Old 24-05-2020, 09:11 PM   #1
Matt dive
Default Passenger side footwells flooded
I jumped in the car after 2 days of rain to find the front and rear footwells full of water . I’m not talking just damp I’m talking a pool in both.
Doors look fine and dry ,firewall is dry but footwells are pooled.
I have pulled the front carpet out and all trim in the front and can’t find anywhere that it has come in from.
Has anyone else had this problem .
I pulled out the pollen filter and there is no evidence of any water coming in through there .
Please if anyone has had this problem and can give me some clues on where I can start to look to hunt it down.
Matt dive is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2020, 10:53 PM   #2
Default Re: Passenger side footwells flooded
What year and model series?
Old 24-05-2020, 11:14 PM   #3
Does it have a sun roof? https://www.youtube.com/watch?v=qsIMQawXGI4
Also perhaps: https://www.youtube.com/watch?v=jXbA8lCTU9k and
https://www.youtube.com/watch?v=EWt1_Hhx1M4
Old 24-05-2020, 11:26 PM   #4
Also see this thread: https://fordforums.com.au/showthread.php?p=5927579
Old 26-05-2020, 09:16 AM   #5
Matt dive
So an update on leaking into the mondeo.
In my car I had found the leak. The sunroof. There are drain pipes running off each corner of the sunroof down the a pillar and into the front wheel arch .
I took all the trim off a pillar . Removed everything for access to the passenger side roof lining.
First step was to check the drainpipes weren’t blocked.
Whisper sniper cord about 3 metres , fill the channel in the sunroof with a bit of water so it pools like it would during a wash or rain, insert the cord down the tube jiggle it down as far as you can ., you will see the water starting to swirl and drain away . It’s very slow though so give it time . Pull the cord out the hole if it’s all clear water will drop from just behind the front wheels. If this is happening all clear with the drain holes .
Now this is where I found my leak. I hadn’t removed the headlining just released everything so I could pull the headline down and see inside to the sunroof and all the tubes from the inside .
While I was doing this I felt water dripping onto the front seat I. I pulled the roof lining away from the top of the passenger seat and a steady run of water came ****ing into the passenger side Orr the roof lining.
I let it all run roped up the water again in the sunroof channel and looked from the inside up to the sunroof under the lining.
It wasn’t the drain hole or drain tube leaking , but just next to it in 2 places water was getting in through 2 gaps in the sunroof plastic itself.
I only noticed it because I had the a pillar trim removed . With this in and the leak happening , the water would run straight down the a pillar . Down the dash and straight into the footwell, leaving no trace of a visible leak as was my case .
I have since had to rip all carpet and Enderley out of the passenger side.
I fixed the leak by going to Bunnings and Getty black marine sikaflex. $20.00.
Applied around the drain hole on the sunroof , problem fixed.
Old 26-05-2020, 02:07 PM   #6
Mondaveo
Mondaveo's Avatar
Thanks for posting your findings! As the owner of a sunroof Mondeo I'm greatly appreciative
2011 Mondeo MC Titanium TDCi wagon, Panther Black
- new Powershift sensor: Nov 2016
Originally Posted by rondeo View Post
Like 'Mondeo' is possibly Latin for gearbox anxiety.
Mondaveo is offline   Reply With Quote Multi-Quote with this Post
