Closed Thread
Old 24-06-2011, 12:36 PM   #31
Malow
Default Re: I Do not recomend this company...
Hi All
This is James Cloke ,Owner of Tubular Suspension Systems
Was made aware of this the other day so I thought I would clear a few things up
DW Customs was my dealer in Vic until they closed
DW Customs asked me to make a strut for the BA Falcon
TSS made the struts for them and DW did the rest
10 months ago DW asked if TSS could do the same struts for the FG
I rang Koni as the customer wanted Konis and they sent me the struts
I fitted the same bags to them and sent them to DW to work out the rest
I found out later on that the strut were infact BA not FG as i ordered but apart from the width of the bottom mount and spring plate they were similar
Chad from DW sent just the strut back up to me less the bags and I made spacer to make them fit, plus I extended the stroke as he wanted more lift
When Chad refitted the bags he damaged the orings, thus they leaked,
Chad bought new o rings for them but they were the wrong section width so they leaked also
I said to Chad send the whole lot back and i will sort it for you which i did
None of this time I have charged for any of this work
I would also like to point out Chad has no trade background in any mechanical field, but took this on anyway
So he has the struts back now no leaks with the right o ring so before any more BS is written be very sure of your facts as i have a screen print of everything that has been written and have sent it to my solicitor
If a retraction is not posted and all the posts correct i will commence defamation action
As for the Supra Chad was told what needed to be done to fit them but forgot to do it
Another example of why you get a tradesman to do a tradesman job
All of the Supra and Lexus based car I have fitted did not have any issues
FYI I am a qualified Fitter and machinist and Marine Engineer
I am 45 years old and have been doing this since July 1999
I have seen all these shops come and go all of which had no back ground for the work they carried out
I have a new Dealer down there now
Rollow, Matt Bumpstead in Mordialloc, he is more than qualified in his trade
Malow is offline
Old 24-06-2011, 12:53 PM   #32
schultzie
Just Images
schultzie's Avatar
I sincely apologies James, it would appear that i have not been given
The right story. I will call you shortly to also apologies.
Regards Justin Schulz
Fg XR8... Finished for now... Untill something breaks again OR A power Adder breaks something in the future
schultzie is offline
Old 24-06-2011, 12:54 PM   #33
Malow
Hear say if you repeat it needs to be correct
02 94576543
Malow is offline
Old 24-06-2011, 01:00 PM   #34
Pearly
Lowriding
Pearly's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the time spent at most functions taking photos free for us
Are Rollow the only dealer you have in Vic now?
Pearly is offline
Old 24-06-2011, 01:04 PM   #35
Zero_PSI
Zero_PSI's Avatar
Kinda think this thread is a good example of why we should call the people in charge of the work before trying to take customers away from a buisness.
Zero_PSI is offline
Old 24-06-2011, 01:13 PM   #36
lockieoc
Thats why i like to hear both sides of the story, to often we only hear the one side...
Now some poor bloke has to do the run around to fix it all up instead of getting on with his business.
lockieoc is offline
Old 24-06-2011, 01:21 PM   #37
Malow
Rollow looks after All of Vic for me
If you need gear give him a call
0434 040 357
Malow is offline
Old 24-06-2011, 01:26 PM   #38
schultzie
Just Images
schultzie's Avatar
Yeah well that is true, just got off the phone to James... Everything is sorted, I would like to see the thread locked later today after any one else wishes to make any more comment.
As stated it would appear clear to me that the middle man has not told me the truth and that James has done everything right for the better part.
Let's hope that I get my car back one day.
Closed Thread
