Old 21-05-2012, 08:10 PM   #31
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default Re: Clay Bars / Windscreens.
Your mini site is essentially correct, it has to do with the surface tension of the toughened glass. Because the glass is baked again after cutting and shaping the surface shrinks thus compressing the internal structure of the glass and hardening it. When you clay bar it you essentially are polishing the surface at a molecular level creating an uneven hardened surface. The compressed glass under the hard surface coat just needs the smallest weakness in the surface tension to cause it to fail and all it would need would be something as insignificant as a sudden temperature change or even a decent bug splatter at 100kph to "pop" the windscreen.
Bushbasher
MINE- AUII Forte
Old 21-05-2012, 08:26 PM   #32
Pepscobra
Call me dirt... Joe Dirt
Pepscobra's Avatar
Originally Posted by Poorboy_racer
Ahhh noticed the plate on your ute build.
Joe how are you mate?
Nice car mate!
Doing good thanks mate!
Been a bloody long time. Hope you're keeping well
It was the pristine Mini in Rocky posted on a Ford forum that got me thinking it might be you...! Plus you said you were a building designer
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100
Mods so far:
Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines
Mods to come:
4.11 Diff Gears|Chromoly Tailshaft
I use & recommend:
Castrol|Motorcraft|Mainlube|Penrite
Check Out My Build Thread
Pepscobra is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2012, 08:33 PM   #33
2.8L Hilux
2.8L Hilux's Avatar
I always clay bar and polish my windscreens. Good think I haven't done it to my mini yet. Thanks for the heads up
Ford Territory Titanium | SZ Mk1 4.0L
Ford Falcon G6ET | FG Mk1
2.8L Hilux is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2012, 08:40 PM   #34
Karnage
Finger Painter
Karnage's Avatar
Given the fact that a lot of people clay bar their glass and all modern cars have toughened side windows, I think the theory is moot.
Karnage is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2012, 08:42 PM   #35
chamb0
But would it be true to say that side windows are not subject to the same stresses as a windscreen?
chamb0 is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2012, 08:45 PM   #36
Poorboy_racer
Poorboy_racer's Avatar
Thanks for all the suggestions. Hope its saved the need for a replacement windscreen 2.8L Hilux.
And yes it was really doing my head in.
So yes claybars can make old toughened (not laminated) windscreens shatter. Still writing to Meguiars. They should put some sort of warning on the packaging.
Poorboy_racer is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2012, 09:56 PM   #37
Bushbasher
Bushbasher's Avatar
Modern technology and toughening techniques have all but eliminated the issues experienced with old school toughened glass. It used to be that glass was suspended from pincers and sent back into an oven and the heating process could be a bit variable in it's results. If you check the old toughened glass from the 60s' and 70s' you'll see small dimple or pin prik marks along one edge where it was gripped by the pincers. Modern techniques don't hang the glass the same way and the heating process is alot more even and controlled which makes the glass even tougher which is why a new side window can be 3mm or thinner and still hold it's integrity where as back in the 70s' and before the glass had to be at least 4mm thick to survive. Clay barring modern auto glass is not a problem as the surface of the glass is harder than it used to be and is mostly unaffected but that wasn't the case 30-40 years ago. Also, the larger the surface area and the more curvature to the glass, the more stress the surface is under and the more vulnerable it is to popping due to irregularities. Rule of thumb is, don't try to polish a 40 year old toughened windscreen, they don't like it.
Bushbasher
MINE- AUII Forte
Old 22-05-2012, 10:21 AM   #38
aussie muscle
aussie muscle's Avatar
My guess is the clay is taking off the top layer of the glass, leaving it exposed to cracking/breaking as only one heat treated side is removed.
Safety glass is not the same as modern laminated glass. the laminate will stop the fragments from falling out, like it did in your photo.
My ride: 2007 Falcon Ute BF XR8 Orange, MTO.
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2012, 01:52 PM   #39
Pepscobra
Pepscobra's Avatar
I reckon he probably had to punch the glass out so that he could see driving home.
