruise with a mate, he has a BA II XR6 T
and mine AU II Ghia. He's just had all his bushes done. Anyways we swapped cars for a leg of the drive
and holy moly what a pleasure the BA was to drive, so tight like it just came off the factory floor, even
better. I really take care of my AU but this is something I've definitely over looked.
Losing my patients with unfinished threads
Did the ideas people helped you with work or not!
347 mont is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2015, 03:06 PM   #32
Peuty
Afterburner + skids =
Peuty's Avatar
Guys another quick question.
I remember a few years ago on here a few guys were having trouble with CV joints breaking - but I think it was only from drag racing.
While I have everything taken apart, is it worth putting in new half shafts while I'm there?
Oo\===/oO
Old 20-12-2015, 10:28 PM   #33
BOTTLEDUP
SuperPro have just finished a development run of new upper irs shock mounts, I have a set on order and will be planning to get them installed asap. They are in all respects a reproduction of the original, but with a flexible polyurathane rather than rubber. I'll get some pictures up as soon as I lay my hands on them.
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2015, 10:30 PM   #34
Peuty
Peuty's Avatar
Interesting in seeing what they are like. I have a set of Sox mounts that are pretty much exactly that.
Oo\===/oO
Old 10-02-2016, 11:36 PM   #35
twodogs 260
Went to get the fairlane wheel aligned today and have the rear camber bolts fitted as mine never had them , only to find out that the upper inner bushes and the upper outer bushes are fishnickered , NOBODY IN WA had anything on the shelf can you beleive that *****. So i ended up with the upper inner bushes being nolathane and i believe the upper outer bush will be a super pro bush, not ideal as is a mixed bag of brands . but had no choice at the time , Are the nolathane bushes that BAD in the rear of the car ???, as it will only be the inners that will be nolathane , or am i going to have dramas with them.They haven't been fitted yet hopefully they get some super pro bushes in overnight and i can return the nolathane ones It's a daily driver lowered to tickford specks with munro gt gas shocks all round
twodogs 260 is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2016, 02:23 PM   #36
Peuty
Peuty's Avatar
Nah you'll be right with the nolathane bushes. Super Pro are certainly better, but You'll be right.
Oo\===/oO
Old 11-02-2016, 10:20 PM   #37
twodogs 260
Well finally got the car back this afternoon , had a chat to the technician that was doing the bushes and a couple of interesting things have been learned. At 16 yrs old and having done 226k i was not surprised to see that bushes were needed, all upper arm bushes were fishnickered . But what is surprising is that the inner upper bolts for the arm on the left side WERE NOT TIGHT AT ALL , right was fine , starting to wonder if this car has been smashed at some point?? , anyway bushes done camber bolts fitted and wheel aligned and now all good MUCH better to drive but not looking forward to the bill tomorrow
Old 12-02-2016, 12:28 AM   #38
mcfly94
mcfly94's Avatar
couple nolathane bushes wont hurt, but dont do the whole lot youll regret it!
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2016, 07:19 PM   #39
NCII40
XR6T BA 2002
NCII40's Avatar
Which Rear Sway Bar do i need?, The Whiteline one on their Website is 20mm?
Over on FordMods, I member Wrote
you will need to brace up the rear outer sway bar mounting points....they will crack without it.
Has anyone looked in to this?
XR6T 2002 BA
Old 23-05-2016, 09:01 PM   #40
T MAN
T MAN's Avatar
im pretty sure thats refering to outer sway bar mounts on live axle, i have seen them crack on live axle cars,
not irs as irs swaybar is mounted to the cradle and rear lower arms
T MAN is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2016, 12:36 AM   #41
NCII40
XR6T BA 2002
NCII40's Avatar
Perfect
thanks for the reply
Which rear sway bar would you recommend
XR6T 2002 BA
Old 24-05-2016, 04:56 PM   #42
Peuty
Peuty's Avatar
I'm fairly certain that Whiteline no longer make a rear IRS swaybar.
Regardless, I got a KMAC item in 20mm. KMAC will make you one on an as ordered basis.
Oo\===/oO
Old 24-05-2016, 05:18 PM   #43
mcfly94
mcfly94's Avatar
Signature sway bars will do a 24mm rear bar
Old 24-05-2016, 09:00 PM   #44
NCII40
XR6T BA 2002
NCII40's Avatar
Thanks heaps for the replies
Cant wait till all the new bushes, rear hubs and swaybars go in
Anyone know about the quality of these Half Shafts ?
XR6T 2002 BA
Old 24-05-2016, 09:19 PM   #45
T MAN
T MAN's Avatar
ntn drive shafts are what the factory use,
Old 24-05-2016, 10:36 PM   #46
mif73
CNC fixer guy
mif73's Avatar
I think GKN (Unidrive, Vic) manufactured and supplied them to BTR (ION,DSI) back in the day.
I used to visit the Albury plant when it was known as ION/DSI, now no more since the chinese bought the company and shut it down. :(
Unidrive is still around for now making parts mainly for Toyota and Corvette prop shafts.
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player.
Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers.
mif73 is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2017, 11:03 PM   #47
au350hp
Did you like the car when you picked it up? How did it drive etc and if you don't mind saying, what did it end up costing & have you listed all the bushes replaced? Be great to hear how you went as I have just purchased rear mounts, struts & springs for the rear of my au & I am sure there will be bushes needing replacing.
au350hp is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2017, 01:17 PM   #48
NCII40
XR6T BA 2002
NCII40's Avatar
Will a 6000kg shop press do the job to fit all these bushes including sub frame?
http://www.supercheapauto.com.au/Pro...-6000kg/214467
XR6T 2002 BA
Old 26-11-2017, 01:47 PM   #49
Sox
RIP...
Sox's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: As recommended by Ropcher. Personifies the spirit of AFF.
Most likely.
I have a 20t press and it rarely goes over 2-3t.
It's been up around 8t a couple of times.
Having said that, my 20t unit was only about $100 more than that on Ebay, with a pneumatic attachment.
Oval Everywhere...
Sox is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2017, 08:08 PM   #50
NCII40
XR6T BA 2002
NCII40's Avatar
Thanks man
XR6T 2002 BA
Old 27-08-2018, 02:15 AM   #51
TickfordTiger
see this forum also :
https://fordforums.com.au/showthread.php?t=11353903
I have noticed these replacement internal polyurethane bushes are now available for $110ea from wholesale suspension
They also sell complete (changeover) shock / spring mounts also $275ea.
https://wholesalesuspension.com.au (02) 98318825
https://www.ebay.com.au/itm/FORD-AU-...T/272728046549
https://www.ebay.com.au/itm/FORD-AU-...A/272724624580
Falcon Unbelievable !!!
T1 TL50 Build No. 014 - Liquid Silver
T1 TL50 Build No. 017 - Liquid Silver, Sunroof
TickfordTiger is offline   Reply With Quote Multi-Quote with this Post
