#31 | ||||
Custom user title
Who cares they only would of had to push 1500 of them since they sold so well... ANd i agrea why the hell would they assemble the boss motors here then ship them back Quote:
ANd i so could not see ANY tickford l6 engine being shiped to england then to australia.. THats just crazy talk.. THey all ran down the geelong production line pretty much just the same, with the same arvo shift nuffies building them as the taxi motor next to them. in fact the bottom ends are the same.. so why would they ship the motor to england then back again Last edited by INJECTED_250; 13-04-2006 at 10:00 PM. |
#32 | |||
Yes the US Ford variants get the 2v and 3v versions (as in the 220kw Barra) and the Lincolns get the quad cam... if they didnt, then Ford AUstralia would have had to design and manufacture their own parts... they didnt do that, but they did build the engine using the best parts they could. |
#33 | |||
#34 | |||
GT
#35 | ||
me may my mo
Why wouldn't they use it? Isnt the BOSS engines the most powerful n/a production V8 that Ford has right now? Im pretty sure it is.
Also to gtfpv, isnt aluminium alloy stronger and lighter? ive heard the only advantage cast iron has is its ability to withstand high temperatures. |
#36 | |||
Solution Was Boost 4?, 6 & 8
It was suggested that most likely we will see a change in the Head, we will have to wait and see.
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
#37 | |||
LPG > You
LPG Lovers Association President & Member #1. ![]() ![]() |
#38 | |||
#39 | ||||
Guy that posts stuff
http://www.orig.green.net.au/mellor/...n?OpenDocument Quote:
If FoMoCo does drop the 32v head for the 5.4's, then I guess it will be up to Australia to engineer new ones. We have head manufacturing ability here in OZ, we could update it to put VCT on atleast one of the Cams.. |
#40 | ||
Performance moderator
![]() Join Date: Feb 2005
There are heaps of navigators there two years ago with 32 valve heads...
Costs are higher here due to cost per unit, we don't have big enough market so cost per unit is high..Even if labour was $5 and executives got $10 an hour cost of setting up plant would still be high per unit..Btw our AU to U.S is not high...73c...
#41 | |||
me may my mo
#42 | ||
BOSS 5.4L Enthusiast
5.0L Cammer is a pretty expensive option and i would doubt evan a chance for Euro 3.
#43 | ||
Ute Forum Moderator
![]() Join Date: Dec 2004
The Tickford XR6 engine was developed in the UK as well as locally. All engine production was local, they didn't differ that much from normal sixes, eg at least in the early years instead of making specific valve springs they used the stiffest 10% of the existing type, which was adequate.
Given the Lincoln Navigator uses a superficially similar engine and we still have Boss assembly locally it is not a guarantee that it will be dropped, it is useful for the local arm to be able to do what they want not what the 20x larger US market wants. As mentioned already higher volumes can only be a good thing though, higher r&d and better economy of scale. |
#44 | |||
What I was getting at is, why would Ford US want our Boss engine, in limited numbers, when they already have the tooling etc to make a more ' desireable' engine in their own back yard. Couple that it's a limited edition, with the fact it has an engine 'marketed' as related to the flagship of Fords range ( GT ), and the die hards will be breaking down the doors. |
#45 | |||
Peter Car
As for the Boss engine it would more likely the Americans could use the engine but they would just take a few from here and copy our inlet manifold and make the other parts to the same specs as ours but assembly them over there. Would make it cheaper as the development has already been done, they would only have to adapt it for their application. It would still be a Boss engine but it would be slightly different. Either that or they buy our inlets and other unique parts from us and assembly them over there. FPV could also build them for the US if it was for a special build that was limited in numbers. I don't see how thats any different to Holden making Saab engines and shipping them to Sweden for fitment. |
