Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Ford Coupe Club of Australia > Coupe Restoration & Build
Old 20-10-2011, 11:43 PM   #31
xbrules
/[_][_]==DMC==[_][_]\
xbrules's Avatar
Default Re: XA Fairmont Coupe
Any updates Kerry
Dave - Luxobarge Enthusiast.
Daily: AU series 1 Fairmont Ghia
The Classic: Jan 79 ZH Fairlane, EFI'd 302 Clevo
The Project: Aug 73 Ford Landau Hardtop
During his lifetime, the average man will spend around 5 years behind the wheel of his car.... Make those years count... Drive a Ford.
xbrules is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2011, 12:35 AM   #32
Apollo66
My toy
Apollo66's Avatar
Location: South Ozz on the only leg Australia has to stand on
Sorry for the delayed response Dave, haven't done a lot at this stage, did a trip over to Geelong & Melbourne back in September and picked up two pairs of XA front guards ( one pair are mint ) a good bonnet and a grill in top condition. Been buying up the brackets etc needed to return the front back to an XA.
Engine wise, I've pulled the 460 down and I'm very happy with the internals, so all it will receive atm is a freshen up put back to standard for engineering. Later it will receive a major overhaul (already have some of the goody's needed to liven it up in the cupboard).
Still trying to work out wot wheels we're going to use, I've already got a pair of M/T slicks for a bit of straight line fun.
Just working out a bit of time off early next year to start on the body. Been flat out at work of late but I'm itchen to get started especially after having a couple of runs down the 1/4 mile at heafcote in the XB. Bought another toy (Honda CBR1100 Blackbird) which has taken up a bit of time but it's almost sorted now, (this thing rockets)
Untill next time
Cheers Kerry
Apollo66 is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2012, 12:26 AM   #33
Apollo66
My toy
Apollo66's Avatar
Small update, been busy reassembling the engine, two of the bores are marked up from water been in them but they should do for the short time this engine will be used. The wear in the bores wasn't to bad so all they got was a bit of a hone (Will be bored out .030" when redone.
Striped the heads and found the valves only needed miner attention, guides were good just faced the valves and re-cut the seats, lapped them in and all was good.
Polished the crank journals, checked the clearance's and all in specs, so for a cheep dodgy rebuild it should run ok.
Still striping the last of the parts out of the shell so hopeing to make a mark soon.
Cheers Kerry
Old 27-03-2012, 11:53 PM   #34
Apollo66
My toy
Apollo66's Avatar
Engine all but done, going to fire it up in a few weeks then tuck it away for when the rest of the coupe catches up and needs it.
untill next time, cheers Kerry
Old 14-05-2012, 12:42 AM   #35
Apollo66
My toy
Apollo66's Avatar
Well I might as well put up the bad with the good.
Fired up the engine, it run for approx 3 seconds, first 1.5 sounded good, started on third compression started working the rev's up, then all turned pair shape in the second half of the 3 seconds. It took about 1.5 seconds for it to come to a rattly stop .
So with this been a bare bones budget build for the initial registration of the car (lucky if it would do 1000km before been fully rebuilt), there could be a few possibility's of old parts not wonting to do there job.
Pulled the inlet and rocker covers and all looked good which was actually bad, drop the sump and found a few parts not where they should be.
It broke the head off a big end bolt and it all parted company, with the sudden rise in the oil level and the fact I drain about half the coolant out of the sump I'd say the block is toasted. Should make a nice table, just need to measure up for the glass top.
So it's back to the drawing board, still wanting to run a BB, plus I still have a few boxes of nice parts to use up.
Few pic's of the death rattled parts.
Lesson to be learned here is don't skimp on the hard ware
Untill next time
cheers Kerry
Old 14-05-2012, 10:34 AM   #36
Tha Jack
Legend!!!
Tha Jack's Avatar
ouch, thats gotta hurt!!!
BARE BONES RACING
BACK TO THE BONE YARD
Tha Jack is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2012, 10:50 AM   #37
GTB 351
GTB 351's Avatar
Sorry to hear about that Kerry.
I know somebody with a few 460's stashed away if you need another core.
Those stock 460 rods were always a bit on the wimpy side. Hope the water was only from the head gasket letting go after the piston hit the head.
The Car -
http://www.fordforums.com.au/showthread.php?t=11358570
The Engine Rebuild-
http://www.fordforums.com.au/showthread.php?t=11361067
GTB 351 is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2012, 01:40 PM   #38
74xbkoop
74xbkoop
74xbkoop's Avatar
Damn!!
Sounds like "Murphy" is over your way at the moment. Keep him there I have had enough of him lately. Isn't it always the way 1 step forward 2 steps back. Why do we do it to ourselves? Hope Michelle isn't too upset for breaking "her" car.
See Ya
Anthony
74xbkoop is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2012, 09:26 PM   #39
Apollo66
My toy
Apollo66's Avatar
I knew I was taking a chance on some of the parts, cost wise it's only set me back approx $400 for parts as the engine was a freebie. The painfull part is it's buggered a good block. The coolent was still running out after I drain radiator and pulled the sump, only a guess but the bottom of the bore isn't looking good an the piston has turned so good chance it split the bore.
I'll work out over the next few weeks which way i'll go, but i'm still heading down the BB path.
Originally Posted by 74xbkoop
Damn!!
See Ya
Anthony
Michelle didn't think it sounded good from the house so she got a cold beer ready for when I emerged from the shed.
Old 14-05-2012, 09:35 PM   #40
gcg2503
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always adding valued comments,  never involved in any disputes. A credit to this forum.
Sorry to hear
Top woman having a cold one ready though!
gcg2503 is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2012, 12:28 AM   #41
GTB 351
GTB 351's Avatar
Haha, mine only has the tongue lashing waiting for me. I can't even stir her up about her unreliable holden as the GT has the domino effect of problems at the mo!
The Car -
The Engine Rebuild-
Old 15-05-2012, 09:41 AM   #42
74xbkoop
74xbkoop
74xbkoop's Avatar
Sounds familiar Glen,
Mines got an acid tongue and the coupe is a dirty word in our house. Some people are lucky!
Old 15-05-2012, 05:58 PM   #43
ianxy351
more cubes please...
ianxy351's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his technical knowledge with members.
Bad luck Kerry. Very sad to see a death rattle like that. All of us who build engines have had at least one die a violent death. My last violent end was a 460 BBF that detonated at 7000rpm mid track. Not my engine but I built it. Felt awful about it. Had a rod bolt let go and the resultant mess included holes in both sides of the block. Not pretty.
Original T-code XE S-pack. Project thread: http://www.fordforums.com.au/showthread.php?t=11293740
XY Wagon - 351C with 2V AFD alloys, Toploader & 9 inch, GT interior - 13.3 @ 109
XB Hardtop big block project ... I'll get to it one day
1967 FJ40 Landcruiser 'Rusty'
ianxy351 is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2012, 12:11 PM   #44
XAanimal
XAanimal's Avatar
Good to hear you are gonna stick with the 460 BB in the coupe, not many people go with that. I hope its all going well
XAanimal is offline   Reply With Quote Multi-Quote with this Post
