15-08-2011, 08:14 PM | #31 | ||
3 Pedals R Better Than 2
$50 blasted and coated. I'm happy with the finish, except in the cracks between the centre and outer rim section, you can see a few little globs of the powder coating.....looks like it bubbled up for some reason during the baking?? Not sure if that's typical or if it's due to operator error?
15-08-2011, 08:27 PM | #32 | ||
Preperation is key mate ... but that still looks sweet
15-08-2011, 08:28 PM | #33 | |||
Would ya like that cross over done mate ? My shout |
15-08-2011, 10:21 PM | #34 | |||
15-08-2011, 10:29 PM | #35 | ||
a.k.a PAULY
great rims i am going to get 4 of my spare T3 5 spokes powdercoated in black,i have been quoted $100 per rim including the bead blasting
2002 silhouette pursuit 250 manual,brembos, 3.73,s 2002 blue print pursuit 250 in restoration 1995 WMW250(CR250) dirtbike fully road registered 1947 ford thames tipper V8 21 stud flat head 1939 ford beer barrel truck V8 24 stud flat head HZJ diesel ute HJ47 diesel ute |
15-08-2011, 11:21 PM | #36 | |||
But $75 rim my cost .... i love the finish... |
15-08-2011, 11:57 PM | #37 | |||
Now Ford-less But good things are coming in 6 months
16-08-2011, 09:21 AM | #38 | ||
I will make it happen buddy ..
16-08-2011, 11:04 AM | #39 | ||
powder coating is definately better,
the earlier post saying there is no prep work done for it?? lol the sandblasting that is done before the powdercoat is applied makes the surface area of the metal about 10-15% more. there are tiny 'pits' and 'hills' everywhere, the gives the powdercoat grip like nothing else. and then it is baked on too, which hardens it like a ceramic style coating. if you chip it there is still a huge grip of the coating to the metal. powdercoating can be polished if you want a super flat mirror like finish too! you just need to ask around who is the best at their job (powdercoaters) and check out their work before you drop your parts off. 20 years ago i had some parts done and there were lots of tiny bubbles in it. i complained and they reacoated it and baked it at a lower temp for longer, resulting in an almost mirror flat surface and excellent gloss. imho some PC'ers will turn up the heat to hurry the job up and get it out sooner. paint is a applied to a flat surface, then it is covered by the next coat etc etc, etch primer, primer, basecoat, clear. and then there are drying times involved inbetween coats if each layer of paint is applied too quick the layers can later 'seperate' example how many times do you see clearcoat coming off car panels, once you get a chip or scratch in it, it weakens the bond between the base and clear, you can just about pressure clean all the clear off. being a painter / panel beater for a long time i have pressure cleaned clear layers off many panels, it's so much easier than rubbing it back... i know what id be using if i wanted coloured wheels cheers, craig
Money Talks, but all i ever hear is it saying Goodbye!! |
16-08-2011, 11:17 AM | #40 | ||
I have various engine components powdercoated including intale manifold top 1/2 and thermostat housing. after 5 years in the hot enviroment of an engine bay a quick hose and it looks as good as the day it was done
[SIGPIC][/SIGPIC]
16-08-2011, 12:49 PM | #41 | ||
normality is boring
Find a Good powder coater and you will be amazed at how good it comes up. I have seen powder coat finishes that look like chrome and the types of finishes you can get now are amazing. They are harder to touch up if damaged but the amount of time and the force needed to really stuff the finish would for me out way the hassel to touch it up.
Powder Coat FTW
Factory v8 with turbonetics 67mm turbo, haltech ecu, aeromotive and raceworks fuel system, cobra intake and a few custom bits thrown in |
18-08-2011, 01:57 PM | #42 | ||
does anyone know of a good powdercoater in sydney? and also rough cost estimates?
19-08-2011, 12:07 PM | #43 | ||
powder coated the frame on my custom harley back in 1989 nice smooth glossy finish did 64,000 miles on that bike including about 10,000 on dirt awlays cleaned up glossy and never a stone chip
19-08-2011, 02:38 PM | #44 | ||
Not speaking from experience, only what I've heard. The problem with powder coating is that when chipped it allows water to get underneath. It is all down hill from there as over time the water can cause the coating to lift. Keen to hear from anyone who knows more about this.
I had my steel wheels ceramic coated. I'm not sure but I guess the colour range is fairly limited. Where the inner and outer sections of the wheel meet I have squirted in a thin bead of neutral cure UV stable silicon. As it is a perfect rust trap in there. |
24-08-2011, 12:05 PM | #45 | ||
I'm in the process of painting my rims at the moment, 3 down and 1 to go. I'm painting the stock BA MKII Rims gloss black. Doing it myself, 4 coats of etch primer and 4 coats of gloss black engine enamel. The first wheel has been on for about a month, and still looks awesome, no chips etc, time will tell though. But touching it up should be a simple process should the need arise. It has cost me about $20 to do each wheel, so I can't complain.
21-09-2011, 11:25 PM | #46 | |||
Cruising...
It goes through alot offroad so what are all your thoughts? And yeh im aware its an old thread.
FBT '98 BA XT '04 F100 4x4 '82 Subaru Outback '02 |
22-09-2011, 01:12 AM | #47 | ||
I bought a set of second hand rims of ebay site unseen except for the pics put up and discovered when I got them delivered that they were badly damaged from hitting gutters. Nothing beyond repair though. Due to this I didn't think it would have been worth sending them away to get repaired then powder coated so I repaired them myself. They have been on the car for a year now and I think I've washed them once in that time and they are still o.k.!!
original rim when it arrived ( and not the worst one): During the repair: Undercoat: Then final colour: Only thing was I rushed a bit, so I could have done a few more coats on each rim. I was going to clear coat them with clear brake caliper paint which is resistant to the brake dust and brake fluid but liked the satin finish they ended up having after painting. All up it took me a week to sand all 4 rims, file, fill and repair the damage to each rim, primer them completely all over then paint them in 4 coats. I haven't had too many issues with stone chips at all, but I did clip a section of my retaining wall which was hanging out a little to far in my driveway and scratched one of them! Other than that painting them hasn't been an issue. Chippa |
30-10-2011, 04:14 PM | #48 | ||
lid man
we do both powder and wet spray,
IF YOU START with a raw part we powdercoat prime and do quite often put a wetspray on top for the likes of chrome and chrome shadow (yes it is sprayed).(for solid colours powdercoat is fine on its own!) Needless to say the raw casting has to be chromated first to give adhesion and chip resistance. Considering you want to recoat only then wet spray is the way to go!(you dont have to strip back) Solid and mettallic colours are possible on both applications even clear and chrome options are available Now. Powdercoating gives better chip resistance and will take the heat (brakes) trev -Progress spray |
16-07-2012, 10:47 PM | #49 | ||
I know its an old thread but i had the same predicament paint or powdercoat my 12 slots.
Anyway i was going to take the "ring everyone in the yellow pages" approach, i only managed to ring one person today. Alpha Powder Coating in Dandenong, Victoria quoted me $40 a wheel (not sure how good they are). Just thought id post it, as everyone elses quotes seemed a lot pricier. ps. Chippa666 your wheels turned out amazing |
