Old 21-05-2005, 02:40 AM   #31
EFFalcon
Last warning
EFFalcon's Avatar
Originally Posted by Sundeep
If it works who gives a **** George. Mine works good, and the original Ford cast prototypes are pretty similar. Same sort of design etc. but the flange is in the centre.
Sundeep
obviously a lot of ppl care... hence why they're not using this manifold.
ofcourse it works, but there is better.. simple as that :P
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 21-05-2005, 12:55 PM   #32
FPVWEPN
Team Urinal Cake Racing
FPVWEPN's Avatar
well if your gonna go to all the trouble of going turbo u may aswell do it properly instead of some "lebo" style manifold! which leads me to the question of why you are turboing in the first place? for an increase in performance or so you can brag to all ur mates?
FPVWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2005, 01:03 PM   #33
dansedgli
dansedgli's Avatar
It all depends what your after, a manifold like sunny's probably wont restrict anything until you start looking for power upwards of 18psi. I have no doubt Sunny's car will make more than 180rwkw when its intercooled and tuned. Without wanting to spend $3K on a fuel system I'd be pretty happy with that.
If it works why change it? The only benefits a $1500 manifold will give will be slightly earlier spooling time and maybe a tiny bit more power when you start looking for big power. Its completely unnecessary to spend the extra when your goal is only 200rwkw or less.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2005, 01:19 PM   #34
EA Turbo Ghia
Motor breaker
ok, this is my old manifold and it has no cracks, there was quite a lot of work involved in producing this manifold, it has been cnc machined out and they are cast steel not cast iron which is weldable.
I no longer own this manifold, it is being sold by its new owner, but i did have exceptionally good results with it, and obtain well into the 300rwkw mark with it, the inside as i said was totally cnc machined out so it has excellent flow, if anyone has any questions then they should pm, since we built this.
EA Turbo Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2005, 01:34 PM   #35
EA Turbo Ghia
Motor breaker
Oh i will ad that regardless on manifold designed, its the turbo that is the main restriction, always is, always will be regardless of manifold design. True a better designed manifold will improve top end performance, but hey i had 271rwkw's at 11psi with this, on a blue printed balance standard EF motor, otherwise stock, no head work, no cam. And we had massive improvements on its way up to 18psi, but never got to get a dyno print out to back it up, but it was well over the 300rwkw's mark, until i had someone destroy my turbo.
And as for cylinder pressures has the people saying this bothed to actually look inside one of these manifolds? They are quite well designed, the front 3 and back 3 come into the outlet and equally seperate, now all you need to do is machine it and redirect it so that if flows correctly out the outlet that is now on the side, with a nicely machined path for the exhaust gas to exit into the turbo.
Old 21-05-2005, 10:03 PM   #36
Sundeep
Sundeep's Avatar
Originally Posted by EFFalcon
obviously a lot of ppl care... hence why they're not using this manifold. ofcourse it works, but there is better.. simple as that
Yeah those "better" manifolded turbo projects take 15 years, because you guys take your time to sit back and "research" and save cash for the expensive manifolds, which is retarded unless you're looking for 11's. I'm gunna be running high 13's in no time. This manifold would be great for someone looking for good gains without spending top dollar, so there's no reason to dismiss it as shit if it's not what you're on the market for.
This aint no leb style manifold. It's sick. Actually it is leb styles, and it's sick and it works. I'll race ya when it's done bro :o) I'm turboing it for all of the above ;) If you look at the manifolds that Ford designed/made when they were considering a turbo variant for the EAs, you'll see heaps of similarities with this one.
To add to that, look what EA Turbo Ghia said. You guys got shut down. I'm looking for good street performance not a "only driven to track and dyno days" car, and this manifold will do that for me.
I hate ****s that criticise people who are trying to do shit cheaper. If it works, don't question it.
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2005, 12:33 AM   #37
EA Turbo Ghia
Motor breaker
Nicely said sundeep, i will also add that these power figures were obtained with a IHI RHB6 turbo that pictures where placed on here and many ford forums people had question'd it's size and made comments that it was way too small, in comparison to garrett yes a garrett that size would be too small, but for an IHI it was plenty big enough, for those of you that did doubt it the proof is in the figures, insadently that turbo got destroyed by a piece of metal going through the compressor wheel, curtious of an exhaust shop who made me a nice 3 inch intake and fitted it without cleaning it, it was then replace with 3 different Garrett turbo combinations and none of them compared in any way, in my personal opinion if i was to do it all again i would get twin IHI RHF5's off WRX's commonly seen on ebay and run them, on another lebo style manifold.
Old 22-05-2005, 03:29 AM   #38
FPVWEPN
FPVWEPN's Avatar
ok sunny ill run ya turbo 6 Vs N/A 6!!!!!!!!!
