#31 | |||
Cam Luncheon
-- Any problem is best approached sideways ... with a crowbar --
-Mental on Life, the Universe and Everything. |
#32 | ||
re
Location: Victoria - where being slow & incompetent is considered being "safe"
Bring on carbon composite wheel rims with aluminium hubs!!
The American car engineer/designer Pete Brock pricked up his ears when he heard about the solar racers outcornering their support vehicles. The racers which were designed for straight line efficiency on spindly narrow lightweight wheels on low-resistance tyres where outcornering the utes and pickups. He reckoned that lighter wheels had a cascade effect on a car design – lighter control arms, lighter unsprung mass, lighter mounting points, smaller brakes required, etc. Start off with light wheels and the resulting car is a lot more efficient. It absolutely killed me when my dedicated track wheels (Honda Enkei CRV alloys) were slightly heavier than my road wheels (Honda Enkei Type R alloys) but at only $100 each they were hard to knock back. Metal weighs more than rubber and Porsche (engineers not the marketing people) were saying anything under 50 series tyres are hard to justify. Have a look at how heavy the DUB style chromies are for a scare when compared to stock alloys or even better forged alloys.
Scuderia Rev: Otto the tow pig - 2007 3.0 litre Coupé, vernünftig schnelle aber kein peilstab, Bathurst 2007 und 2010 zwölf Stunde Gewinner Jaffa the angry ant - mid 70's Honda 市民の, 73 と立方インチ LSD Elle "the body" shell - early 70's Datsun フェアレディ coupe. いい体は彼女の内側、内側と土台を待つ |
#33 | ||
The lower you go in tyre profile the more "onus" you place on the cars suspension to do its job properly. Low profile tyres rely on the cars suspension to absorb all the bumps and control deflection as well as maintain proper tyre contact with the road..
Unless you drive on billiard table smooth roads all the time tyres with too low a profile can actually reduce handling performance.
335 S/C GT: The new KING of Australian made performance cars.. ![]() |
#34 | ||
Critical Thinker
This is a good thread guys. I didnt have much of an idea on 'unsprung weight' and the like. But it seems as though, if you want your car to look good, handle well, and be affordable. Wheel diameter should be no bigger than 18"?
Personally speaking I am in 2 minds. I like the 15" Centreline's/Welds on old skool cars, but I also like seeing 17-18" simmons on them too or similar. Both styles are excellent wheels. Could convo's be use on track work? I dont know.
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
#35 | |||
I know someone with weld pro stars and he did a hill climb in his XB and the cornering loads bent the spokes of the wheel and caused it to seperate and deflate.. Here's a pic: quite scary when you see what a bit of spirited track driving does to these types of rims.. http://img.photobucket.com/albums/v5...ltofA0032R.jpg
335 S/C GT: The new KING of Australian made performance cars.. ![]() Last edited by 4Vman; 08-01-2008 at 11:14 AM. |
#36 | |||
#37 | ||||
#38 | ||
Critical Thinker
wow, that is amazing 4Vman. I can see the logic. Depending on application, its better to get wheels to suit what you do.
Do you think the width of the rim had any effect on why that wheel buckled like that?
#39 | ||
If you want the best compromise, get some 18" rims and buy some quality rubber for them - Michellin, Pirelli etc. If you wanna be hardcore, import some Advans, or Volk/Rays or something. They're extremely light weight racing rims.
#40 | |||
xgs351 is spot on about rims dia.. the brake dia generally dictates the rim dia used, i.e for racecars, especially open wheelers they use the smallest dia possible dictated by brake caliper clearance, that way they maintain as much sidewall as possible to aid tyre life and durability as well as some cushioning by the tyre to maintain contact with the track.. Of coarse with heavier cars like sedans too much sidewall will make steering vague and create too much sidewall flex so there has to be a balance as well.
#41 | |||
Peter Car
I remember reading a little while ago that once you go lower than a 40 aspect ratio for tyres you start to lose sidewall strength and handling decreases. So for Falcons thats usually a 17 inch rim, the same as used by V8 Supercars. |
#42 | ||
Critical Thinker
hmm makes a lot of sense. I for one would want handling performance over looks. But if you can get both, then your winning. Of course depending on your application.
For me, its handling and straight line performance for street only, so in saying that, it would have to be a wheel between 15-17" with a width of no less than 7". On a falcon that is.
#43 | |||
#44 | |||
#45 | ||
I've got 19's. Can only go as fast as the speed limit. Doesn't matter how quick your car is or how big the wheels you'll still hit the speed limit.
#46 | |||
Oo\===/oO
don't for get on most open wheelers the side wall accounts for 1/3-1/2 or suspention travel... |
#47 | ||
Bseries Moderator
I went from 195/65/14 to 205/40ithink/17 on my e30. handling improved 1000 fold. im not sure whether its the tyre but before the car slid all over the place and handled no better than a ba xt falcon.
The overall diameter of the wheel and tyre is just a touch smaller than the 14's because of the tyre profile but the difference in handling was phenomenal. The new tyres are chinese brand jintong and the old ones were falken. go figure.
Long Live the Rugerspeed Primer Destroyer! Only those that attempt the absurd achieve the impossible. Serviced and maintained by Mascot Auto Repairs
#48 | ||
when it comes down to it most people who fit 18inch and up wheels are doing it for looks if you were serious about track days and hill climbs youd obviously set yourself up that way but for most regular joes i doubt there would be much diffrence when your doing 60.
#49 | ||
Oo\===/oO
even if you bought a wheel for racing and for its advantages in weight/strength/perfomance, your still going to choose one that looks good in the end...
#50 | |||
It is also worth mentioning that open wheelers don't run a lot of tyre pressure. My car cold runs 14 PSI front and 16 PSI rear. |
#51 | |||
LPG > You
LPG Lovers Association President & Member #1. ![]() ![]() |
#52 | |||
re
I’d just read about the Dymag (UK) composite wheels and mentioned it to them, they pointed me to their own composite wheels and suggest that I try lifting them. Incredibly light. Tried lifting one of the Porsche 911 BBS racing wheels (rear) later on and they were much heavier than I was anticipating.
#53 | ||
the biggest i will go is 18" and ill have them either 8" or 9" wide. i cant afford wider :P
ive got 17x8's atm and they are alot better then the 16x6 stockies
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery! Insta@mooneye_ghia White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly |
