12-07-2012, 11:26 PM | #31 | ||
Forum Director
From the factory sheets, for stock standard engines..
1528kg / 161 kw = 9.49kg per kw. 1573kg / 165 kw = 9.53kg per kw. Without adding any potential benefits on the XR6 provided by extractors / exhaust(OP does mention that the XR6 has exhaust mods) the XR6 already has a better power to weight ratio(at 4500rpm) then the XR8, even if the gearing was identical. The fastburn heads in the Tickford XR6 heads respond well to exhaust mods. Unless the exhaust / extractor combo fitted is a complete abortion I am confident that the XR8 would need a bit more than merely levelling the gears. Personal experience with both of these vehicles in confirmation enough for me. |
12-07-2012, 11:41 PM | #32 | |||
http://forums.bimmerforums.com/forum...d.php?t=121351 Three different ratios simulated, the tallest ratio is quickest to 40pmh and 100mph. Over a longer run, they all even out. Diff ratios are a game of swings and roundabouts - you never get a free lunch. Of course, if you want to be the quickest from one set of lights to the next, by all means ... but in gear, on freeway for example, probably a different story. |
13-07-2012, 12:40 AM | #33 | ||
There is a such thing as a free lunch.
Where exactly is the 185kw au xr8 slower than any e series xr8 (excluding sprint which has 3.45 gears) For $400 you can get au xr8 equal performance in your e series xr8 (and walk away from an ed xr6) |
13-07-2012, 12:50 AM | #34 | |||
13-07-2012, 01:06 AM | #35 | ||
I have an eb v8 auto with 3.9 gears, rebuilt motor, ported gt40p heads,220 cam and explorer,1.72 roller rockers.ran a 14.5 quarter but i still think an xr6 of the same era with the same mods will smoke it.what can i say???
My car feels hell fast for a basically stock v8 but i know a mild xr6 may just eat me for dinner |
13-07-2012, 08:34 AM | #36 | |||
Oo\===/oO
I'd rather a 185Kw EL XR...or Ed Sprint, faster and prettier.
13-07-2012, 09:59 AM | #37 | ||
For what its worth, just prior to me purchasing my ED XR6 auto, I took an ED XR8 auto for a good long test drive. Was OK, but I was a bit underwhelmed. The old 5 litre Windsor was silky smooth but just seemed to have no top end. It just felt a bit asthmatic, but I don't think I've exactly unearthed a revelation here.
Jumped into an ED XR6 a week afterwards. 2 hours later I'd bought it. I don't care what the stats say, but the 6 felt livlier, more willing through the rev range, albeit a bit rougher whilst doing it. And the nose definitely felt lighter. Both cars totally stock. Brings back fond memories actually. That XR6 was a weapon in its day. |
13-07-2012, 10:05 AM | #38 | ||
The ED/EB XR6 did have a higher top speed than the XR8 equl. XR8 topped out at 220 vs 224kms an hour for the ED XR6 (however that comparo was manual to manual) I understand and appreciate that in autos this top speed may very well be different.
Regarding exhaust and extractors in the XR6 (its genie custom made extractors with genie exhaust, Doesn't sound any where near as loud as pacemakers alas but it punches hard....for an auto...) |
13-07-2012, 10:08 AM | #39 | |||
13-07-2012, 11:29 AM | #40 | |||
BUILT FORD TUFF
2015 FGX XR6 Turbo |
13-07-2012, 11:39 AM | #41 | ||||
In this universe, there is no fee lunch however... Quote:
13-07-2012, 11:49 AM | #42 | ||
Now Fordless
To the OP, you can do diff gears, full exhaust, underdrive pulley and I think tuning these is possible(someone may need to confirm) before wholesale changes are needed or supercharging. Going to need atleast a couple of thousand just for the basic stuff
13-07-2012, 01:20 PM | #43 | |||
Give me a ED XR8 with 3.45 gears in the back, full exhaust and Ill run any ED XR6 with full exhaust only, auto or manual. |
13-07-2012, 01:27 PM | #44 | ||
First Question What does it set you back to run change diff gears? Secondly for the same money what can be done on the XR6 for that same coin?