Mods so far:
Mods to come:
I use & recommend:
Old 06-06-2012, 11:02 AM   #40
Poorboy_racer
Follow up:
Letter sent to Meguiars:
Dear Sir / Madam,
I regularly read posts made on the website: http://www.fordforums.com.au where I was introduced to your Quik Clay product. There were a lot of positive reports on the product. Back in 2010 I bought one of your Quick Clay kits for use on my classic Mini. As reported on the web site I was very happy with the results on my paintwork. There were numerous reports about using the product on their windscreens to get them really clear. I used Meguiars Quik Clay on my windscreen following the instructions given. That day when I drove my Mini the windscreen shattered. I put a post up on the website asking if anyone else had experienced the same thing. I was told no, they have been using it for ages on their windscreens with no negative results. This past weekend I was preparing my Mini for a classic car show and thought maybe it was a coincidence so I used Meguiars Quik Clay on my windscreen again. Once again the results were good and my screen was very clear, but once again the first time I drove my car the windscreen shattered. After some research I found the following examination to why my screen shattered:
● Its because it is a toughened (not laminated) screen. Used on all Australian Minis except Cooper S (and maybe the GT) which were laminated. The surface of the glass is in compression, when you clay bar it the surface stress is released, so tinkle tinkle. You shouldn’t even polish marks out of these screens with glass polish I’ve been told.
Get a new laminated screen……
As there is no mention of any problems associated with the use of Meguiars Quik Clay on glass on the product packaging. It opened up a debate on the website about cars with laminated windscreens and toughened glass side windows, please see the following posts:
● It has to do with the surface tension of the toughened glass. Because the glass is baked again after cutting and shaping the surface shrinks thus compressing the internal structure of the glass and hardening it. When you clay bar it you essentially are polishing the surface at a molecular level creating an uneven hardened surface. The compressed glass under the hard surface coat just needs the smallest weakness in the surface tension to cause it to fail and all it would need would be something as insignificant as a sudden temperature change or even a decent bug splatter at 100kph to "pop" the windscreen.
● Modern technology and toughening techniques have all but eliminated the issues experienced with old school toughened glass. It used to be that glass was suspended from pincers and sent back into an oven and the heating process could be a bit variable in it's results. If you check the old toughened glass from the 60s' and 70s' you'll see small dimple or pin ***** marks along one edge where it was gripped by the pincers. Modern techniques don't hang the glass the same way and the heating process is a lot more even and controlled which makes the glass even tougher which is why a new side window can be 3mm or thinner and still hold integrity where as back in the 70s' and before the glass had to be at least 4mm thick to survive. Clay barring modern auto glass is not a problem as the surface of the glass is harder than it used to be and is mostly unaffected but that wasn't the case 30-40 years ago. Also, the larger the surface area and the more curvature to the glass, the more stress the surface is under and the more vulnerable it is to popping due to irregularities. Rule of thumb is, don't try to polish a 40 year old toughened windscreen, they don't like it.
I don’t know if you have heard of any other case where this may have happened or were aware of the possibility, but after purchasing two new windscreens for my car I think your product should carry a warning about using on any glass on any vehicle manufactured before the creation of the more modern glass. Fortunately for me, apart from a few minor cuts picking glass chards up and punching a hole through my windscreen while driving to see where I was going I was not badly hurt, but as soon as the windscreen shatters obviously I couldn’t see where I was going so the situation could have ended quite differently.
As explained this did open up quite a debate on the website mentioned with some people concerned about the use of the product on glass. I have posted on the site that I will be contacting Meguiars and that I will post any response that may be received.
Regards,
Responce:
Its a bit hard to contact the window manufacturer as the car is 40 years old. I doupt they still exist.
Old 06-06-2012, 11:07 AM   #41
jcxr
Tribal Elder
jcxr's Avatar
Pilkington ACI may have been the manufacturer.
jcxr is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2012, 12:19 PM   #42
Poorboy_racer
Cheers when the rain stops here I will go outside and take a look to see if there is a manufacturers name on the glass.
