26-03-2012, 11:03 PM | #31 | |||
3..2..1..
26-03-2012, 11:34 PM | #32 | |||
Fixing Ford's **** ups
Strange statement considering having more neg camber helps cornering. Never mind, the pic makes for interesting comments
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone |
26-03-2012, 11:41 PM | #33 | |||
3..2..1..
too much of a good thing is a bad thing. |
27-03-2012, 10:15 AM | #34 | |||
My ride: 2007 Falcon Ute BF XR8 Orange, MTO. |
27-03-2012, 10:30 AM | #35 | ||
One Word - Stupid
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's In Storage : '74 XB GS 351 Fairmont Sedan XB Falcon Owners Group Mike's Man Cave |
27-03-2012, 10:57 AM | #36 | ||
it makes it look mean and what not, but for it to wore properly, you need to set the castor, toe in, toe out, and have the correct suspensionn set up. maybe for every day use -1 degree camber would help, but the principles above still need to be applied.
'99 AU Falcon S1 GLI factory manual in sparkling burgandy, 333xxx, NA + T BF barra conversion, FG TR6060 6spd manual, 3.9 lsd. Currently at 10psi. Power figure unkown at this time. Project "White Knight" 93 ED XR6 ROH Alloys Momo wheel Cruise Sunroof Premo Sound Manual HO Goodies http://www.fordforums.com.au/showthread.php?t=11447916 |
27-03-2012, 11:02 AM | #37 | |||
Critical Thinker
With my car I run 2mm total toe in and 1.5deg neg camber and a SuperPro castor camber kit. It is setup this way for better turn in and lateral hold in corners when I do hills driving or take corners faster. As far as tire wear is concerned, there is minimal wear on the inside, possibly some light feathering of the tread. But I tend to rotate my tires at requested intervals to minimize wear as well.
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
27-03-2012, 06:41 PM | #38 | |||
That's a big juggling act, which can be a PITA to the bloke trying to get minimal edge wear from a tyre to keep the customer happy. Problem faced is, the bloke setting the toe can only do a little guess work to begin with. Then the customer will complain, take the car elsewhere, where it'll be changed a little more, but the customer will still complain. Or in laymans terms, one big nightmare that's barely worth tackling.
27-03-2012, 06:50 PM | #39 | ||
Critical Thinker
Depends on if you are happy to accept a percentage of wear in lieu of better handling. For me, I will sacrifice some tire wear for this privilege. Others wont.
27-03-2012, 07:04 PM | #40 | |||
Do disrespect intended towards anyone, but you are one of the very few that does accept this. So I take my hat off to you. Unfortunately there are too many customers out there that expect aligners to perform miracles, which we can't. ie, have an excellent cornering car and no tyrewear. Those 2 items don't go hand in hand
27-03-2012, 09:25 PM | #41 | |||
Critical Thinker
For instance, if you have bent, or worn front end suspension parts you don't tell anyone about, worn bushes, slightly out of true wheels, worn shocks, uneven spring height, differentiating air pressures, uneven and undulating road surfaces and other smaller yet taken for granted wear and tear that isn't brand spanking new, then your alignment will be as close as it can be but never be spot on and stay that way for 10,000km, how could it be? It would be ignorant of me as the owner to blame an aligner to get it spot on for any of these factors alone. I took it upon myself to accept tire wear consequences when I ask my aligner to set my camber, toe adjustment and alignment the way I want it. I may be a minority, but its the pay off for better handling. What I see less of is tire places not warning customers of the added consequences of having better handling in this department. Most customers do not know of the sacrifice in tire life to gain better handling in this regard, but if told, I believe most will not try it. If you already do this, then there is no reason for the owner to place blame. The only way I would return to the aligner for a complaint is due to vibration in the wheels because of poor tire balance. Other than that I just drive and enjoy.
28-03-2012, 12:49 AM | #42 | |||
I agree with the worn suspension parts being a problem, and I do congratulate you being very acceptive of the possibilities of slightly more tyre wear, due to alignment settings. Unfortunately, there are people out there that don't see it the same way as you. This is where it does get rather frustrating for people like myself, trying to explain it to some people. Personally I wish there were more understanding people like you out there. It'd make peoples jobs like mine a lot easier. Hence me congratulating you.
28-03-2012, 12:55 AM | #43 | ||
I dont think cambers get much more aggressive than this...
28-03-2012, 06:51 AM | #44 | |||
Too many Fords........ :)
I rest my case........... http://www.youtube.com/watch?v=C7FiBhLoTS0 http://www.youtube.com/watch?v=umT-_UR151U
Current Projects 97 EL V8 wagon - cool cruiser, or street bruiser? CLICKY 93 XG panel van - at your door in 60 secs, or the first hr is FREE........ yep, that's the goal. 95 XG ute - awaiting a head gasket...... grrrrr. 74 XB GS pano..... factory optioned with all the good stuff..... not much there now. ........long term resto. XB Coupe and Van TV Ad you know........ there's a little bit of Bathurst in every Ford Falcon.... think about it |
28-03-2012, 07:04 AM | #45 | ||
