06-11-2023, 08:01 PM | #3631 | ||
Giddy up.
Thanks mate, any recommendations on brand of lube etc, I think of the top of my head I had the RocknRoll stuff ?, it's up in the shed but I can't remember if this was the stuff I've got or not.
06-11-2023, 08:11 PM | #3632 | |||
Rob
Water based liquid wax lube. Designed more for off road than on so should suit you perfectly. Otherwise RocknRoll used to be ok from memory.
UA2 TREND 4WD BI TURBO |
06-11-2023, 08:19 PM | #3633 | |||
Rob
If the chain does get dirty and need cleaning I remove it from the bike and shake it in an old milk bottle with turps or metho. Let it dry fully then re fit (quick links are meant to be single use but i re use them) and re lube. I lube by putting a drop on each link, rather than squirting while rotating the chain. And yes, use a track pump. I have a topeak joe blow https://www.mtbdirect.com.au/product...oor-pump-black
07-11-2023, 08:08 AM | #3635 | |||
Cabover nut
Works a treat. Anyone here remember the super expensive Rohloff chains. They were like jewelry. Swapped between 2 so I would never get them dirty. Did last well though.
07-11-2023, 08:17 AM | #3636 | ||||
Barra Turbo > V8
Just be mindful if the bikes are set up tube less, most regular track pumps wont bead a tubeless tyre (ive managed to with my giant pump) although if they are tubeless can top up via the valve if needed without breaking the bead. Quote:
As for lube, another vote for Squirt, we also use this at work. Also another vote for Muc Off dry lube.
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
07-11-2023, 11:21 PM | #3637 | ||
Giddy up.
Can brake cleaner/degreaser be used on the chain ?.
08-11-2023, 08:24 AM | #3638 | ||
Barra Turbo > V8
We dont use brake cleaner on drivetrains (wouldnt hurt it i wouldnt think). But yeah no hassles using degreaser, used a few different brands over the years. When using degreaser i try to minimise contact with brake rotors/pads (again not a big issue).
08-12-2023, 01:50 PM | #3639 | ||
Rob
So back in July i finally picked up my new bike. Those following along would remember I had back surgery in July 2022.
Getting back on thy bike was short lived, possibly mostly due to my own impatience. Thinking that exercise would be good for me I went straight back to commuting 3-4 days a week. Lasted just over 2 weeks before I had to give the bike up again. Just did too much too soon and combined with the constant struggles at work, ended up feeling like back to square one. So last ride outdoors was Aug 14th. So long story short and after weeks of physio (and some enforced rest a month ago after covid finally got me) I am now keen to get back on the bike. I've done about 10 indoor trainer sessions and pull up ok afterwards, as long as I leave a day or so in between. Hopefully over the Xmas break I'll find time to get back out for a pootle around. It's too good a bike just to sit collecting dust.
08-12-2023, 01:59 PM | #3640 | ||
Rob
Regarding the indoor trainer for those who are interested.
I have a tacx flux 2. A few years back when I first got it I signed up to zwift but then cancelled and changed to fulgaz. Mainly because my wife also had a trainer and you could have 2 members on one account. I've since gone back to one trainer so cancelled fulgaz and signed up to trainerroad. I'm a bit of a nerdy numbers guy so while there is no virtual world or video to watch, I find the time on trainerroad really good. It's just no nonsense training. Really good with training plans and techniques etc. Alas, it's also very expensive ($30+/month)... I came across a relatively new player called mywhoosh. This is essentially the same as zwift and it's free! Its funded by UAE and has just partnered with UCI for 3 years. It works quite well and I've done 3 rides so far on it. The only downside is the minimum requirement for your device are quite high. My laptop was too old so wouldn't run it but I can run it off my phone. Just not as good looking at a 5in screen.
17-12-2023, 11:03 AM | #3641 | ||
Rob
Finally got back on the bike yesterday. Was great to be outdoors riding again. Took it nice and easy. I don't have a power meter (yet) and lost the crank magnet for the cadence sensor earlier in the year so it was quite liberating to just ride the bike and enjoy the scenery. A few complaints from my back but mostly it was ok. Am sore today but also did a bit of gardening yesterday as well which probably didn't help.
A gratuitous bike pic... Only noticed after taking the pic that my saddle is a bit nose high. Should be level. Adjusted it once I got home. Need some new bottles too.
17-12-2023, 03:14 PM | #3642 | ||
Barra Turbo > V8
Good to see you back on the bike Rob.
Went out for a pedal myself yesterday. Ebikes been gone since October, didnt ride it for about a month before. Almost all of the local trails here have been redone, most of for the better some they've tamed down a little which is fine also Also gave the forks a service with some new seals, they hadnt been serviced since i bought the bike and were running fine but you know, just incase. No wear found anywhere Got my Strava stats for the year, can tell when i stopped riding an ebike a little but i still kept on as much as i could. 115hrs of riding 174 active days Longest ride 35Km 2290Km ridden. (goal originally was 2500, but dropped it to 2000) 30500m climbed 55 Personal records 5KOMS (King of the mountain) Top 17% of all Strava users it tells me.
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance Last edited by DJM83; 17-12-2023 at 03:23 PM. |
03-01-2024, 10:15 PM | #3643 | ||
Ford screwed the Falcon
I did my first ride this afternoon since my body started showing negative reaction to the forced vaccinations I got in late 2021. Damn I am out of shape.