13-07-2012, 01:35 PM | #45 | ||||
The one and only
Cost is the major factor. You could start with good extractors and exhaust with 3.45's (so you are on par with the XR6). Depending on drivers skill and wear of the cars, the XR should be quicker. If you want to destroy the XR6. Then spend. 347, alloy heads, blower, etc. Quote:
XR6 prob get cam and head work.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
13-07-2012, 01:59 PM | #46 | |||
Now Fordless
13-07-2012, 10:58 PM | #47 | |||
Peter Car
The AU XR8 was just a superior package, the engine made more torque everywhere, more top end and area under the graph was well up on E series. It was just a superior engine, and i'm sure the IRS got the power down better too. The AU engine was so much better than what the figures show. In theory it should have been slower, cause it made the same power with an extra 10nm but with a lot of extra weight to carry, it goes to show it made a bit more than what they probably claimed, or more likely the E series V8's never made what they were claimed to. Some people believe the E series V8's were closer to 150kw than 165. Would also explain why the E series XR6's were easily quicker. |
13-07-2012, 11:14 PM | #48 | ||
Have a look at a ef fairmont ghia vs el fairmont ghia
Ef ghia= 157kw and 0-100km/h in 9.2 seconds. 3.23 gears El ghia = 162kw and 0-100 in 8.2 seconds 3.45 gears in diff. Do we really think 5kw makes up for the 1second 0-100km/h its the diff gears Same thing with el to au xr8. Minimal power improvement but diff gears and 1 second better 0-100km/h... Get the 3.45s and enjoy. Cost me $400 2 months ago fitted in the LTD 5.0 it will dust up a xr6 no probs now. |
13-07-2012, 11:30 PM | #49 | ||
Rob
i think one of the biggest problems is the pre ba xr6's are put up on some sort of pedestal compared to their v8 brother. the fact is there has never really been any sort of great divide between the xr6 and xr8. people talk like its daylight second but the numbers often only show a matter of tenths in it one way or the other.
even when xr6t came along, stock for stock, there was very little to choose between a boss and a T but that discussion has been done to death. too many times you get stories from 'my mate who owned xyz, thrashed my other mate in his zxy' etc etc. in the OP, the xr6 already had exhaust, so an xr8 would probably need an exhaust as well as diff gears. it all depends on your definition of 'faster' though. |
14-07-2012, 01:23 AM | #50 | ||||
14-07-2012, 07:43 AM | #51 | |||
A more even test might have been fairmont EL vs fairmont ghia EL. |
14-07-2012, 07:55 AM | #52 | |||
Tickfored worked well on the XR6. The XR8 really wasn't much different to the family v8 engine if it was at all. And yes 3.45 has abit to do with it......so does weight...so does the gearing in the gear box certainly in manuals autos well they're the same gearing there. I do find it interesting tho. They got 7.2 0-100 15.2 0-400 m with the EB XR6 in one comparison. Yet AU XR6 VCT 172 KW over the 161 and 374nm vs 365 nm they still couldn't get a sub 14 second quarter in the fat pig of a thing. what it boils down to imo I think there is wednesday cars and friday cars and I think this is more apparent in early E-series cars. They seem very inconsistant. you'll get one thats kinda average then one thats off its tree. |
14-07-2012, 12:04 PM | #53 | |||
14-07-2012, 12:59 PM | #54 | |||
Sorry, but at this stage, it just looks like you're pulling numbers out of your ****. |
14-07-2012, 01:13 PM | #55 | |||
14-07-2012, 01:28 PM | #56 | ||
lols at the internerds having a internets drag race...
14-07-2012, 09:55 PM | #57 | |||
Peter Car
15-07-2012, 12:43 AM | #58 | |||
I dont make up times. The 3.23 geared i6s were 0-100 in low 9s. The 3.45 geared i6s 0-100 was low 8s. I have a million motor magazines confirming. The windsor v8s with 3.23 gears were low 8s for 0-100 sprint. But with 3.45 diff gears (from au) they were low 7s for the 0-100. Ford responded when the holden sticking the supercharged 6 in the calais by sticking the xr6 motor and 3.45 diff in the ghia. The xr6 motor added a chicken feed 4kw but the 0-100 time dropped by a second. It must be the diff gears. |
15-07-2012, 01:02 AM | #59 | |||
If the magazine figures are showing big differences, its different test conditions. |
15-07-2012, 01:13 AM | #60 | ||
Performance moderator
Tickford didn't touch the V8 till the AU T series..
Sure there was some minor parts like badges etc.. The AU engine was basically a truck engine .. So is the 5.4 Boss engine for that matter...
