Old 23-09-2024, 10:11 PM   #1
T3rminator
T3rminator's Avatar
Default BA Falcon headlight low beam height adjustment
Hi, someone here previously posted instructions on how to calculate the low beam headlight height for the B series falcon. It was a couple of years ago and I can't find that thread.
Does anyone have the instructions?
Rides (past and present)
Old 23-09-2024, 10:20 PM   #2
arm79
arm79's Avatar
Default Re: BA Falcon headlight low beam height adjustment
https://fordforums.com.au/wsmpub/ba/417-01.html
Page 48 and 49.
arm79 is online now   Reply With Quote Multi-Quote with this Post
Old 23-09-2024, 10:40 PM   #3
T3rminator
T3rminator's Avatar
Thanks man!
Old 24-09-2024, 03:51 PM   #4
T3rminator
T3rminator's Avatar
Hey just want to make sure I'm reading this right. If the bulb is 640mm off the ground, then the cut off beam should be 640mm at a distance of 5m.
Am I reading it correctly?
Old 24-09-2024, 09:08 PM   #5
arm79
arm79's Avatar
Nope...
The horizontal aimpoint should be 11mm lower than the height of the bulb centre for every meter of distance the wall you are aiming at is away from the bulb centre.
So if the wall is 5m away, the aim point will be 55mm lower than the bulb centre. 585mm.