Falcon: 1960 - 2016 My cars Current ride 2016 FG X XR6 - 6 speed manual Previous rides 2009 FG XR6 - 6 speed auto 2006 BF MkII XT ESP - 6 speed auto 2003 BA XT V8 - 5 speed manual 1999 AU Forte - 5 speed manual 1997 EL Fairmont - 4 speed auto 1990 EAII Fairmont Ghia - 4 speed auto |
04-01-2024, 07:34 AM | #3644 | ||
Cabover nut
You wouldn't want to ride around here then and I'm only walking atm.
14-02-2024, 08:05 PM | #3645 | ||
Barra Turbo > V8
Ive been pretty lucky with flats of recent, that was until i had some new wheels built up.
2 weeks ago i hit a couple rocks, even with tyre inserts one of the hits pinched a hole in the sidewall of the tyre. So it was pretty much useless and i ruined it a little more riding home. This week after i reluctantly fitted a new Maxxis Forekaster (New design) i managed to do the same thing yesterday, tyre survived but another decent dint in the rear. Bit frustrated if im honest that ive managed to put a few dints in a stronger wheel. Is what it is, wheel still runs true not that it matters. Im not a maxxis fan, but this forekaster (thin sidewall aside) is pretty bloody good. Its like a summer kinda tyre and it rolls and rolls and then some. Ive got some Michelins ready to go on when i need to, they were my go to but were U/A for quite a while.
14-02-2024, 08:33 PM | #3646 | ||
Living the Dream
5 users like this post: |
15-02-2024, 12:31 PM | #3647 | |||
Cabover nut
I've spotted for the first time this Summer in Victoria's NE, bloody cathead grass (spiny emex) growing this side of the Murray. Horrid stuff grows everywhere in the Newcastle / Hunter Valley region.
16-02-2024, 05:52 PM | #3648 | ||
Barra Turbo > V8
New tyres arrived, but i might wait until i get some wear from the rear tyre i fitted last week
17-02-2024, 12:42 AM | #3649 | ||
I rode to Jells Park last night. The damage caused by Tuesday's storm was very evident. Many fallen trees on the path and debris everywhere. I needed to dismount several times to climb over the trees. Near the Police Paddocks was the worst section.
21-02-2024, 08:57 PM | #3650 | ||
Living the Dream
Port Campbell ride to Timboon and back after work.
10-04-2024, 04:00 PM | #3651 | ||
Barra Turbo > V8
Ive had my current Norco Sight for 3 years today ive thought about moving it on, but i dont think i will. Its probably been the best bike ive owned (dont we all say that about the current bike we own )
Got a couple of (at least one) race/s coming up next month, back to back weekends. I raced them both a couple of years ago (the 5 stage gravity enduro event i got P2 in category, below pic). I got super nervous doing it, and probably will again. But i see it now as another time just out riding my bike, just a little more intense. Also hoping McKayos at Falls Creek comes back this year, absolute blast the events gone by but got cancelled the last few years.
11-04-2024, 05:29 PM | #3652 | |||
11-04-2024, 05:31 PM | #3653 | ||
Degreaser is a big issue if it gets on rotors or pads
11-04-2024, 05:32 PM | #3654 | ||
Would you use cheap stuff on your ford ???? chain lube the best is rock and roll google the reviews
11-04-2024, 05:38 PM | #3655 | |||
Rob
I've used SQUIRT for years and get very good chain/cassette life
11-04-2024, 06:50 PM | #3656 | ||||
Barra Turbo > V8
Also working in a bike shop makes my decision easier. Quote:
Ive also had degreaser on my brake rotor accidently, more than once and its never posed a problem. Brake cleaner fixed it.
12-04-2024, 11:50 AM | #3657 | |||
21-04-2024, 04:00 PM | #3658 | ||
Barra Turbo > V8
Entered the local gravity enduro round coming up (podiumed 2 years ago in the sport category). 7 stages, that'll take a toll on the legs, liaison stages here can be tough even though i ride em all the time. That said ive ridden more kms this year than any other year at this point. 920kms 13000m Climbed. No ebikes. Also fitted new tyres to it, the maxxis i had on the rear, whilst it rolled well the soft tyre casing couldnt take decent hits and it showed as my rear wheel had a few dents. Managed to lose my AXS battery cover, no idea how. Because im OCD ive ordered another. This was the cushcore insert i pulled out, did its job to a certain extent. It does look like someone has been chewing on it
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance Last edited by DJM83; 21-04-2024 at 04:18 PM. |
15-05-2024, 05:20 PM | #3659 | ||
Barra Turbo > V8
“A fox is a wolf who sends flowers.” — Ruth Brown
Ive been debating a new bike for a bit, but i couldnt justify it until i seen this. It has big shoes to fill but we'll see, price was better than good also 2023 Mondraker Foxy XR Carbon. Made a few changes to suit me like tyres/mudguard/bigger rotors. Ride wrapped it also (My first go) ill need to practice more on that topic. Also a few pics from the last cpl weeks racin. Point to point race cpl weeks ago. Finished 20/39. Issue with my race plate that still isnt sorted. Last weekend 7 stage gravity enduro. This was fun, sadly only 4 in my category. Ended up P2 My Norco has served me well, and if the new bike isnt right it'll stay on longer.
