Old 17-07-2024, 04:36 PM   #2041
GTLEGEND
Originally Posted by wickerd View Post
Hi.I’m looking for a vrs gasket set to suit Boss 260 32v (2004 BA xr8 Ute)… any suggestions ? . I know that cheap ones aren’t necessarily good and good ones aren’t necessarily cheap .. any suggestions or advice would greatly appreciated . cheers
There used to be a genuine VRS kit for the 260 Boss,part number BAFP6079B, how ever long obsolete.
Suggest you try someone like Rocket Industries to see if there is an aftermarket equivalent through a brand like Fel Pro or the alike.
Maybe contact Herrod Performance in Melbourne who worked on this things as well.
Old 17-07-2024, 04:53 PM   #2042
GTLEGEND
Originally Posted by Baminator View Post
Howdy GT,
This may be a bit of a Hail Mary, but I'm looking for an Idle Speed Controller for my 1997 XH Falcon 4ltr. Figured it couldn't hurt to ask if any Genuine Ford NOS is still floating about, and if you even just happened to know the Ford part # that would be fantastic.
Cheers,
the Baminator
Hi mate,
More information required, GLi, Outback, XR etc? Even a VIN will help.
GT
Old 17-07-2024, 06:53 PM   #2043
GTLEGEND
Originally Posted by fgpsi View Post
Hi , GTLEGEND
Do you have or do you know where I can get some fresh airbox torx screws for the FG Falcons. Also anyone know what size they are/ part number
Have a look below and advise which screw you are referring to. Note this is for 4.0L NA or Lpi, Turbo, V8 and earlier LPG vehicles have slightly different housings, which one are you referring to?
Old 17-07-2024, 07:35 PM   #2044
fgpsi
Attachment 107396
Thanks for the reply GTLEGEND
It's for an NA FG Mk II xr6. Looking at the image you uploaded its 9B600
fgpsi is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2024, 09:05 PM   #2045
GTLEGEND
Part number is BG9B600C, unfortunately obsolete.
Old 17-07-2024, 09:24 PM   #2046
fgpsi
Damn that sucks . Wonder what I could use instead
Old 17-07-2024, 10:09 PM   #2047
GTLEGEND
I would check out you local wreckes and get one from there, keep it all original..
Old 17-07-2024, 11:32 PM   #2048
gassa
Hi Mate
I think i have a few screws if needed
Gassa
gassa is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2024, 12:23 AM   #2049
Baminator
'97 XH Falcon Longreach
Hi mate,
GT
Yeah no worries didn't realise I'd left you high and dry for info. Just a plain old GLi running the log manifold. Not a BBM car sadly, although I thought all XH 4.0's had the same ISC?
Hope that helps.
Baminator is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2024, 08:46 AM   #2050
GTLEGEND
Hope that helps.
The 4L ISC are all the same, V8 is different, but there are different sections of the catalogue and just wanted to make sure I was on the right one.
EF9F715A is part number, will check later and get back to you.
Old 18-07-2024, 10:08 AM   #2051
GTLEGEND
No luck on the EF9F715A, keep an eye out on the usual places.
Old 18-07-2024, 08:44 PM   #2052
Baminator
All good, thanks heaps GT.
Old 19-07-2024, 07:45 PM   #2053
mad2
Regular...with metamusal
Hi Legend
question today is - the 'egg crates' that support the front bumper, when did they change from the plain?.
examples below
the black lower pair are what i know/believe were standard on BA/BF, but i have NO idea what the white/black upper pair are off?. any chance you could explain what's the go is?.
Thanks
Ps.i believe the upper pair do not fit the later BF2 bumper.
Old 19-07-2024, 10:21 PM   #2054
GTLEGEND
Originally Posted by mad2 View Post
Hi Legend
examples below
Thanks
Hey mate,
Here are the relavent part numbers:
For BA BF XT, Futura, Fairmont, XR, Ghia, XL, XLT, RTV & All FPV
BAF217D926A: RHS 7/2002-9/2005
BAF17D926A: RHS 10/2005- 9/2006
BAF217D927A: LHS 7/2002-9/2005
BAF17D927A: LHS 10/2005-9/2006
BAF217D926A: RHS 10/2006 on
BAF217D927A: LHS 10/2006 on
LWB Fairlane/LTD take the below for all:
BAF217D926A: RHS
BAF217D927A: LHS
Hope that answers your question.
Old Yesterday, 08:52 AM   #2055
mad2
Hey mate,
BAF217D926A: RHS
BAF217D927A: LHS
Thanks Legend, with that 09/2006 timeline is that roughly when they changed the front springs from the earlier BA shape?.
best see IF i canna find some part numbers on em 'crates' ......
cheers
Old Yesterday, 10:54 AM   #2056
bondy99
The white I have is on the AU2, both front and rear.
bondy99 is offline   Reply With Quote Multi-Quote with this Post
Old Yesterday, 11:08 AM   #2057
mad2
the white shown is not the same as the one you have on the AU and is only fitted to the front.
Old Yesterday, 11:30 AM   #2058
bondy99
Might not be identical but I do have those fitted at the back, that's what was seen when we took the rear bumper off and towbar, CS123 had seen them also.
Old Yesterday, 05:51 PM   #2059
GTLEGEND
cheers
Front spring change in BA seemed to happen around 7 or 8/2007 pending on model.