Old 22-05-2005, 03:36 AM   #39
EFFalcon
Last warning
EFFalcon's Avatar
i never said it was a shit manifold.
i simply said there is better, and no one can argue that fact.
despite the claim of the turbo being the main restriction and a good manifold only improving top end, we also know it can improve spooling times.. which IN A STREET CAR matters.
Old 22-05-2005, 03:36 AM   #40
EFFalcon
Last warning
EFFalcon's Avatar
as it stands u'll kill his car ;)
Old 22-05-2005, 11:10 AM   #41
ilsautomotive
Former E-Series Member
Relax peoples, just a discussion.
I do have a question, how much would it cost to have the stock manifold high flowed, welded etc? Considering custom ones start from several hundred dollars there would want to be a half reasonable saving...
Old 22-05-2005, 11:23 AM   #42
dansedgli
dansedgli's Avatar
How much can Dave get his manifolds for now? I think other than modding the stock manifold, which would get expensive if you cant do it yourself, that would be the cheapest option.
We need more turbo falcons! Jack you're up!!
Old 22-05-2005, 12:52 PM   #43
EFFalcon
Last warning
EFFalcon's Avatar
if i get my hands on the manifold like dave's, then i think that is 100% the way to go.
i was amazed at the price i was given, but i won't say anything about it until i actually have it in my hands and dave gives the ok :P
Old 22-05-2005, 12:54 PM   #44
dansedgli
dansedgli's Avatar
Nice thats another turbo falcon on the way
Old 22-05-2005, 01:14 PM   #45
FPVWEPN
FPVWEPN's Avatar
well ill let him get his cooler and tune it then well run fair and square
Old 22-05-2005, 01:18 PM   #46
dansedgli
dansedgli's Avatar
I dont like your chances then!! :
Old 22-05-2005, 11:56 PM   #47
Sundeep
Sundeep's Avatar
Yeah, key words "as it stands". I'll also have my turbo project finished for under $2k, where most are spending ~$6k+ and the 1/4 times will amount to jack shit differences for the extra amount.
Rollin, I'm about to mod my sig.
Sundeep
Old 22-05-2005, 11:57 PM   #48
Sundeep
Sundeep's Avatar
Man I can't believe it, I'm turning in to Yagz.
Sundeep
Old 23-05-2005, 02:00 AM   #49
FPVWEPN
FPVWEPN's Avatar
errrr i sorta do like my chances actually
Old 23-05-2005, 08:42 AM   #50
dansedgli
dansedgli's Avatar
I dont :
Teh turbo can nevar lose! :
Old 23-05-2005, 07:35 PM   #51
Qwikcorty
V8 Turbo Hoon
Qwikcorty's Avatar
i kept beside sunny in my blue bbq at the last meet lol, nah his leb machine goes good, i went for a ride in it sunday after chopping his car up with a grinder!
Qwikcorty is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2005, 07:51 PM   #52
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
I think this thread is great.
I think "leb style manifold" needs to go to collins. That is just hilarious.
TURBOTAXI is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2005, 07:54 PM   #53
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
Can I suggest Bankstown special manifold
Old 23-05-2005, 09:08 PM   #54
Sundeep
Sundeep's Avatar
I'm changing it to Punjabi, siff I'd give Lebs the credit.
Eh George, once the cooler's in we'll have a mini meet up your way. I'll beat you bitch, turbo's are tip top veer ;)
Sundeep
Old 25-05-2005, 01:57 PM   #55
FPVWEPN
FPVWEPN's Avatar
sweet looking forward to this
Old 25-05-2005, 03:45 PM   #56
mcflux
mcflux's Avatar
Is bankstown really that, umm, famous? (kinda like an ethnic Moe?)
Here's a Bankstown guy (I know his sister, she drives a 302W XW ) with his new manifold (non-leb-spec) ;) ;)
-Dave-
Old 25-05-2005, 05:01 PM   #57
Supa R00
Rolling on Simmons...
Supa R00's Avatar
hahah rofl, what a classic!
The daily hack...
1994 ED
XR6
5Spd, Simmons FR17"s, SupaLow's, Sprint Bodykit,
Cam, exhaust and all that jazz... Complete AU XR6 conversion and soon to be turbo!
:voldar02:
Originally Posted by Walkinshaw
When has any XR6 after the ED, prior to the XR6T been anywhere near being a performance car, or much more of a car than a stock taxi spec Gli?
Supa R00 is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2005, 06:48 PM   #58
falconpower351
falconpower351's Avatar
-Dave-
I took that pic!! Still makes me laugh. Thanks for the plug Dave! :voldar02:
falconpower351 is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2005, 08:33 PM   #59
mcflux
mcflux's Avatar
Good to see you've finally posted
Old 28-05-2005, 04:51 PM   #60
Qwikcorty
V8 Turbo Hoon
Qwikcorty's Avatar
just to keep this thread alive, look what i made today sunny
